Question about Husqvarna Garden
Cordless mower model Master 43RC is dead. Batteries OK, fuse OK but no juice to the motor. Any ideas? Thanks, Mike
chillmaster
  • 104 Answers
SOURCE: Fedders window model A6Y12F2B "New Unit",,only
Take it back to the store. Manufacture defect if it died after only 10 days. Attempting repair or disassembly will probably void warranty.
Posted on Jun 23, 2008
  • 68 Answers
SOURCE: My fredge rm 2652 not working
You need to check your fuses on the fuse panel inside your coach. The frig will not operate on gas or electric without 12 volt power to the frig circuit board.
Posted on Mar 19, 2009
buffalonyman
  • 1865 Answers
SOURCE: my 24 volt 1200 watt cordless mower abruptly
You'll need a DC voltmeter and have to start checking the circuit from the battery to the motor
Posted on Jul 29, 2009
  • 7993 Answers
SOURCE: The calculator is dead. Batteries are OK.model
You can reset the calculator:
Turn the back of the calculator towards you. Extract the top left rubber pad on the back of the calculator and use a paper clip to press the Reset button. If that does not restore the calculator to health, you should perform the dagnostic tests.
The following procedure valid for the 48G should work for the HP48GX.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Relaese the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterwards you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  4. Release the [ON] key
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a hight pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.
Hope it helps.
Posted on Nov 07, 2009
TechnoMarine
  • 132 Answers
SOURCE: Uniden Atlantis model#atlw27 057782. Unit dead
probably battery contacts or dead board.
Posted on Jan 13, 2010
Testimonial: "Thank you to the Tech team. Have sanded battery contacts with 1500 paper; no change. Rick"
Keeps stopping and I have to keep resetting the fuse switch. Battery feels like it's overheating. Any ideas why? Fuse? Switch? Something else?
Reese, with the battery disconnected look under machine to see if anything is wrapped around the blade and shaft that could be working the motor hard, electric mowers normally can only cut half the height of grass as a gas mower. Make sure wheels are not set too low and overworking motor.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 20, 2016 | Garden
Homelite 24v cordless will not run
turn the motor by hand see if it moves look for blown fuses check for voltage with a meter
Apr 25, 2012 | Garden
I had my car stored for 6 months, battery disconnected and when I reattached it inside lights etc. came on but not enough juice to turn it over. Attached a battery charger which charged the battery to 80%...
newer cars need to see at least 10.5 volts to operate. A new battery has 12.6v. fusses would not have blown while you were charging the battery unless you hooked up the connections wrong. usually if you saw a lot of sparks than i would say it was a fuse. but in your case, it just sounds like you need a new battery. when you store a battery again try and recharge it every month. once car batteries go completely dead they will sulfate and nothing can bring them back. diesel and watercraft batteries are the only deep cycle batteries and they can be run to nearly no charge and be brought back. hope this helps
Apr 03, 2010 | 2007 Chevrolet Blazer
The phone is dead!
Have you tried it with other batteries? The handset will be dead on the cradle regardless of juice from the wall, if the batteries are missing or no good. This unit eats batter juice quickly if left off the cradle for any length of time.
Jul 06, 2009 | Doro 550S Twin Cordless Phone
Changing batteries in black and decker cordless lawnmower
You can find parts information and exploded views for your mower here. You'll need to pick the series mower you have from the list. The service site's home page is here. At the bottom of the center pane is box where you can enter your model number to find the manual. With the views they give, you should be able to get the mower apart to replace the batteries yourself. Good luck on the project!
Apr 17, 2009 | Black & Decker Garden
Feb 03, 2009 | Dometic RM2652 Refrigerator
My phone goes dead while dialing
It might sound obvious but have you checked that the batteries are charging properly?
Can you receive calls OK?
Jun 25, 2008 | Panasonic KX-TG1033S Cordless Phone
Garden Logo
111 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
