Question about Saeco Royal Cappuccino Espresso Machine
Selftest sign hi, i just got my saeco royal cappucino maker but when i switch it on it just keeps blinking selftest....? i can go to the menu but when i try to make coffee it won't work, the selftest sign just keeps on blinking...
  • akifcesur
    akifcesur Feb 16, 2013
    have the same problem as me, but I could not find a solution
  • 515 Answers
Try to make a cup of water(tea), press the button for water.
On the old Royal Cappuccino that are the button on the right down corner and the new machine had it on the upper right corner.
Hope this will help you.
/Mirran
Posted on Aug 17, 2008
Cappucino don"t work
Make sure that, Capucinatore is pushed in all the way And cover closed tight OR,S are in place, not crystallized Vinyl tube tight Milk cold and 2% and higher Container level with unit Steam present
Jul 08, 2013 | Saeco Royal Professional Espresso Machine
Our Saeco Royal Professional has been working well but has started ejecting steam out of the steam wand and cappucino spout.
Sounds like your machine needs a new steam valve plastic. Because it is worn the part is allowing steam to come out of the steam wand when it should be closed.
Hope this helps.
May 20, 2011 | Saeco Royal Professional Espresso Machine
The ventilate notification doesnt disappear on my saeco royal cappucino even i flushed with 4 loads of water
Please release hot water as well as steam by selecting both the selector switches( press hotwater button and open the steam knob).
Still you have the same problem,better you have to consult with service technician( there may be problem with boiler section)
Jul 24, 2010 | Saeco Royal Cappuccino Espresso Machine
Cleaning of saeco royal cappucino machine
The user manual shows you how to clean your machine. If you don't have it you can download it from the Saeco site:
http://www.saeco-usa.com/en/products/household-automatic-machines/1/automatic/0/royal-coffee-bar/17/royal-coffee-bar.html
Hope that helped! Thanks for using FixYa.
Apr 09, 2010 | Saeco Royal Cappuccino Espresso Machine
My Saeco Royal Cappucino gives hard noise, when "tamping". The grind goes to waste-basket. No coffee..
HI
There is a lever on the top of the door that has a + to the back and a - to the front. Pull the lever back 1 click to the front or - side. Your putting too much coffee in the brew unit and could break the brew drive.
Nov 30, 2009 | Saeco Royal Professional Espresso Machine
Cappucino setting won't pump
Hi
The steam solenoid is stuck. Have you descaled the machine? You might try that first, but if it has gone to long it might not work.
Mar 31, 2009 | Saeco Royal Professional Espresso Machine
Dregdrawer. miss.
Make sure the machine is clean of coffee grinds. Mine has a nasty habit of dropping them behind the dregdrawer instead of in it. Remove the central unit and give it a good clean. The dregdrawer should then slide back fully into the microswitch.
If this doesn't work, you've probably got a dud microswitch.
Nov 20, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal Digital Plus Coffee Maker, Espresso Machine
go into the menu and reduce the amount of water the machine pumps through
thanks
Coffee fix
Oct 26, 2008 | Saeco Royal Digital Plus Coffee...
Saeco cappuccinatore
also check that the milk is cold. temperature makes a big difference. also try pulling the "pin" on the side up and down to get the milk flowing.
Jun 10, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal Cappuccino Espresso Machine Logo
413 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
