Question about Electrolux Kitchen Appliances - Others
Need to find 1/4"-28 x 3.25" self aligning screws
The item you are looking for sounds like a microwave mounting bolt. Check w/ Sears or other stores that sell microwave ovens and purchase a mounting kit.
Posted on Apr 08, 2014
Technics SL-P111 door wont open!?
Some units require a draw be in alignment with the rest of the system in order for the mechanism to get into the right place to trigger skeleton switches or small microswitches. You hand upset that positioning and the only way it will work now is to get the mechanism aligned so that all is happy. This will require a Technician who is capable of working on these units. I have seen this on many brands- the better unit are self aligning but there were some that were made like yours that have trouble.
Sep 21, 2012 | Technics Audio Players & Recorders
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Tip
SERVICE MODE AND ERROR CODES CHECK
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
I HAVE A PRINT CARTRIDGE ALIGNMENT problem wiht my HP C7820
Try to find the alignment software in your HP printer's Control Center. If alignment does not work, you could un-install the HP printer software and drivers. Disconnect the printer from the computer. Restart without HP software, drivers, and printer. Shutdown. Now reconnect the printer and turn the computer back on. Re-load HP software and drivers. Follow there direction as you go. You'll be asked to align the printer.
Sep 02, 2012 | HP Photosmart C7280 All-in-One Printer
Adjusting bi-xenon headlights on Volvo S40
This guys don't know what they are talking about. If you have self leveling head lights and they are way out of alignment, yes there is adjustment screws but those mess with a different light bulb (daytime running light) instead of the main bulb alignment.
So what is a man to do? go to the dealer and have them adjust them for you. Believe it or not everytime you get an aliment done you have to recalibrate your headlights because they change the way the vehicle sits. Do it enough times and the headlight will go out of wack (because of the self leveling function)
In other words, they headlights are adjusted by means of a Computer. You could do it your self but you have to buy the DICE VIDA adjustment tool and the proper software from Volvo. Not cheap, just go to the dealership.
Jul 05, 2012 | Volvo S40 Cars & Trucks
How to replace1986 toyota front shocks
I believe the front shocks are actually STRUTS you can replace the strutes your self with minimal effort. the vehical will then need to be aligned. my suggestion is to purchase the struts your self then talk to your local trusted shop that does alignments you can usually make a deal with them to have them install the struts for an extra 5 to 10 dollars other wise install your self then take it to the alignment shop
Jun 03, 2012 | Toyota Cars & Trucks
Plastic bobbin gear rod unscrewed, how to align with bobbin round gear
Type into browser: http://fixsewingmachine.com for diagram and instructions. Hope this helps! Jimmy
Apr 06, 2012 | Brother LS-2125 Mechanical Sewing Machine
Gas Self Cleaning Oven: When we tried to use the "self cleaning function" of our oven a "F5 E1" code was displayed. According to KitcheAid this indicates a "Latch System...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 26, 2010 | KitchenAid KGSA906PSS Gas Kitchen Range
Mis-alignement between eyepieces
Up close to the eyepieces around the barrels are small screws that you can use to "collaminate" your binocs. The screws aren't meant to be accessed by the owner and most manufacturers cover them up with the material that surrounds the binocs. Of course the binocs in their current state are useless anyhow, so I wouldn't hesitate to peel up the material to look for the screws. If you do it carefully, you can reseat the material anyhow. Then once you locate the small screws, put the binocs on a stand or a table outside. Focus on something far away using one eye. Then using both eyes, you adjust the screw on the other eyepiece while looking through the binocs. Adjust until you get a single image. You can use loctite, or nail polish to "glue" the screw in the final position if it is really loose.
May 07, 2009 | Nikon Action Zoom XL (10-22x50) Binocular
Kitchen Appliances - Others Logo
460 people viewed this question
Top Electrolux Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Electrolux Kitchen Appliances - Other Expert? Answer questions, earn points and help others
