Question about Hotpoint Dryers
I am trying to installl a 4 wire cord to a 3 wire setup but not where where to ground on dryer
    President:
  • 3,074 Answers
Http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
Posted on May 29, 2011
4-prong to 3-prong Power Cord Conversion.
On a 4-prong power cord you have 2 hot wires, one neutral wire, and one ground wire. On a three prong cord, you have 2 hot wires and one neutral/ground wire. The difference is the on four prong the neutral wire goes to electrical neutral bus in the breaker panel and the ground wire goes to the ground bus in the breaker panel. Since the neutral and ground buses, although separate, both go to physical ground, on a three-wire setup, you are just putting the neutral and ground wire together, Most dryers actually have a place at the pigtail connection to do just that.
Sep 09, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
How to ground a MDE6700AYW dryer after changing to a 3 prong cord
Hi fievelsgal21...
Go to the following webpage and it will show you what and where to connect the ground wire when converting from 3 to 4 wire or 4 to 3 wire.
Please rate me
Bud
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Sep 28, 2012 | Maytag Neptune MDE6700A Electric Dryer
What do i do with the ground wire on the dryer. i changed from a four prong dryer cord to a three wire prong
Good day,
Actually nothing. The center wire in the three prong setup works as both the ground and neutral.
Look here.
Old 4 wire.
New 3 wire.
Make sure the grounding strap is in place.
Jul 15, 2010 | Dryers
I am changing the 4 wire on my 2 yr old maytag dryer to a 3 wire to fit the recptical in my new house. Other then the 2 hots and 1 neutral connection, my dryer also has a white ground wire off to the side,...
So you have an, ahem... problem....you have a Code compliant dryer (with it's 4 wire cord and plug)....and have moved into an older home that is not Code compliant (with it's 3 prong receptacle outlet)....and this is fairly common.
At this point - you have two choices....replace the wiring from the dryer's breaker to the receptacle with all new 8/3 with ground romex (it more then likely only has 8/2 with ground now)....and replace the receptacle with a 4 prong grounding receptacle to match your dryer's cord....OR - as an alternative - you can replace the cord on your dryer with a 3 prong cord to match the existing dryer receptacle outlet.
Out of the 2 choices....the first one will bring the old wiring in the home up to current Codes (all NEW homes must have this 4 wire/4 prong set-up per Code...but older homes are grand-fathered)...but it is clearly the most involved, time consuming and most costly approach...and it is recommended only an electrician do this work. If this approach is taken....your dryer cord can stay as is...it will now fit the new receptacle outlet with no modifications.
The second approach - is to pick up a 3 wire 3 prong cord at your local hardware store to match the existing 3 prong receptacle.....and replace the 4 wire cord on your dryer with it. Although this is the least desireable - it is an allowed approach because this is an older home with existing wiring. This is a much less involved approach...all you need to buy is the 3 wire dryer cord (they come all ready to go) remove the 4 wire cord and install the 3 wire cord to your electrical connections at the back of the dryer. Hopefully...when the 4 wire cord was installed on your dryer, the ground strap wasn't removed completely (this is a metal strap that will connect the white wire to the metal frame of the dryer)...because now you will need to re-use the ground strap. For more on this....see the images of the differences of the 3 wire and 4 wire dryer hook-up at:
http://www.applianceaid.com/general.html#3to4
NOTE: the only real difference between the 3 wire cord and the 4 wire cord is now the white neutral and the ground are kept seperate in a 4 wire..the green ground will connect directly to the dryer frame....where in a 3 wire there is no seperate ground wire - ground and neutral are one and the same...the ground strap connects the frame to the white neutral. The 4 wire permits a better safety measure...in the event of an electrical problem (ground fault) in the dryer...the fault now has a seperate path to your panel's ground...and less chance of a shock from touching the metal frame of the dryer.
The choice of how to proceed is up to you....if you go with completely updating the dryer wiring from the breaker outward...I recommend an electrician do this work for you (it's about an hour's work...plus materials). Then your exisiting dryer's 4 wire 4 prong cord can stay as is....the electrician will install a 4 prong receptacle made to fit your cord.
If you go with simply replacing the dryer's cord....changing it to a 3 wire so it will fit the receptacle...make sure the ground strap is re-utilized as seen in the images at the site above.(also make sure all work is done with the dryer breaker (or fuse if a really old home) off before starting any work. If you change the cord yourself...make sure to reconnect in exactly the same manner as the previous cord was connected...(make a note on paper or take pictures so that there are no mistakes)..and that you tighten the nuts securely to the posts once the wire lugs are on them. Where you state you do not have a background in electrical work...you can have an electrician change this cord for you...(typically in under a half-hour)....or you can do it yourself - by carefully following the pictures.
The choice is yours...if it was me - I'd change the wiring from the breaker outward...making the older home meet today's current Codes and be complaint for this dryer..and then you wouldn't need to change a thing on the dryer....but you can go either way....Codes allow this grandfathering in older homes with existing wiring.
Feb 19, 2010 | Dryers
3 wire to 4 wir
Feb 11, 2010 | Kenmore 94802 Front Load Stacked Washer /...
How to hook up a 4 wire plug to a Maytag clothes dryer model LDE8824ACM with 3 wire connecters.
Feb 09, 2010 | Dryers
Need to replace existing three wire plug with new four wire plug. there are only three terminals to connect to. what do i do?
Based on your description....you have a Code compliant dryer (with it's 4 wire cord and plug)....and have moved into an older home that is not Code compliant (with it's 3 prong receptacle outlet)....and this is fairly common.
Feb 08, 2010 | Dryers
Roper Dryer
Changing from 3 to 4 wire hookup on a electric dryer:
Power cord help for 3 & 4 prong dryer cords
This is an example of a three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
This is an example of the 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Mar 02, 2009 | Roper Dryers
Wiring 4 wird dryer plug to 3 wire 10/3 for 220 welder
the four wire plug seperates the neutral and ground. the three wire just piggybacks the ground to the neutral. so just get a three wire cord that fits the 220 plug on the generator and install it on your dryer make sure to attach the ground correctly for your three wire setup
May 07, 2008 | Dryers
I have a 4 wire dryer plug and a 10/3 wire that I want to connect to a welder that is 3 wire. No idea how to splice the wire as the dryer has a bare ground. welder is 220 and 25 amp. help.....
get a 3 wire cord and install it on your dryer is the easiest way. the four wire setup removes the ground from the neutral.
just piggyback the ground to the neutral for your 3 wire setup
Dryers Logo
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
