Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
I need gateway and dns numbers to connect samsung bluray mod# bd-d5700/2a with 327w mod#wis09abgn can you help me
  • 4 Answers
On your computer open up a command prompt (click start, then run, type in cmd press enter)in the command prompt window type in IPConfig /allThe output of this command will give you your default gateway and DNS information for your network
Posted on May 29, 2011
I had Att DSL and never had an issue with my bluray player. I switched to charter Internet and now my Samsung BDP-1590 bluray player will not connect to the internet. Any ideas? I have reset the bluray....
If you're using the same router, nothing should have changed. If you're using a different router, you will need to connect to the network from the blu-Ray player, providing the network pass phrase/preshared key. You could try using an Ethernet cable from the router to the BD player and see if it works that way. This is assuming your network is up and the rest of your devices work fine.
Hope this helps!
-Plemmons
Jan 24, 2015 | Samsung Televison & Video
I need an owners manual for a Samsung BlueRay DvD Player mod #BDP3500
The model number BD-P3500 does not seem to be right. probably you are looking for BD-P3600. But, this unit also does not have built in wifi support. You've to use a wireless LAN adapter. This unit is compatible with Samsung's Wireless LAN Adapter only (Model name: WIS09ABGN). If you already have it, then the configuration is simple. Try to follow the instructions in the manual from this link. http://downloadcenter.samsung.com/content/UM/201104/20110419175550529/BD-P3600-ENG-BM-0930[1].pdf
I hope you find this useful
Jan 10, 2014 | Computers & Internet
Can't connect Samsung bd-e5400 to network
put in network password and had an "unable to connect" message, turned the bluray player off and on again and then the network connection worked fine. I had to also switched to "manual", failed to manually assign an IP, then switched back to auto. 1 of those 2 things solved my problem.
Dec 25, 2012 | Samsung BD-E5400/ZA BLURAY PLAYER BD WISE...
Need code for samsung bluray player
google model number of bluray player and look for common FAQ's about programming a universal remote or do a search for common codes for smasung bluray players and try each one
Jul 09, 2012 | Samsung Bd-d5700 Blu-ray Disc Player black
Region code for Samsung BD-E6100
Try this code I have got it with this code may be you will also get yourthe code is: BD-E6100/XU.Perfectly I don't know whether it is for all regions or not but try this.
Performance Chip
May 23, 2012 | Samsung BluRay Disc Player BDC7500 BluRay...
The Salt blu Ray wont play in my Samsung blu ray 1500 player? What is wrong?
Connect the ethernet cable to the backside of the samsung bluray 1500 player ethernet connection with the bluray player power on with no disk & it will automatically update your bluray. It should be work fine after update your bluray. Good Luck!
Feb 06, 2011 | Samsung BD-P2550 Blu-Ray Player
Samsung BD-P1500 Blu-Ray Player won't play salt blue ray dvd
Jan 05, 2011 | Samsung BD-P1500 Blu-Ray Player
Samsung BD P3600, can not connect to the Wi Fi system on my Apple Time capsule. IP address I have Subnet mask number I have gateway number I don't know what this means DNS server number? I hope someone can...
Forgive me if you know this already IP address needs to be different to the Apple one. If the Apple one is 192.168.0.1 make the Samsung 192.168.0.2. subnet 255.255.255.0. Gateway should be the same as the apple number.. DNS can be left to automatic but if stuck use 4.2.2.3. Check the security settings on both the Apple and the Samsung are set to the same type
Oct 11, 2009 | Samsung BD-P3600 Blu-Ray Player
Samsung BD-P1200 (Bluray) Remote Control stop responding
Try resetting it.
Remove the batteries and hold down the POWER button on it for 30 secs. Then replace the batteries with fresh ones.
Dec 19, 2008 | Samsung (1012861) Remote Control
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
132 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
arnold balmaceda
arnold balmaceda
Level 1 Expert
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
