Question about Sony WEGA KZ-42TS1 42 in. Plasma Television
My sony kz-42ts1 tv keeps going to standby sleep mode. turns on for a sec. then off to standby. Do not have manual. What to do?
SOURCE: Sony tv keeps going into standby mode
the tv is probably placed n a tight spot and getting over heated or even if its n a good air circulated area u may be leaving it on to much and its overheating anyway or its your lamp it may b out i heard they only have 1000 hours of operation the lamp operation not the tv itself ----K.O.
Posted on Jan 02, 2009
  • 51 Answers
SOURCE: The tv turns off automatically & standby light blinks 4 times
4 blinks is bad backlight inverter. Download the service manual here:
http://rapidshare.com/files/208591107/KDL40S2000_L5_sm.pdf
Posted on Aug 22, 2009
SOURCE: 40'' Sony Bravia goes into standby with the light blinking 9 times
I finally managed to solve this problem by unplugging everything - scarts - HDD cables - power etc and left it for an hour. When I turned it back on again the problem had sorted itself out.
Posted on Oct 01, 2009
xptareq2000
  • 1447 Answers
SOURCE: My Sony Bravia KDL-40S2000 keeps powering off by
Problem may be the power supply,check in it thoroughly and find the falty components.Remove the faulty one and replace new one.
Such as components may be diod,capacitor,power booster.If you are able to do your self other wise take it to the workshop.
Posted on Dec 31, 2009
SOURCE: sony bravia
HI I HAVE A SONY BRAVIA 55 INCH REAR PROJECTION TV MODEL NUM: KF-55E200A. 1 DAY IT JUST MADE A POP NOISE AND THE SCREEN WENT BLACK,NOW WHEN I TURN IT ON IT MAKES A BUZZING SORT OF NOISE,THE SCREEN IS BLACK AND A RED LIGHT FLASHES? WHAT DO I DO
Posted on Oct 01, 2010
Our Sony TV at work will not give us the option to turn off sleep mode permanently.
Go into settings, there is a option to turn the sleep mode on or off.
Oct 12, 2016 | Sony Televison & Video
My 15 month Celcus LCD423D913FHD tv will not turn on. The standby light is lit and will flicker but will not power up the tv. What is the likely problem?
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 20, 2014 | Televison & Video
Samsung lcd lines vertical
There are so many reasons for this fault. If you wish to get more details, check this link. Pull up older posts there. Faults with screen shots are given. Compare them with yours and make sure about the fault.
Mar 21, 2013 | Sony WEGA KZ-42TS1 42 in. Plasma...
Hi I have a sony KV-ES34M31 -- I pressed the sleep button by mistake it won/t come out of that mode. 2 blinks in a 3 sec period.
The main power supply regulator board has damaged. The fault you see as two blinks are its indication.
Visit this site for more details. Type in the site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as electronics equipments' repair help.
Pull up older posts there. Cause for two blinks of standby light with Sony sets are described in detail. Check it.
May 19, 2012 | Sony FD Trinitron WEGA KV-24FS120 24" TV
When i turn the tv on, the standby light star flashing, and the picture goes off and come back on after like 10 sec and keep so over and over. please help.
you need a new bulb for the tv but first call manufacture and the can tell you what to do on your remote to stretch the lifetime on your current bulb and also check if the sleep timer was accidentlt programmed.
Nov 04, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
42 sony wega plama veritcal line
The PDP ( plasma display panel) is defect.You can look for badly soldered SMD resistors on the COF panels wich are located at the bottom of the screen.
Beware,the flatcables wich the resistors are located on are verry fragile!
Nov 02, 2009 | Sony WEGA KZ-42TS1 42 in. Plasma...
Aug 22, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I pressed the sleep button by accident and the pic and sound went off and the stand by/timer red light started blinking. what does it mean?
Depends on how many times it blinks,just count the blinks Example: if it blink 2 times then pauses and blink 5 times then the code would be 25 and so on
Once you have this code,please post it.
Jul 30, 2009 | Sony KV-32S40 32" TV
Sony KP53HS30 Stuck in Sleep Stand by
I don't believe it is stuck in the sleep standby mode, rather it has shutdown with an error. Is there a pattern to the flashing? Does it flash a set number of times?
Oct 19, 2008 | Sony KP-53HS30 53" Rear Projection...
Plasma tv vertical lines
I am getting a vertical green line on my lg 50 incs is the screen or have you a solution
Sep 03, 2006 | Sony WEGA KZ-42TS1 42 in. Plasma...
Sony WEGA KZ-42TS1 42 in. Plasma Television Logo
118 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
