Question about Tecumseh Garden
When the tiller is under load it loses power and dies? it runs fine when in idle but when engaged is when its at a loss of power
DickCanFixIt
  • 948 Answers
SOURCE: Friend layed his 2004 Vulcan over today..after
Sidestand switch broken or moved? If the switch does not detect the sidestand is retracted it will kill the engine when it is put in gear.
Posted on Apr 04, 2009
SOURCE: Honda mini tiller stalls
Sounds to me like your main fuel jet is clogged if it will idle (different fuel supply) but not run with open throttle. When you open the throttle the engine gets more air and not enough fuel and quits.
Solution: Open (disassemble) the carburator and spray carburator cleaner through every orifice. Make sure you actually get cleaner THROUGH all holes. You've no doubt got fuel "varnish" in the jets from letting the equipment sit idle for long periods.
Prevention is the key: Always use a fuel stabilizer (Stabil) in your fuel. Mix as described on teh package for the "long term storage" concentration — generally double the dose of "normal" concentration and you'll minimize future problems.
Posted on Apr 09, 2009
rcampsr
  • 90 Answers
SOURCE: Troy Horse tiller engine stalls after warm up under load
Has any work been done on the engine? Especially the carburetor? There is an insulator piece between the engine and carburetor to reduce the heat from the engine. Also the muffler has a screen inside of it, if you have the two piece muffler on the engine that gets plugged up and the motor looses power. There are also two small feed tubes that hang down inside the fuel tank that also get gummed up and they also will cause the same symptoms. Is the motor burning any oil yet? This will happen when the rings get worn out. If the valves get bad the motor will be hard to start due to lower compression. There could possible be a mechanical cause from the cam shaft if it lost oil to it for some reason and caused a lobe to round off, but this would be prevalent at all times. You can put a compression gage on the engine to check the compression by pulling the cord and rotating the engine over three compression cycles to get a reading. Good Luck, RAC
Posted on Apr 18, 2009
  • 45 Answers
SOURCE: Ryobi Model 65020 gas tiller dies when engaging the throttle
sounds like you need to adjust the carburator
Posted on Apr 29, 2009
  • 138 Answers
SOURCE: Craftsman tiller engine dies when I try to engage tines
tilt the back of the tiller up and check for a rock or stick wedged in between the tines and the shield
Posted on Aug 21, 2009
New tiller makes grinding noise when trying to run tillers
if it has a clutch
most small units just run a dog that you engage with a swift motion at low idle speed of the motor
have the tillers free above the dirt so they can turn with out any load to inhibit the dog engagement
May 20, 2015 | Garden
Galant vrg gdi 4g94
That is pretty much normal. When the AC engages it's compressor it triggers the idle sensor to increase idle to compensate for the huge load that an AC unit puts on a vehicle. If your AC is producing cold air, approx. 40 degrees on high, then it should be ok. Power loss is all part of the program with AC. It takes much more noticeable power to run an AC unit on a vehicle, and especially a 4 cylinder. Ever see your house lights dim a bit when you turn on the Home AC central air? :.) Every item under your hood connected to your engine steals power from the engine. The AC is the king of all takers of power.
Jun 28, 2013 | 1999 Mitsubishi Galant
Honda rotor tiller dies under load but runs fine other wise
Its running lean. There might be a small amount of water in the bottom of the bowl that gets sucked up when the motor is under load and requires more fuel.
There is a drain plug on the side of the bowl. Use a 10mm wrech and remove the plug. Catch the fuel and inspect for water. If water is found drain system and refill with fresh fuel. If no water is found then a carb rebuild is needed
Sep 25, 2012 | Garden
Machine runs fine for approx 20 mins. Thereafter when drive is engaged will run for 20 seconds before engine starts to die .If drive is disengaged engine will idle fine until drive is engaged and problem...
your engine is starving for fuel supply. Remove fuel line from carburator. If fuel flows from line remove carburator and clear obstruction from needle valve and insure that fuel is not being restricted. If fuel flow is slow: clean and rebuild if necessary the fuel pump (if applicable) or follow fuel line to fuel tank and remove blockage: in line fuel filter fuel, tank strainer, or on and off valve that may be choked off.
Mar 02, 2011 | Mantis 4-Cycle Tiller
Ford 460 loses power then dies. Starts back up. Idles fine.
It sounds like you might have a clogged catalatic converter on the exhaust system.
Apr 23, 2010 | 1999 Ford Super Duty F 450
My tiller completely dies when the tines are engaged in the soil.... it runs fine with tines engaged when not touching the soil. what's the problem?
The last time I had that problem, the governor spring was broken. Replaced it and everything was good. Look to see...Lee
Sep 08, 2009 | Garden
Blades turn slow and dies out under load
Is the engine running good or misfiring with no load ? Dieing under a load maybe a sparkplug or bad fuel you possibly have water in the fuel ... as far as your tines not turning fast enough this sounds like drive belt related
Aug 08, 2009 | Mantis 4-Cycle Tiller
Apr 25, 2009 | Ryobi Cultivator
Mar 22, 2009 | Craftsman 8.50 Torque Rating Dual...
Garden Logo
108 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
itsman
Rick Oudette
Rick Oudette
Level 1 Expert
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
