Question about Refrigerators
Danby refrigerator M# DAR452BL does not run - does nothing. PTC starter part #432.45 and Overload protector part # 432.44 have corroded contacts, and 432.45 appears to be broken inside where it plugs into side of compressor. Where can I get these parts, and what is approximate cost? Thanks
I had a similar issue with this fridge, i put in a supco 3 in 1 (relay, overload, capacitor) and it's running just nice now.
http://www.youtube.com/watch?v=3MYNecMtsFQ
Posted on Jul 15, 2012
I have the same model and am needing parts for it. Did you have any luck finding a parts house?
Posted on Aug 08, 2011
  • crmpacer Aug 08, 2011
    I have a similar model and am in need of parts. Did you ever find a parts house?
BCFA27B need replacement for QP2-4.7. i think it's the starter.
Shop for Refrigerators need repla... on Google
Oasis 036056?001 R...
$18.55
DrinkingFoun... Refrigerator Compressor S...
$25.32
Sears Parts D... QP2?4.7 ' Danby Refrige...
$15.75
Google Trusted StoreAppliance...
Danby QP2?4.7 Refrigerator St...
$17.50
Google Trusted StoreSpeedy A... Oasis 036056?001...
$10.45
PittsburghWat... Search Results
    uxcell 4.7 Ohm 1 Pin Refrigerator PTC Starter Relay Black
    www.amazon.com/...Refrigerator.../B00N3WFW5K
    Amazon.com, Inc.
    Rating: 4.8 - ‎63 reviews
    The original starting part QP2-4.7G is equivalent to this one. the 4.7G .... the PTC, so at this price, buy a spare because in year or two, you'll need another one.
    Amazon.com: Questions And Answers: Will this replace a QP
Jan 01, 2016 | Refrigerators
Compressor not comming on. The frezzer door was left open and now the compressor dosn't work. could it be Overload Protector?
yes it definitely could be the ptc overload relay on the compressor as it was overworked with the door left open
Aug 23, 2011 | Refrigerators
My fidge is a kenmore medel 25357685790 my starter ptc looks to be burnt so i decided to replace it but it includes three pieces the capacitor, starter ptc and overload. the new parts only have a diffrent...
HI,
I use ERP 410 (relay capacitor and overload) Get it at your local Appliance Parts Store
Very easy to install
Leo Ponder
imufo2
Please vote for me if this helps.
Aug 02, 2011 | Refrigerators
Sounds like overload protector issues. cuts in briefly and cuts out.
touch the compressor if its red hot its knackered sorry to say.... needs regas ..
Feb 25, 2011 | Danby Refrigerators
Magic Chef Model #MCBR360S just quit working all of a sudden. Any suggestions for solving this problem would be appreciated.
Check the PTC starter component. It is a small ceramic disc inside a plastic housing, attached to the side of the motor. If it is an open state, the motor will not start, If it is shorted, the motor will start, but the overload will trip in just a few seconds. The resistance across the PTC should be around 7 ohms at room temperature. I recently had the same symptoms on my MCBR440. The PTC had some arcing on it. A simple cleaning of the surfaces by scraping with a sharp knife and then reassembling it did the trick.
The resistance across the thermostat in it's running position should be zero. The resistance across the motor overload protector should be zero. The resistance across the motor windings (start, and run) should be just a few ohms. MAKE SURE YOU DISCONNECT THE POWER cable before attempting to measure the resistance of any of the electrical components. All of the wiring is easily accessible from the rear.
Lightfoot_55
Dec 15, 2010 | Magic Chef MCBR440 Compact Refrigerator
Not cooling
your ptc overload on your compressor has gone out and needs replacement,locate the compressor and unplug the overload off the compressor and take it to an appliance parts place and purchase the correct replacement ptc overload and plug it back in and your good to go
Jun 18, 2010 | Hotpoint HSS25GFP Side by Side...
Danby dkc645bls cools once, then wont kick back on when it starts getting warm.
Your compressor is not starting and in your case you have a thermal induced problem.
I looked for about an hour for parts below on-line with little success. (Danby sourced)
You have 3 possibilites as far as what is causing your problem.
1. PTC start relay / Klixon (2 parts as an assy)
2. Run capacitor
These are not expensive parts even if you ordered all of them.
The sad thing about it is the parts are probably available at your "local" appliance parts store.
If you can look at your compressors' label and copy down the
Manufacturer (i.e Embraco, Mitsubishi Elec, Panasonic etc) and ALL numbers (including LRA)
you can take that info to the local appliance parts supply and walk out with the parts in hand.
Otherwise your looking at calling Danby (number below) and telling them you need a PTC Start relay / Overload and run capacitor.
1-800-263-2629 (US)
Thanks for using FixYa
Oct 16, 2009 | Danby DKC645BLS Compact Beverage Cooler
Danby Refg PTC Starter
you can replace with an supco 3 n 1 for 1/3 1/4 (if run capacitor is used)
or use the combination relay/overload for 1/4 1/3(if there's no run capacitor)
if you need any additional help please e-mail @ hvac.tech7872pr@gmail.com
Apr 28, 2008 | Refrigerators
Refrigerators Logo
195 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
