Question about Dell Computers & Internet
My security monitor is black and has a message that says I need to change the input timing. How do I do that?
    Guru:
  • 767 Answers
When i shutdown my computer after that when lcd goes black then at that time a message shown on the black screen that "no input signal" and also glows little bit light with this message continuously.
Your monitor may have an option to set it as "manual" or "auto". If set in manual, you will have to turn off the monitor power switch each time. If it has the "auto" setting , it should shut off or "go to sleep" when it detects no input signal.
Oct 18, 2014 | Samsung SyncMaster 713BM 17" LCD Monitor
Normal behavior. Most of the lcd monitors ( not all) show this message. You can safely turn off the monitor once you shutdown your computer.
Oct 17, 2014 | Samsung SyncMaster 713BM 17" LCD Monitor
Why is my dell inspiron 531s stuck on black screen with input not supported message?
Start pc in safe mode and try to change resolution.
Then update the graphics driver.
May 06, 2014 | Dell Inspiron 531s Desktop Computer
Change input timing for monitor when i can't do anything
Hi Austin
it sounds as though you have a problem with your graphics card drivers and your tv will not accept the lower resolution. Do you have another screen that you can connect to prove/disprove my theory? If your tv will not accept the lower resolution input then you need another screen to enable you to sort it out. Hope this is helpful.
Feb 19, 2013 | Computers & Internet
Input error
If you are getting the no input or out of range message on your screen then you will need to do one of the following:
No input
If you aren't getting signal then it means that your graphics card has failed. Make sure the video connectors are secure. If all connectors are in place and you still don't get a signal then you will need to:
Connect the video cable to onboard graphics if you were using a graphics card. If you're not using a graphics card then it means that your motherboard vgraphics has become faulty. You will need to consult a repair technition.
Out of range message
If you are getting this message then you will ned to change the refresh rate on your monitor. To do this boot your computer into safe mode by pressing F5 during boot up. Then right click on your desktop and click on properties. Then click on the Settings tab and click Advanced. Once in the Advanced settings click on the Monitor tab. Then all you will need to do is set the refresh rate down to a lower setting like 60 Hertz.
Feb 19, 2011 | Acer X183H 18" Monitor
How to change input timing without a monitor
you will not able to do it without a monitor. you'll need to get another montior in order to change the settings on computer. you need to change the resolution on that computer. sounds like the resolution is either too big or too small that it will not display it.
Oct 17, 2009 | Computers & Internet
Black screen with message about no input signal
might be something wrong with your monitor's data cable
May 21, 2009 | Sony SDM-HS95P/B 19" LCD Monitor
No DVi input, then computer goes to sleep
Hi publicworker,
I had a similar problem whereas my monitor went to sleep mode after a few minutes. I'm running an HP LP 2065 in dual mode with another HP flat screen. However, I did resolve the issue after resetting the output settings.
How to do that:
  • right mouse click on the desktop
  • select graphic options
  • output to
  • extended desktop
Maybe some changings/modification will help you too.
Stefan
Jan 31, 2009 | HP 2025 20.1" Flat Panel LCD Monitor
Monitor Blacks out 'input not supported'
i think the probelem is monitor resolution out of range . try the system resolution changes and connect the monitor then the issue is solved 80% or other problem is monitor hardware damages cheack the whole hardware components
Nov 04, 2006 | Acer AL1717 17" LCD Monitor
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
