Question about Ovens
Need an oven thernostat - was part AP2836675 - could be Bosch 486945 - or a substitute part that would work
Tip
Common heating faults with Bosch HBL 455 Stainless Steel Electric double oven
For all Free appliance repair videos visit our VIDEOTUTORIALS 1, If the Bosch fan motor in the back of the oven is going round andthe temperature light is on (normally little red light), but there is no heatthen you will probably need a new oven element, these are generally very easyto fit and readily available from our website these can be tested with aelectric meter.
To gain access to the BOSCH element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your BOSCH fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven thenyou need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBL 455 Stainless Steel Electric...
Tappan oven tgfs26cba , oven does not light when turned on. control panel says it's working. glow plug glows hot. gas inot fed. was informed wife had taped oven vents to stop mice ??? could this have over...
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 04, 2010 | Tappan Ovens
Tip
Common heating faults with Bosch HBL 5056 double oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Bosch fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BOSCH element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BOSCH fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBL 5056 Electric Double Oven
Tip
Common heating faults with Bosch HBL8750UC double oven
on Jan 19, 2010 | Bosch HBL8750UC Electric Double Oven
Hbn7052gb/05
If you have a BOSCH electric Cooker or Fan Oven which isnot heating it could be one of the following problems.
1, If the fan motor in the back of the oven is goinground and the temperature light is on (normally little red light), but there isno heat then you will probably need a new oven element, these are generallyvery easy to fit and readily available from our website these can be testedwith a electric meter.
To gain access to the BOSCH element you will have to remove the back platefrom inside the oven. Once removed you will see the fan and element,if you look closely at the element you will probably see a small holeburnt in it where it has blown. Sometimes however there is no evidence of afault but the element is open circuitie: broken inside the element casing, either way it will need replacing. Some elementswill are fixed from inside the oven and some are held in place by nuts from therear of the machine.
2, If your BOSCH fan oven is getting warm but takes avery long time to cook or is burning the food more on one side than the other,then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into theoven then you need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have theopposite problem ie: your oven is over heating and burning everything then youwill need to replace your BOSCH oven thermostat
4, A quite commonand easily overlooked answer is if your BOSCH oven is not working at all ie: no heatand no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Jul 30, 2009 | Bosch HBL 5032 Electric Single Oven
Tip
Common heating faults with Bosch HBL3420UC Electric single oven
on Jan 19, 2010 | Bosch HBL3420UC Electric Single Oven
Tip
Common heating faults with Bosch HBL 5032 single oven
on Jan 19, 2010 | Bosch HBL 5032 Electric Single Oven
Tip
Common heating faults with Bosch HBN 430560B / 430520B single oven
on Jan 19, 2010 | Bosch HBN 430560B / 430520B Single Oven
Tip
Common heating faults with Bosch HBL 745 single oven
on Jan 19, 2010 | Bosch HBL 745 Stainless Steel Electric...
Ovens Logo
75 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
