Question about Agri-Fab Agri Fab Walk Behind Broadcast Spreader 125lb. Capacity, Modelno. 45 - 02102
Missing agitator and agitator hairpin cotter (R540-21 and R540-32), listed as drawing numbers 10 and 11.
In the agitator, how do i remove the clear plastic cam holder so i can replace those little cams so the agitator works again
If the clear plastic piece you are referring to is the center post cap, it simply lifts up. If the model number is correct, the cap is listed as item 23 in this parts drawing:
http://pcappliancerepair.com/model-display.php
Sometimes it can become gunked up with detergent and/or softener residue which can make it a little difficult get off. If it is on too tight, you can try reaching it with a pair of pliers and gently pull straight up on the handle portion. Make sure you do not damage the cap is it is required to provide and air gap to keep water from entering into the gearcase (transmission) shaft.
If you need further guidance, the following link explains how to access and replace the agitator dogs:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
The part number for the agitator dogs is included in the instructions I provided. For a little more, you purchase the entire cam assembly (which includes the dogs, the cam and the bearing) for about $8 to $10. It is listed as item 9 in the drawing I provided and the part number is 285809.
Replacement parts can be found at any of the following websites:
searspartsdirect.com
appliancepartspros.com
repairclinic.com
All these sites are reputable, offer great service and have competitive pricing, so shop and compare. The first three sites have helpful exploded view parts diagrams to assist you with locating and properly identifying the parts you may need.
If you have questions, please post back and let me know. I hope this helps you.
Jun 01, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Tip
Dirt Bike set-up.
When preparing a bike for a ride in the dirt, it is a good idea to pay attention to what holds your bike together. Cotter and Split pins can be made more secure with a zip-tie or wire.
Rocks, tree roots and even coarse grass can easily pull out hairpin cotters and split pins. To minimise this, place opening of pins to the least likely side to be impacted.
The Hairpin Cotter below, if placed the other way could easily be displaced if struck going over rough terrains.
Happy trails.
on Sep 27, 2010 | Motorcycles
Looking for diffirent pins to hold saddle bags on the factory ones keep coming off
What kind are on there now? The hairpin shaped cotter? You can go to a local hardware store and choose whatever would work.
May 18, 2010 | 2007 Yamaha Stratoliner
Bottom agitator spins but the top piece is loose like something is missing. The top piece of the agitator and the soap despensor just come right of and spin freely... there is nothing holding it on. Looks...
Whirlpool has a split agitator design. The upper portion is called the auger, while the bottom is called the agitator. Between these components is a agitator cam assembly. This problem is commonly caused by worn agitator dogs on the agitator cam assembly. The following link explains what the dogs are and how to replace them:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The part number is included in the link provided. You can purchase replacements at appliancepartspros.com for about $5. For a little more you can purchase the entire cam replacement kit, which includes the cam, the thrust bearing, and the dogs. If the model number you listed this under is correct, the part number for the kit is AP3094543 and sells for about $11.
NOTE: You can refer to the excellent exploded view parts diagrams the web site has to offer for assistance. Whirlpool also recommends the application of a little grease on the thrust washer. The part number for their recommended grease is AP3098553.
If you have any questions about this repair, please let me know. I hope this helps you.
Nov 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washing machine Model 110.4767292, squeaky agitator
I can't seem to get the Sears Parts site for your washer model number.
Can you verify that it's correct?
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
In the interim, here is the Whirlpool Service manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Following is a procedure for removing the agitator(s) on top load washers.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136
If you take the agitators out, I'd make sure that any "gunk" is cleaned off and check the splines inside the agitator and on the transmission agitator shaft.
It's probably not a serious problem.
Nov 04, 2009 | Kenmore Washing Machines
Missing part for 12" "Craftsman" band saw.
Go to: Searsparts.com and list the model number from the machine. The have drawings of the unit (exploded) that list all of the parts used, although on older units, some of the major components are not available any longer. Hope this helps.
Oct 19, 2009 | Saws
Where does the manual clutch cable mower deck spring connect to on a Craftsman YS4500?
It should connect on top of the idler pulley on the idler arm. The bolt is extended and the spring hooks over it with a 'hairpin' or cotter key through the hole in the end to hold it on.
Oct 09, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Agitator will not spin on last cycle
try replacing cotter pin first.if that dont don't work try to get a used timer to try before buying a new one.hope this helps!!!!
Sep 07, 2009 | Whirlpool Washing Machines
Dvd stuck in recorder
Power of and some players got small hole next to draw for hairpin to open manual some disk is from diffrent regions code 1 or 2
Mar 20, 2009 | NexxTech EDP3110
My machaine no longer takes the softner when on rinse .
open the soap drawer when softener should be taken and see if there is a jet of water into the conditioner box. if not, a common cause is the jets in the roof of the box blocked. poke a hairpin in the holes in the roof of the box and see if this cures the problem. if the rinse water does come in, this means that the actual water valve is ok
May 18, 2007 | Hotpoint WF645 Front Load Washer
Agri-Fab Agri Fab Walk Behind Broadcast Spreader 125lb. Capacity, Modelno. 45 - 02102 Logo
66 people viewed this question
Top Agri-Fab Garden Experts
Roland W VanLue
Roland W VanLue
Paul Sikkema
Paul Sikkema
Joseph Mueller
Joseph Mueller
Are you an Agri-Fab Garden Expert? Answer questions, earn points and help others
