Question about GE DBXR463EDWW Electric Dryer
Squeeking when on - GE DBXR463EDWW Electric Dryer
    President:
  • 3,074 Answers
Check drum roller and glides Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Posted on May 29, 2011
My 2001 Nissan Altima has a squeeking sound coming from the drivers side wheel. It only squeeks when the car is moving. And I don't think it squeeks when I use the brakes. What could be causing it to...
You will need to pull the wheel off and inspect the brakes. Spray some brake fluid cleaner on the rotor and disc area to clean the brake dust off. Next, have the wheel bearing checked and replaced, a bad wheel bearing would cause your wheel to squeak.
Feb 06, 2011 | 2001 Nissan Altima
Sounds like serpentine belt is squeeking
If the squeek stops as the motor warms up replace it. You can also purchase some squeek stop spray and see if that helps before buying a new belt
Sep 09, 2010 | 2001 Oldsmobile Aurora
When put into 4 high from 2wd I hear a squeek squeek squeek while driving about 20 or 30 km per hour
you have a bad ujoint on your front drive shaft. remove shaft and replace the bad one but i would replace both. its squeeking cause the bearings in it have turned to rusty powder and are dry, the bad one will be easy to spot
Apr 28, 2010 | 1991 GMC K2500
Front end squeeks changed the upper and lower ball joints and it helped but it still squeeks, whats next?
Bushings....did you replace both sides?
Another cuase of the squeek too is the upper strut mount.
Nov 04, 2009 | 2000 Lincoln Town Car
Brakes squeek
did you spray some brake stop squeek on the back of the pads before you installed them try these websites www.alldatadiy.com and www.autozone.com and the stop brake squeek you be able to pick up some at any auto parts store even Walmart.
Aug 28, 2009 | 1994 Honda Civic
I have a Maytag Legacy Dryer SDE305DAYW that is squeeking. How do I change the belt?
the belt is not causing the squeek. either the tub rollers, or the idler pully is squeeking. you must remove the front panels and drum to inspect these parts. usually when a roller or idler pully is squeeking, you need to replace them. if they arnt to worn, you can clean the shaft and grease them to stop the squeek, but i dont recomend that, as it will just be a temporary fix and will start squeeking again. this isnt a easy repair if you've never done it. let me know if you have any further questions. Shane
Jun 19, 2009 | Dryers
Clutch squeeks when i put it in? any solutions?
It just squeeks once when you push the pedal? Or sqeeks the whole time the pedal is down.
Mar 30, 2009 | 1998 Chevrolet S-10 Pickup
Squeeks from front end, 1999 explorer sport
you did not indicated when the squeek occurs. If you turn the steering wheel and there is a dry squeek look at the tie rod ends. If you bounce the truck and the squeek is heard look at the stabilizer bar bushings {most common cause } If this is the cause, lubing them is a temporary fix they should be replaced.
Feb 19, 2009 | 1999 Ford Explorer
Kenmore Elite model: 22932
Washing machine works fine UNTIL spin cycle. Loud engaging sound and then it makes a squeek, squeek sound...not really a squeek, but if you were to listen to it, eee, eee, eee, eee, eee and loud.
Dec 10, 2007 | Washing Machines
GE DBXR463EDWW Electric Dryer Logo
41 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
