Question about Toshiba 43H71 43" Rear Projection Television
RED Convergence Alignment issue
Im haveing an issue with adjusting only the RED in some area of my tv's grid areas. By that I mean that some sections of the grid the RED will move in any direction and align just right while in other areas the RED is so far off that it will not move correctly or far enough to align with the blue and green. My blue and green alignments seem fine - only having issues with some areas of the RED. Any suggestions would be greatly appreciated.
I have the board out of tv and having a hard time locating the STK392-110 on board can you give me clue.
Posted on Jan 14, 2010
    Genius:
  • 1,694 Answers
Replace both STK392-110 Convergence IC's with Toshiba or Sanyo quality................No cheap IC's !!!......................T.
Posted on Aug 22, 2008
I am wonering how to reset the yellow blue and red color grid ?
If you are talking about convergence there is a setting in the customer menu and with the original remote try adjusting there--a color that will NOT adjust in some area of the screen up/down or left/right means the set has a convergence problem.
Parts need to be located and replaced if that is the case.
May 26, 2012 | Zenith Televison & Video
The screen is distorted ... double words and double picture
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergence select that and wait a minute the TV will adjust itself and give you a clear picture.
If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the cursor (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It takes time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture.
You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of synchronous.
RPTV's are made of the three lenses (red, Blue and Green) and as you watch TV, these lenses slowly get out of alignment. So you should do a convergence about twice a year to make sure nothing is out of whack.
Good luck in solving the problem....
May 27, 2011 | LG 50PG20 50 in. Plasma HDTV
Double image from red bulb
You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of synchronizing.
RP TV's are made of the three lenses (red, Blue and Green) and as you watch TV, these lenses slowly get out of alignment. So you should do a convergence about twice a year to make sure nothing is out of whack.
You can pay somebody to do it, but may cost you like 100.00 or do it yourself, it is very easy just tedious and time consuming. If you have the auto convergence than your golden because this is the easiest way to "reset" the TV.
Hope this will help in solving the problem....
May 21, 2011 | JVC AV-65WP94 65" Rear Projection...
I have a green and red shadow on the words. It appears towards the top and bottom of the screen.
You have to do this will all TV inputs (Video1, Video2 and so on) the reason Zoom looks good, is because you never used that screen as much and so the lenses didn't have a chance to get out of synch.
Since it is 4-5 years old it's a 50-50 chance that the TV has the auto feature. Good luck and if you still have the owners manual, I would read up on the convergence section in the manual.
Take in solving the problem.....
Jan 12, 2011 | Philips Magnavox 51MP392H Rear Projection...
Ive got a samsung LE32A457CID tv every now and then whilst watching a progamme all the people green, wot can this be ???
It's a convergence issue. Go into the main TV menu under video settings and look for convergence. If it has an auto convergnce select that and wait a minute the TV will adjust itself and give you a clear picture.
If the TV does not have an auto convergence and just regular convergence than select this. It will give you a grid pattern on your TV and you have to move the cursor (using TV remote) and adjust each "point" so that each line is perfectly white. If you notice red or blue anywhere on that "line" then you have to adjust using the up, down, left and right arrow keys to "line up the red and blue lines with the nearest white line. It taked time and patience to do, but when completed, all lines on the grid pattern should be pure white and you will have a great looking picture.
Good luck and if you still have the owners manual, You should read up on the convergence section in the manual.
Jun 14, 2010 | Samsung Televison & Video
Have aligned all the + signs already but is still out of focus!
with the original remote go into the customer menu and find CONVERGENCE---you will be able to adjust a single cross and also if you continue it will give you several points on the screen with a grid of lines----what you are looking for is does the red and blue adjust in all areas----if either will not adjust up/down and left right---you have a convergence problem--need to replace both convergence IC's and then align the convergence. Hope this helps you.
Aug 09, 2009 | Panasonic PT-51HX40 51" Rear Projection...
Covergence out of alignment on 1/4 Vertical left side of screen
You need to manually adjust the alignment:
On remote, press Menu to get to the main menu
Then arrow down to "ADVANCED FEATURES"
Then press "enter"
Then Arrow down to "CONVERGENCE" and press "enter"
"Red Convergence" should be highlighted
Press "enter"
You now have Green, Red, and Blue overlapping crosses.
If Red is out of whack, use arrows to align
To toggle to blue (and back to red), press "VIDEO"
Then align blue cross
Once the crosses look aligned, and nice and white, press "AUDIO"
This will bring up the Advanced Convergence screen
This is a grid of the same overlapping colors
You have control over the Red and Blue
If Green is very out of whack, you'll need a repairman…
While the "target" is flashing, you can move it around the screen with the arrows
Place it over an intersection to adjust, then press "enter"
Now the "target" is steady (not flashing), and you can use the arrows move your color
When it's aligned, press "enter" again
Now "target is flashing, and you can go to the next square.
You cannot adjust every intersection.
Some areas need to be adjusted via the adjacent intersection
When you're happy with color you're working on,
Press "video" while target is flashing to change to the other color
Repeat the above (blue is much harder to see and adjust for me…)
When you're happy with the entire grid, start hitting "Menu"
Each press brings you back out one menu level, until you are out of them
Once you're used to the process, it should take no more than a minute or two.
Mar 02, 2009 | Mitsubishi WT-46805 46" Rear Projection...
CONVERGENCE PROBLEM IN TOSHIBA 43H70
Replace both STK392-110 convergence IC's with Toshiba or Sanyo brand........no cheap junk IC's !!!.................T.
Aug 16, 2008 | Toshiba 43H71 43" Rear Projection...
Adjusting convergence grid
i correct grid will look all white. all colors aligned up.
you should be able to move the lines with the remote. and you cant burn anything out by doing convergence.
Jan 27, 2008 | Samsung HC-P4752W 47" Rear Projection...
Still can't get into the convergence mennu
You may need the original remote. This is normaly needed to access this menu
Jan 24, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
Toshiba 43H71 43" Rear Projection Television Logo
102 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
