Question about Healthway Air Purifiers
A smell is coming out of the healthway purifier. It was so bad, I had toturn it off. the filters are clean. and I vacuumed them again.
Keep the machine running it must have gotten something stuck in the main filter or call healthway and ask them for a post filter. That worked for me and we couldnt live without the machine now
Posted on May 30, 2011
  • richmanfl May 31, 2011
    Media filters often absorb odors in the environment and when these machines are turned on and off you will have an issue with smells. You should always run these 24/7, so just run the machine until this odor cycles through...should be no more then 1 hour. I love these systems!
    When did you last change the filters?
There is a bad smell coming from the indoor unit of my Mitsubishi Mr Slim split-type a.c.
Mitsubishi MSZ-GE06NA Mr.... Repair Questions - Fixya
www.fixya.com/.../p3677512-mitsubishi_msz_ge06na_mr_slim_wall_m...
Recent Mitsubishi MSZ-GE06NA Mr. Slim Wall Mounted Indoor Unit Air Handlerquestions, problems & answers. Free expert DIY tips, support, troubleshooting ..
Jul 26, 2015 | Mitsubishi MSZ-GE06NA Mr. Slim Wall...
I cleaned purifier plate and filters and purifier still won't workon my fresh air machine
The air purifier filters which need to be washed lose their efficiency very fast and need replacement every few months . I think its time you switched to a better air purifier like this with superior filters which last longer and can be cleaned using a vacuum cleaner Premium Air Purifiers with e2f technology
Oct 22, 2014 | Air Purifiers
Air purifier filter smells bad
That's interesting... I doubt it is the filter if the new filter did the same. It might help if you take a fan and blow it through the area behind the filter, or maybe even spraying some Lysol in it, because my best guess is that something inside the purifier is what is causing the smell. Hope this helps!
Feb 24, 2014 | Blueair Air Purifiers
Can the hepa filter be cleaned?
The link below will show a page on how to clean and care for your air purifier. Although the Hepa filter can be cleaned multiple times, the manufacturer recommends you replace it every 12-18 months.
Bionaire Air Purifier Care + Cleaning
Jan 09, 2012 | Bionaire LC1460-U Air Purifier
I am not sure when or how to change the filter for my ecoquest air purifier. I moved into a house with brand new carpets, floors, paint etc. and then had a flood. I was running the purifier fairly...
If you have a HEPA filter, it may need cleaning. Every month at least. If you figured you don't NEED one because of the machines abilities to knock down particulates, you're most likely right. HEPA "filters" tend to grow their OWN nasties after a short time with ANY moisture around at all. The plate may have VOC's crystallizing on the plate. Check the lint screen and if it doesn't smell bad(musty) and you can see light thru it when you hold it up to a light, it's probably only needing a vacuuming. Some people rinse them in warm soapy water. Make sure it's DRY before putting it back in.
Jun 13, 2011 | Ecoquest Fresh Air Air Purifier
How do i test that healthway filter is able to reduce bacteira and germ cioncentration in an HIV /AIDS FREE DRUGS CLINIC OF ABOUT 300 PEOPLE COUGHING
Strictly speaking, you would need to run culture tests in a sealed laboratory to conduct such a test. There is actually no way for the layman to verify that microorganisms are being killed by this device. Either you believe the company's claims, or you don't.
Apr 14, 2010 | Healthway EMF 20600-2 Air Purifier
IT SMELLS LIKE A GAS COMING OUT OF IT, ESPECIALLY WHEN I CLOSE THE DOOR IN A ROOM. I BELIEVE IT'S OZONE LIKE A COPY MACHINE. IT IS VERY IRRATATING TO MY LUNGS.
Whilst Healthway claim that they do not use ozone generation as a method of treating microorganisms, generally speaking, any high voltage system (18kV is considered high voltage) will generate some degree of ozone. All that is required is for an electrical connection wire to have some sharp edge and the high voltage will generate ozone. There is no solution to this, however since the device is Listed by the FDA as a Class II Medical Device, you should write a letter of complaint to Healthway.
Mar 01, 2010 | Healthway EMF 20600-2 Air Purifier
Is this purifier hepa or ozone?
Strictly speaking it is both and neither! It incorporates a high voltage source (18kV) which has the potential to create ozone, though the manufacturer does not claim that ozone is the means by which micoorganisms are defeated. It also incorporates an 85% efficient HEPA filter, but teams it with EMF technology (their own patented technology using the 18kV energy field) to increase the HEPA efficiency to 99.99% (their claim).
Oct 13, 2009 | Healthway EMF 20600-2 Air Purifier
Air Purifier smells like chlorine
Mine does too. Did a little research - I guess all air filters let out a little bit of ozone. Some describe the smell of ozone to be something like bleach yet others say it smells like geraniums or even "sparks" (like the sparks that come off of the bumper car ride at the fair...hmm...interesting). Not sure which to believe, but I know mine smells.
I found a manual talking about reducing this smell. Said the first couple of weeks are the worst of it, but if it still bothers you, you could install an "activiated carbon filter" down stream from the air filter, or go through complicated instructions (for whatever model they were talking about) to go into the of the machine and switch stuff around.
Both solutionssound complicated to me.
I'm just happy knowing the smell is normal and that it is actually working. Think I'll live with the smell.
Dec 13, 2007 | Brookstone Pure-Ion (506840) Air Purifier
Air Purifiers Logo
174 people viewed this question
Top Healthway Air Purifiers Experts
Are you a Healthway Air Purifier Expert? Answer questions, earn points and help others
