Question about White Sewing Superlock 1934D Mechanical Sewing Machine
I have a white superlock 534- I recently broke a needle and now I cannot load two needles. After unscrewing the screw- I try to load two needles and only the right will stay in--left falling out. If I load the left needle only, it will stay and the same with the right, but I want two needles loaded. Any help would be appreciated. I do have the pressure foot down, wheel in the highest position.
  • Terry Ryan
    Terry Ryan May 03, 2014
    I broke a needle and then when I went to replace the broken one with a new needle. After unscrewing the screw- I try to load two needles and only the right will stay in--left falling out. If I load the left needle only, it will stay and the same with the right. When I replaced both needles with the new needles it worked. What was happening was one needle top was fatter than the other one so the screw only held the fatter neede in place. If the fatter needle was removed the thinner needle would be held in place. When I put two of the new needles in it worked perfect.
    New Friend:
I have a White Superlock 534,the needle broke and I tried to change the needle and lost the screw,it is so tiny I cant find it,is their any way I can buy the same tiny screw.I like to have 2 needles.
Posted on Mar 08, 2014
SOURCE: needle clamp won't attach to needle bar
There is a set screw above the needle pin screw which tightens with an allen wrench--try that.
Posted on Feb 21, 2009
  • 185 Answers
SOURCE: Needle timing.
Timing of a sewing machine, which timing? Needle to hook timing is fairly simple, turn the hand wheel in the direction the machine sews until it is at bottom of the stroke. Continue turning it until it moves up 2.54 mm if it is timed correctly the point of the hook should be right behind the needle and passing above the eye in the middle of the scarf of the needle. There are several timing of a sewing machine, needle to hook, feed and swing timing.
Posted on Feb 23, 2008
  • 9 Answers
SOURCE: Kenmore sewing machine 385.1960180, problem with needle centering
That sounds like it's definitely an internal adjustment. The machine will need to be opened up and the left/right adjustment taken care of. Is this machine one that you can open the top easily, or is it the type that has the front and rear shell?
  • 23 Answers
SOURCE: I broke a needle on something hard. After I
This sounds like your metal plate needs adjustment. Loosen the screws and adjust it until the needle goes all the way down. If that doesnt work, ensure that your bobbin case has been aligned properly.
Posted on Apr 13, 2010
  • 123 Answers
SOURCE: left needle thread keeps breaking
the tension must be too tight or check to make sure the spool does not have a crack that is catching the thread in the middle of using the serger. When the serger is working and the spool has a crack it catching the thread then you press to go on and it gives a break the needle because the spool is still holding onto the thread
Posted on May 02, 2010
What needle to I need for my White Superlock 534 Serger achine
It looks like your machine will take Singer, Kenmore or any universal needle 15x1. Double check your manual.
Nov 29, 2017 | Sewing Machines
Need the manual for model 534?
SINGER 534 MANUAL Pdf Download. - ManualsLib
www.manualslib.com > Brands > Singer Manuals > Sewing Machine > 534
View and Download Singer 534 manual online. Stylist Sewing Machine. 534 Sewing Machine pdf manual download.
[PDF]White Sewing Manual Model 534
www.masepmadit.com/white-sewing-manual-model-534.pdf
vw instruction manual, white 534 serger: sewing parts online understandable ... techmanual white superlock serger model 534 repair manual compiled pdf.
Jan 07, 2016 | Sewing Machines
I need a replacement needle screw for my White Superlock 2000 What size is this screw?
try these sites--you may have to email them about the needle screw
sewingpartsonline.com
sewvacdoctor.com
a1sewingmachines.com
Apr 23, 2012 | White Sewing Superlock 2000 ATS Mechanical...
What needle do I replace my broken needles with on my WHITE SUPERLOCK ELECTRONIC 1934D
I use schmetz universal needles in all my sewing machines or try sewingpartsonline.com
Jan 22, 2011 | White Sewing Superlock 1934D Mechanical...
What is the size of the needle used in the white superlock 1934D
This is a very highly regarded serger. Check out the reviews on http://sewing.patternreview.com if you're interested--but they are all extremely positive.
I also checked out the White Sewing Machine site--the three sergers they currently sell all use regular sewing machine needles.
Based on what I read on both sites, I believe your machine also uses regular sewing machine needles (not all sergers do, BTW). To be absolutely certain, you can call the White Help Line (l 800-331-3164, Monday through Friday 8AM to 5PM, EST).
If your serger uses regular sewing machine needles, then the size of the needle depends on the type of fabric you're sewing. Sizes 8 to 10 for lightweight fabrics, 12 to 14 for medium weight fabrics, and 16 to 18 for heavy weight. Use ballpoint needles for knits, jeans needles for denim, and universal needles or sharps for woven fabrics.
Jan 26, 2010 | White Sewing Superlock 1934D Mechanical...
Hand wheel will not turn
A FRIEND GAVE ME A SUPERLOCK 2000 WITH THE SAME PROBLEM. THE HANDWHEEL WAS HARD TO TURN AND MACHINE WONT RUN WHEN PLUGGED IN. I OPENED THE SIDE COVER WHERE HANDWHEEL IS LOCATED. FOUND THE BELT WAS DRIVEN OFF THE MOTOR. PUT ON THE BELT ON THE MOTOR, OILED THE MOVING PARTS.
WOKRING GREAT NOW.
Apr 30, 2009 | White Sewing Superlock 2000 ATS Mechanical...
Bottom thread keep breaking , sew an inch then break !!
Make sure that the needle is all the way up in the needle bar.
Unscrew until just loose, use finger nail or small screw driver to push up on the needle. The two needles do not line up.The right needle extends longer. Also, make sure that there are no burs on the needles and that they are straight and correct for your machine.
Apr 28, 2009 | White Sewing Superlock 1934D Mechanical...
Right needle broke twice
Needle sizes: 14 for general sewing, 11 for light-weight fabrics. Make sure that the needles are as far into the needle bar as they can go. Remember that the right needle extends out just slightly further than the left (they do not line up). Be sure that needles are inserted with the flat side away from you.
Dec 03, 2008 | White Sewing Superlock 1934D Mechanical...
White Sewing Superlock 1934D Mechanical Sewing Machine Logo
332 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
