Question about EliteGroup G31T-M7 Motherboard
I just bought a mother board and a matching processor when i finish fitting it up fan and all is spinning but monitor says signal cable disconnected i boot with out memory and it beeps i test the processor and its working need help
  • girlspet23 May 29, 2011
    ok a dont have the manual but i figure the beeps are memory problems because my memory stick is ddr2 533 and the mb used ddr2 800 ddr2 667 so a guess i will have to buy a set tomorrow
    Sergeant:
    Champion:
  • 223 Answers
the problem you are facing can be detected by the beeps you hear. Normally those beeps are a code that let you understand where is the problem.
You should take your motherboard manual in which is written those codes. If you don't have it you can download it also from producers website,
Let us know if you solved your problem
Posted on May 29, 2011
Computer powers up, MONITOR says no signal
had same problem...re-install windows ...bad drivers and such
worked fine after that
Mar 31, 2014 | Gateway Computers & Internet
My Mother Board Is **acer sf2 661fx rev 1.1**. Now I Have A Problem, Please Solve This.......... No Signal To Monitor, But Mother Board Is Working. After That I Tried To Solve The Problem By Following...
haii all.....
i facing problem on mb acer sf2 661fx rev 1.1 no power to cd rom and hdd...also monitor not shown anything... cpu fan and casing fan only working..any idea pls..
Aug 03, 2010 | Acer (ACERMOTHERBOARD)
No signal or cable disconnected or power problem
check the black cable with big blue connector at the back of the monitor if its connected properly. Also follow the cable and check if its securely attached at the back of the system tower. if the cables are connected properly check if the cable is connected to the correct port at the back of the system tower. Some computers have two places to connect this cable one towards the top and other towards the bottom of the system, tower.
Thanks for using fixya
proton
Jun 16, 2010 | Dell Inspiron 530 Desktop Computer
Turns on (fans spinning, HD clicking), blank screen, no sounds
hi this issue is with ribbon cable it is connect between the mother board and your LCD screen. the cable required change. if you can change it OK other wise take it to nearest service center.
Jun 15, 2010 | Acer Aspire One Netbook 8.9" Notebook
Hp pavillion 533w wont boot up green light on front comes on but thats it no fans coming on either
Hi ,
If the green light comes on on the front panel then it means the fan is spinning so what u can do is a self test for the monitor.Disconnect the vga cable from the back panel of the computer tower and then check if there is a message displayed on the monitor that should say check video signal or no inoput signal ,if there is no such message displayed then it means the monitor is a fault .If not then reset the memory card and then check .U can also run a test for the motherboard to do this u will have to remove the memory card and then turn the computer on if u hear long beeping noise it means the motherboard is fine .If u dont hear any sound then the mother board needs to be repaired or replaced...
all the best
May 01, 2010 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
Not gettin any signal from cpu
When the monitor shows no signal it means either the data cable going from the monitor to the computer or the computers graphics card needs to be replaced.
Sep 07, 2009 | Computers & Internet
Mother board no display
Looks like the lights are on? Fans spin? Sounds like the harddrives spinning? The power supply is bad. has just enough power to light lights, and spin fans, but not enough for the processor. (No beep sounds, because BIOS hasn't done a memory count. It's not going to)
ALL the lights use less than 1 Watt.
EACH fan uses 2 to 3 Watts.
The harddrive just sitting there spinning, uses about 5 watts.
Processors use 55 Watts to 125 Watts. Depends on the processor.
Not enough power to turn the processor on, the computer won't work. Computer isn't working there isn't anything to turn the monitor on. No Signal.
Apr 17, 2009 | Intel Motherboard
Monitor displays signal cable disconnected
Check if motherboards you connect the monitor into has a video signal frequency range that the monitor supports.
Feb 01, 2008 | Dell UltraScan P1110 21" CRT Monitor
EliteGroup G31T-M7  Motherboard Logo
89 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
