Just purchased a new Keystone Laredo travel trailer and the air conditioner or fan will not come on when setting the thermastat
    President:
  • 3,074 Answers
Are the breakers on and power applied to the unit, Tim
Posted on May 29, 2011
I have a new keystone hideout with dometic single zone lcd thermostat when i put it to furnace the ac fan comes on at same time but when furnace reaches temp. ac fan just keeps blowing cool air?
Obviously wired wrong. I will assume it is still under warranty? If you only recently picked unit up, I would also question the quality of the PDI performed. ( Pre Delivery Inspection) Have you tried to contact dealer you purchased it from?
Oct 14, 2012 | Dometic Rooftop RV Air Conditioner
My Dometic AC on my travel trailer cools well but I cannot set the fan to stay on when the compressor cycles off. Can a different switch or board be installed to allow the fan to stay on?
An energy saver setting is what it sounds like. Turn off energy saver feature and fan should run 100% and compressor cycle on-off separately.If not familiar with energy saver setting .make sure it has one or not before disregarding this.
Feb 28, 2012 | Dometic Rooftop RV Air Conditioner
Just purchased a Keystone Cougar travel trailer with a Colman air conditioning unit. It does not do the job. The dealer I purchase the trailer says it is operation correctly. It is supposed to put out...
Common problem with TT's. the first thing I do is always find afternoon shade to park mine under to decress loads. Also If you are getting a 20 degree split between the air coming out of the unit and the air returning to the unit its doing all it can do and its doing good.I would also recommend that you crack the cabnits open a bit to prevent hot air build up inside those spaces. It is really hard to size a unit as TT's are used in cool areas as well as hot areas and one size does not fit all. You might want to concider a larger unit? tough call .. Hope this helps .. let me know Jon
Aug 05, 2011 | Coleman Heating & Cooling
I have a springdale travel trailer with a dometic ac system. When I turn the air on, with the fan in the auto position on the thermostst, the compressor turns on and runs, but the fan does not. The...
Neither.
The fan should run in the 'auto' position.
If it runs (on hi and lo settings) then I doubt if anything is wrong with the fan motor.
I would think your thermostat is bad and needs replacing.
Jun 05, 2011 | Dometic Rooftop RV Air Conditioner
I have a 2006 Keystone travel trailer that has a remote control that opperates both the air conditioner and the furance for some reason I can not get the unit to work in either function with the remote or...
Check all 12 volt fuses in panel, as well as make sure breaker is on that powers unit. Also if you pull face off wall thermostat, you may have glass fuses in there & possible one or more has blown & will need to be replaced. Do you hear any clicking when you operate thermostat manually from wall?
Sep 12, 2009 | Heating & Cooling
A/c trips breakers
You may have a short in the system. There could be a lot of solutions to this problem. Maybe you could give more detail. May need a professional to look at this one? If you can give more detail I could try to help.
Aug 20, 2009 | Dometic Rooftop RV Air Conditioner
I have a 247 03 Springdale RV trailer. I want a
Depends on wattage demand of ac unit. VXA=W 110x20amps=2,0200 Watts. A 2,00 watt generator is too small. Best go for a 3,kw genset. A 5 kw will leave you room to run appliances and the ac simultaneously., otherwise you will need to watch your margin usage. I think 4.5 kw gensets are also available. Happy trails.
Jul 25, 2009 | Heating & Cooling
Heating & Cooling Logo
133 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
