Question about JVC XV-S65 DVD Player
What channel do I put the TV on for this type of DVD player.
  • 643 Answers
Not channel need to go to the input that you plugged into the tv. On the remote should have a button labeled input, source, or tv/video. Turn on the player. Next run through the different inputs to find the dvd player. Hope this helps.
Posted on May 29, 2011
How to get dvd on tv
There are generally 2 ways to connect a dvd player to a tv.1 If you have 3 rca connectors on the back of your tv (they are color coded yellow for video and white and red for audio left and right channels respectively) and the same connectors on the back or side of the dvd player.Use rca cables to connect the dvd player to the tv,connecting yellow to yellow white to white and red to red.Using the remote put your tv on video.Put the channel selector on the dvd/vcr player on video or L1 or E1 (depending on what brand dvd/vcr you have).2 connect a rf (coaxial cable from the rf output of the dvd/vcr and connect this directly to the rf (antenna) input to your tv.Put the tv on channel 3.Play the dvd/vcr to see if you have the video.If not put the tv on channel 4.Some dvd/vcr's put their signals out on channel 3 and others on channel 4.Good luck.
Sep 15, 2013 | Disney 13" TV
How do i hook up a dvd player to my tv if i have cox cable? I dont know what channel to put my tv on. I know there has to be a way to watch a dvd without unhiiking the cable
Most DVD players have a coax input and output on them. But some newer ones don't. Assuming your does then you can run your DVD player to your TV with a coax cable you bet. Either on the back of the DVD player there will be a little switch or in the menu settings it will give you an option for channel 3 or channel 4. The same channel you select on the DVD player will be the same channel you will want to put your TV on. For the coax install run it from the output on your DVD player to the coax input on your TV. If you use a coax for cable too then just run you coax from the output on your cable box to the input on your DVD player.
Mar 20, 2011 | Samsung Televison & Video
I have an older RCA television and when I hook the dvd player up to it the tv says unusable signal.
I don't know if this will help. Try changing the tv channel to channel 3. If that doesn't work, depending on which port you plugged into, start at channel 3 and go down in channels. it should change to the different ports you have with every push of the button. to get to channel 3 you may have to use your remote and type in '03'. Make sure your dvd player is on while you do this.
hope this helps
Aug 08, 2009 | RCA L32HD41 LCD TV
DVD Player Only Produces Snow After Power Outage. Halp!
Sounds like your TV has lost the DVD channel. Turn off TV and make sure the DVD player is connected to TV and is playing a DVD. Now put you TV on and press the SOURCE or AV button on your TV remote until you can see the DVD channel. In older TVs you may need select channel and tune it manually using the TV setup.
Jul 10, 2009 | Insignia Digital-to-Analog Converter for...
I just Cant figure out how to hook this DVD Video Player to my TV
You must give a clearer explanation of the type of television you are using and the type of cables you are using in the hook-up. You should give the television name and model number.The type of connections you are trying to use. What the problem is.Is a conflict between the remotes or just a user problem. You should find all reasonable hook-up information for you television in the owners manual. The same goes for the dvd player. Hope this helps you with your problem.
Apr 19, 2009 | Cyberhome CH-DVD 300 DVD Player
Video channel
if your DVD player supports a HDMI cable a single cable is enough for both audio and video channel.
but both your player and TV must support HDMI.
Aug 12, 2008 | Samsung DVD-V4600 DVD Player/VCR
Can't get TV onto the AUX channel
You can purchase an RCA universal remote that will let you access the A-V inputs. These only cost about $10.00 or so. Stargazer
Sep 09, 2007 | RCA F25254GY 25" TV
JVC XV-S65 DVD Player Logo
46 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
