Question about Hayward 1 12 Hp Super Swimming Pool Pump Sp2610x15
Opening pool can't get prime
  • 5,370 Answers
Can't get your swimming pool pump to prime up and begin proper circulation? If your pump basket is not filling with water completely, then you have air getting into the system and it is not working properly. Usually this can happen when you open your pool for the swim season especially if you winterized your pool.
Make sure you unplugged any of the lines you may have closed off for the winter. If you can, have someone block off the intake while you add to the basket, when it will take no more, cap and turn it on.Have the person keep the end blocked for a couple seconds then remove once the pump it at full speed(2-3 sec). If this doesn't work, your probably have going air through the cap, get an o-ring.The o-ring needs to be replaced.-------
Click this link for more help:--- http://technoanswers.blogspot.com/2011/05/swimming-pool-pump-priming.html ----------- This should help.Thanks.Helpmech.
Posted on May 29, 2011
How to prime an A O Smith pool pump
if the pump is higher than the pool, you should have a ball valve at the front of the pump. close this valve, fill pump housing with water. close the system, open the valve and turn on pump. if the pump is below the pool level, you shouldnt have this problem.
Jun 27, 2014 | AO Smith Pool & Spa
Prime
Hi to prime your pump you fill the strainer basket with water and make sure all connections are tight with no leaks. Once you seal the lid turn on your pump and it should prime. If you have an issue you can force water through the suction line by putting a hose in the skimmer and force the water through your suction line. Time to Open the Swimming Pool
Jun 06, 2013 | Waterway 1 HP HiFlo Above Ground Pool Pump
Pool won't hold prime. I cleaned the filter & basket. Prime is slow to come up but then surges up and immediately drops back down.
check top seal make sure its not damaged if ok check to see if intake union is tight if still bad check impeller for debris
Sep 06, 2012 | Pentair 1.0 Hp Whisperflo Pump
I primed my pool but water starts shooting out of the top of the vent and it is not a constant flow it stops than gives a push of water . I have a small 12'x30
Okay finally found the question again...
not enough info:
are talking about the pump...to what vent do you refer to. ...never seen a vent on a water pump. Are you talking about the priming filler cap? It should be sealed! Check the gasket perhaps it fell off and you missed it when replacing??
May 27, 2012 | Pool & Spa
Pool pump wont prime when in pool mode, but will run in hot tub mode. Hot tub is 3 ft higher than the pool... is this a bad impeller? I think it may have run for a few hours without a prime , as I...
I assume that it pumps from/to the hot tub. If so, the pump is fine. Look for any air leaks in the piping/hoses from the connection in the pool to the inlet of the pump.
Gary
Aug 30, 2011 | Hayward 1.5 Hp Northstar High Performance...
Hello I'm trying to dismantle my hayward pump, but can't seem to able to remove the turbine... without forcing it too much....any tricks?
IT TURNS OFF TO THE LEFT, YOU NEED A 7/16 OR A 11 mm WRENCH TO HOLD THE ROTOR AT THE BACK OF THE MOTOR.. LOOK FOR THE NOTCH IN THE SHAFT UNDER THE SYNTRIFICAL SWITCH ASSEMBLY , BE CAREFUL NOT TO BREAK ANYTHING ON THE BACK OF THE MOTOR. REPLACE THE SEAL ! THERE IS A GUY SELLING SHAFT SEAL HAYWARD SUPER PUMP MOTOR REPAIR KIT & how to
ON EBAY .. HEY YOU .. PRIME THAT PUMP AFTYER ANY PUMP REPAIR !! THERE NOT SELF PRIMING UNTIL THERE INITIALLY PRIMED IN FIRST PLACE !!! AKA PUT WATER IN THE PUMP !.. IF I WAS OF HELP CLICK ON THAT (YES) BUTTON ON THE BOTTOM LEFT OF THE PAGE.. REMEMBER A CLEAN POOL IS A SAFER POOL .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA ..
Jun 11, 2011 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Not self priming itself. when it turns off the water pushes back out of the skimmer and pushes the basket up. it loses water and the pump cant re-prime itself.
PRIME PUMP, OPEN AIR VALVE ON FILTER. OR TAKE THE LID OFF YOUR FILTER AND SEE IF IT STARTS TO PUMP... YOU DO HAVE IT PLUMBED RIGHT? THE PIPE COMING OUT OF THE PUMP GOES TO THE FILTER !! I'M YOUR LOCAL POOL PUMP REPAIR GUY IN LONGWOOD FLORIDA. WHERE THE POOL IS ALWAYS OPEN
Aug 28, 2010 | Waterway Inground Pool Pump Champion No....
Can't get pump to prime
Is this the first time starting up this season? 1. Make sure pool level is up. 2. Check lid gasket and coat with silicone based lube. 3. Try to fill skimmer or drain line as much as possible. 4. If there ara two suction lines coming in then try to prime pump on just one of them. Gradually open second valve after prime is achieved. 5. If pump sits more than two feet above pool level then you will have to allow ample time for priming (it may take a couple of minutes).6. Make sure strainer drain plug threads are taped up. 7. If able to, try priming through another line.Good Luck
Apr 22, 2009 | Pool & Spa
My pool pump won't prime
If the pump is above the pool water level the it is unlikly that the tank will fill completely with valves open (which is ok).Most pumps are self priming and will pick up a prime with water level below suction inlet on strainer. Try starting on main drain again and slowly open skimmer line. Did you remove water from skimmer line and winterize(if in cold weather climate)during closing?.I know this sounds stupid, but make sure water level in pool is well into skimmer. If air situation remains after scspriggs' and these thoughts then prepare for a pressure test on skimmer line to determine location of leakage.
Apr 21, 2009 | Hayward 3/4hp Super Pump Inground Pool...
How to prime my Pool?
Prime is the term we use to state that the air has been mostly purged from the pump and the pump is moving water. When you have lost the prime, your pump is no longer pumping water through it. Sometimes it can be very difficult to regain the prime on the pump. This will tell you how to get the prime back in these difficult situations
Aug 27, 2008 | Intex 2500 Gallon Sand N Sun Pool...
Hayward 1 12 Hp Super Swimming Pool Pump Sp2610x15 Logo
165 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
