Question about Thermador MASTERPIECE ME302EP Stainless Steel Electric Double Oven
Stuck in pause mode - Thermador MASTERPIECE ME302EP Stainless Steel Electric Double Oven
  • dawnkeller May 29, 2011
    This is a brand new oven and it is the first time we are trying to use it. We have turned the power off and are currently waiting the 15 minutes as you have suggested. How do we check the oven temp sensor?
    This is a brand new oven and it is the first time we are using it. We have turned off the power and are waiting the 15 minutes you have suggested. How do we check the oven temp sensor as you have told us to do.
  • 4,323 Answers
Hi
Turn off the power to the oven and unplug it for 10-15 minutes. Alternatively turn off the breaker to the oven for 15 minutes and check. If the oven is still stuck in Pause mode then check the oven temperature sensor for resistance of 1050-1120 ohms, if the it reads outside this range then replace the temp sensor else you would need to replace the control board. Hope this helps... Please post back if you need more information.
Daniel
Posted on May 29, 2011
  • Daniel Scott
    Daniel Scott May 29, 2011
    To check oven temperature sensor you would need to disassemble the oven and use a multimeter to check the resistance. As it is a new oven and under warranty I would suggest you to call the Thermador tech for any repair/replacement. The repairs & replacements are not charged during warranty period.
    Daniel
Omega double wall oven model E88 stuck in demo mode and won't disable
Suggest you contact the manufacturer. There is little information on the web
Aug 04, 2016 | Ovens
Self-clean-mode not working, I get the "door" error message
are you sure it is an auto lock door and not a manual locking type .
Oct 22, 2015 | GE Ovens
Eecrolux combination wall oven / microwave is in demo mode model# ew30mc65jb
Good Morning Rolf, thanks for your post!
Based off the information you have provided your Electrolux wall oven/microwave combination is stuck in demo mode. The best way to remove demo mode from your wall oven/microwave combo is to hold the oven light button and the on/off keys at the same time and you should be able to toggle in and out of demo mode. Hopefully this is helpful. -Matt
Mar 09, 2015 | Electrolux 30" Built-In Double Electric...
Co1 erroe code distinctive wall oven what is problem
According to your model number this code means Shorted or stuck key. Your keypad needs to be replaced. Good Luck
Aug 07, 2014 | Dacor Distinctive DO130 30" Single...
Stuck timer
my acoustic solutions tv is stuck in standby mode its the timer because it com on the other day how do i turn timer off
Jan 02, 2014 | Electrolux Ovens
My oven is messed up
OK, here is the deal. Your over has a built in cycle timer for clean mode. Most will not let you cancel the cleaning mode. You need to let it completely run through the cleaning process and cool down time before you can use it again. , But if you unplug it and wait about 2 hours then plug it back in it should be cooled and the computer reset.
Jul 31, 2013 | Ovens
Westinghouse oven door locked
if you mean it is in stuck in the clean mode , then try starting the clean mode again then hit cancel , let me know how you make out
Dec 10, 2011 | Ovens
Gaggenau EB944-110 Pyrolytic oven stuck in some kind of mode after power outage. Oven worked perfectly but there was a mains cut. After restoring power it appears to be stuck in some kind of strange...
Yes this could be the problem. If you can't set the timer to manual mode the oven will not work. Turn the oven to on so that when power goes to it you will see the oven indicator light come on. Play with the timer buttons until the oven indicator light comes on. If it won't work you probably need a new timer.
Feb 11, 2011 | Ovens
Jenn-Air gas wall oven some how got stuck in ''Sabbath'' mode and unable to reset.
ok it happens / so to enable the Sabbath mode 1 open the door. 2 press cancel/off. 3 press the number pads 7&8 and 9 , in that order. 4 press Number pad 6 . 5 press start. "sab and on" will appear on the display ..( now to disable the sabbath mode .}. ( repeat the steps above to disable the Sabbath mode. " Sab and off" will appear on the display .. there now that wasn't too tuff was it .. mm hope this helped ..
Jul 15, 2010 | Jenn-Air Ovens
Oven stays in warm up mode
does broil work? if broil works and bake does not you have a bad bake element. let me know how it goes
Jun 14, 2009 | Frigidaire Ovens
Thermador MASTERPIECE ME302EP Stainless Steel Electric Double Oven Logo
Top Thermador Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a Thermador Oven Expert? Answer questions, earn points and help others
