Question about Samson Technology Zoom H4N Handy Digital Portable Recorder with Two BONUS Instrument Store Dynamic Cardioid Microphones for 4 Track Recording Accessories and CUBASE LE5 Software
I accidentally dropped my Zoom H4N mic first onto concrete resulting in the mics bending out of shape and one piece ripped off the socked. Where can I get this fixed?
I have a Peavey XR 8600 PA, I have tried adding an external vocal effects module into a mic line but it drops the output volume of the entire PA by about 75%. Any ideas why this is?
Well, I would say it isn't dropping the level of "the whole pa", it is just dropping the level of the input you have plugged the fx into. Check the settings on your fx unit, there are usually input, output and mix controls that are independant of "the pa" and affect the amplitude of the signal going into your mixer from the fx unit.
Nov 01, 2017 | Peavey Music
Tip
When I turn on my Zoom H4n, it says no card
to solve this problem you will need a screw driver! disassemble the unit and reassemble, the card connectors some times they move if dropped
on Jun 06, 2011 | Zoom H4 Handy Recorder
Korg Microkorg XL Vocoder Not Working (No Sound)
Check the mic and connections all through its input into the unit. I would check the cartridge of the mic for continuity for the reason that (I think but not 100% sure) on this model, I think there has to be sound at the mic or it does go silent in vocode mode. This is how it digitizes the mic and keys together. The played keys cannot put onto pitch the sound it is NOT picking up at the mic. I think there is a problem with the mic.
Mar 07, 2014 | Korg Micro Microkorg Xl Synthesizer...
Add to the question of hooking up 4 mic channels to a single compressor: I have a samson 16 channel mixer ( 8 mic inputs ) and a 4 channel compressor. I want to be able to use the compressor to compress 4...
Is there some reason you can't use one of you're aux sends for the compressor? You can then dial up as much compression as you want on each individual instrument. If you're determined to get the 4 mics into one compressor input.... Only thing I can think of is use TRS insert cables on the 4 mic channels - tie them all into one compressor input through a small patch bay or similar. Then bring your return from your comp to a 5th channel. Impedance matching is completely out the window so no promises on results.
Sep 27, 2012 | Samson TXM16 16 Channel Powered Mixer,...
Zoom h4n won't connect as mic via USB
What I figured out - simple. Plug your usb cable all the way in. That's it. Did I guess it? ;)
Apr 12, 2012 | Zoom H4 Handy Recorder
Can't get order form for below item
The zoom H4 is out of production. You can get its successor the Zoom H4n here:
http://www.sweetwater.com/store/detail/H4N
Jul 17, 2011 | Zoom H4 Handy Recorder
Hi im using the carlsbro gd 4000 in a 3 piece rock and roll band we are using an oldmike shure c606 and we cant get any volume out of the mike and its distorting the vocals we dont know whether the p.a.s...
Proper placement of mics versus the speakers of a PAS is important to avoid feedback. Your speakers need to be toward the audience from where the mic is. If the mic can "hear" the speakers you will likely have feedback. The mic should work even though it is a consumer grade mic.
WORD OF CAUTION: There are a LOT of fake SM58 microphones being sold... even on Ebay... SOME are fairly high quality and others are not.
Mar 31, 2011 | Music
When I turn on my Zoom H4n, it says "no card" even though I have a card in it. Why is this? How can I fix this problem?
My zoom h4 will not turn on at all....not with new batteries or the AC adapter.....any suggestions? Worked fine last time used.
Feb 13, 2010 | Zoom H4 Handy Recorder
Samson Technology Zoom H4N Handy Digital Portable Recorder with Two BONUS Instrument Store Dynamic Cardioid Microphones for 4 Track Recording Accessories and CUBASE LE5 Software Logo
234 people viewed this question
Top Samson Technology Music Experts
Michial Gueffroy
Chris Larocque
DROPNDEAL
DROPNDEAL
Are you a Samson Technology Music Expert? Answer questions, earn points and help others
