Question about Electrolux 18 in. ESL4114 Slim-Line Built-in Dishwasher
Elctrolux dishwasher .... the water is not running into the machine have checked water supply filters ect all fine just no water running in please help not sure if the code is right here but its a slim one about 5 yr old
What is error message e15
What brand dishwasher? Model number might help too.
If it is a Bosch this might be the answer.
The E15 fault code means that the dishwasher is not receiving water through the water supply hose, or at least that what the machine thinks anyway.
E15= Check Water Inlet supply*
This can be caused by several reasons.
1. The filters in your inlet hose or inlet valve are blocked and need cleaning.
2. The inlet water supply valve is faulty and worn out, not allowing water in fast enough in relation to the set amount of time it takes to fill the machine for washing etc..
3. The water supply isnt turned on fully underneath the sink?
You will need to undo the water inlet hose from under the sink and check to see if there is a filter in that end of the hose and check to see if it needs cleaning. It will be of the wire Gauss type.
If not, then you will need to uninstall the dishwasher and pull it out from the cabinet to check the inlet valve where the inlet hose connects to at the bottom rear of the machine.
The valve itself will have a filter, where the hose attaches to. Undo the hose and visually check the filter in the valve for blockage/restrictions.
If the above brings no results, then you probably need a new inlet valve for the dishwasher.
Sep 04, 2014 | Dishwashers
Are there intake filter screens on the GU1500XTL B?
I have never heard of a water filter for a dishwasher since the water entering your house is clean and filtered and potable. If the water supply line for your dishwasher is clogged you have a different problem where in you must clear it to allow sufficient flow for the machine to fill. If it is restricted it will most likely take longer to fill but it will still operate. If the filler is on a timer then you will not be getting enough water into the machine and must restore adequate flow for it to operate. There is no need to filter water into your dishwasher. People who have water supply problems will get water conditioners for hard water issues and whole house filters for sediment problems. I would get Culligan to take responsibility and fix the problem if they caused it.
Mar 11, 2014 | Whirlpool 24 in. GU2500 XTP Built-in...
Have just tried to install a secondhand dishwasher which goes for about 5 mins and then shows UE. Could you please tell me how to fix this? Thank you Nancy
UE- means an unbalanced load in a washing machine.
le- means make sure water supply inlet hose is on. check inlet hose for any kinks or bends in the line
that could prevent the machine from filling properly, check and make sure the water supply is on
completely and not partially. check inlet filter for buildup of mineral deposits. clean filter with small
brush. make sure that machine can drain properly. good luck!
Apr 09, 2011 | LG Dishwashers
Whirlpool ADG7540 approx 4 years old (maybe a bit older) I have ran diagnositic check and the start light flashes 4 times stops briefly then flashes 4 times again over and over along with a continuous...
Yikes, we have just identified this exact same problem tonight. If you've had any success with fixing it, we would sure appreciate hearing how. Best of luck with your machine
Mar 03, 2011 | Whirlpool 24 in. ADG7540 Built-in...
Bosch dishwasher SHX46AO7UC/14 Cycle doesn't run. I suspect the filters are clogged with our hard water. Have cleaned the main outlet to best of my ability but how do you get at inlet filters?
You will have to get to the back of the machine where the water feed pipe is.
There can be a filter at the supply tap and also in the back of machine where pipe goes into the unit.
If you have hard water do you use salt (dishwasher salt not cooking) in the water softener dispenser and adjusted the machine to the correct level ?
Please dont forget to vote this answer was helpful
Many thanks
Feb 13, 2011 | Bosch Integra® 500 SHX46A0 Dishwasher
Hallo I have bosch dishwacher and red light check water. allready water pipe is fine.could you help me pls?? thanks
If your water supply is fine and filters not blocked the problem could be the water supply solenoid inside the machine has stopped working.
Many thanks
Feb 13, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dishwasher won't start until running until at
The 2 minutes is most likely the "Fill" time in the cycle therefore since the water supply is active the fill solenoid is spent or not getting a signal.
Dec 12, 2009 | Kenmore Dishwashers
I am not getting any water into my Inglis scour master. It is a built in model. Any solutions???
Have you checked the inlet filters on the water hoses ?
If you unscrew the water hoses from the machine, and look inside the connections on the machine, you should see the filters - they are usually a plastic "cage" supporting a gauze or fine mesh. These can be pulled out (you may need tweezers or fine nosed pliers) and washed under a running tap.
If this doesnt cure it, check that the water supplies where the hoses connect to your house plumbing are actually fully on and flowing properly, and as yours is a built in model, that when the machine is pushed back in to it's housing the water hoses are not being kinked or trapped to the point the water cant flow properly.
Otherwise, there is probably a fault with the solenoid valve(s) on the machine that controls the flow of water in to your machine.
Nov 08, 2009 | Dishwashers
Water is not filling into dishwasher. Everything sounds like it is running ok and water supply is on.
Go to the back of the machine, where the main water inlet connects. The connection there is the inlet valve that should open when you switch the machine on. Usually you have to remove the machine outer casing to get to the valve. The valves are quite cheap. Cheers, Derek.
May 19, 2009 | Dishwashers
Electrolux 18 in. ESL4114 Slim-Line Built-in Dishwasher Logo
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
