I have a rca t.v that wont turn on - Televison & Video
    Guru:
  • 586 Answers
Your TV is obviously having a power problem. Once a TV does not turn on, then it means it is having a power problem. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on. (Before you go any further, check the power wire/cord connected from the wall (plug) to the TV. This is to confirm if the power cord has not loosed contact from the wall.)
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Regards.
Posted on May 29, 2011
Rca th1611 wont work
either you have keys locked (look on the end near the earphone jack) or you have low battery
Aug 18, 2009 | RCA TH1611 MP3 Player
Rca mp3 is stuck on the now playing screen and wont turn off
hold the power key for 10 seconds and the player will turn off
May 31, 2009 | RCA M4208 MP3 Player
Tv wont turn on
try replacing the flyback 259296 and CP150 both items are available at the following link with free instructions.
http://servicemanuals.vstore.ca/
Dec 20, 2008 | RCA D52W19 52" Rear Projection Television
Rca tv wont turn on
What is your Chassis# and what year is TV??
Nov 18, 2008 | RCA P56950 56" Rear Projection Television
Remote wont turn the tv on
need the codes for the remote to porgram it back in
Jul 17, 2008 | RCA 20F424T 20" TV
Wont turn on
try fomatting it then unplug, reset your machine then plug it back in if that dont work trash it the rca m002a has a problem
Jan 21, 2008 | RCA OPAL M4001 MP3 Player
MY RCA TVE WONT TURN ON
Did you change your battery from the remote?
Dec 02, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca opal screen wont turn on
OK click the play/pause button twice/ Or: the hold switch on the right side may be on.
Sep 14, 2007 | RCA OPAL M4001 MP3 Player
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
