Question about HTC HD2 Smartphone
Touch screen not responding it is on the tap or slide
  • yortlob9 May 29, 2011
    how do you do a soft hard reset
  • 659 Answers
Settings -> Menu -> All Settings -> System -> Screen and see if you can calibrate the screen that way
Posted on May 29, 2011
  • 3 more comments
    i cant get into nowhere no button is responding should i buy a new touch screen
  • Wesley Gardner
    Wesley Gardner May 29, 2011
    you can try a soft and a hard rest of it as well to see if that will help
  • Wesley Gardner
    http://www.htc.com/us/supportdownloadlis... and do the install the newer rom for it this might help as well
  • Wesley Gardner
    Wesley Gardner May 30, 2011
    Performing a factory reset via settings
    On the Home screen's Settings tab, tap Menu > All Settings > System > Clear Storage.
    Enter 1234.
    Tap YES to perform the reset, or tap NO to cancel the reset.
    Performing a factory reset using phone buttons
    If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using buttons on the phone.
    With your phone powered off, press and hold the VOLUME UP and VOLUME DOWN buttons.
    While holding the volume buttons, press the END/POWER button briefly and then release it.
    When you see a warning message on screen, release the VOLUME UP and VOLUME DOWN buttons.
    Press the VOLUME UP button to perform the reset, or press any other button to cancel the reset.
    Performing a Soft Reset
    Perform a soft (normal) reset to clear all active program memory and shut down all active programs. This is useful when your phone is running slower than normal, or a program is not performing properly. If a soft reset is performed when programs are running, unsaved work is lost.
    Hold your phone securely, with the front facing down.
    With your thumb or finger, open the back cover by lifting up from the left side of the cover.
    The RESET button is located at the bottom left below the battery compartment and SIM card slot. Use a small object with an unsharp, pointed tip such as a toothpick to press the RESET button.
    Your phone restarts and displays the Home screen.
    To replace the back cover, secure the right side of the back cover first and then press the cover down into place.
  • Wesley Gardner
    ah sorry that one is all bunched together like that.
Ipod touch screen is unresponsive but it makes sounds like normal
Fix an Unresponsive Ipod Screen
Many of today's electronic devices including cell phones, music players and portable game systems have a touch screen.
When a touch screen fails, it does not respond when you tap it with your finger or a stylus.
This can happen due to several reasons, such as a screen protector, dust or improper calibration.
You can often fix an unresponsive touch screen by cleaning it or resetting the device.
Remove the plastic touch screen protector sheet.
Some protector sheets are too thick and prevent the touch screen from responding to your touch. If you must use a protector screen, only use one that is licensed for your specific device.
Wipe the screen with a soft microfiber cloth.
Clean off any dirt, dust or fingerprints on the screen.
Dry your hands thoroughly.
The touch screen will not respond if your hands are wet.
Reset the device.
If your device does not have a "Reset" button, remove the battery, memory card or SIM card, then reinstall them.
Delete any third-party applications you recently installed.
Some third-party applications can cause your device to lock up or freeze.
Recalibrate the touch screen.
Look in the device's Settings menu for a calibration option and follow the prompts.
http://support.apple.com/kb/ts2771
iPod touch: Hardware troubleshooting
If this fails to fix the problem
Press the "On/Off-Sleep/Wake" button and hold it for a few seconds, until a red slider appears. Press the "Home" button until the frozen app quits.
If this doesn't work, you can try restarting the iPod touch.
Press the "On/Off-Sleep/Wake" button if you need to restart the iPod touch, and hold it until the red slider appears on the screen.
Slide your finger over the slider to turn off the device.
Press the "On/Off-Sleep/Wake" button and hold it until the iPod touch turns back on.
If you can't turn off the iPod touch, you can try resetting it.
Press the "On/Off-Sleep/Wake" button while simultaneously pressing the "Home" button when you want to reset the iPod touch, and continue to hold the buttons for at least 10 seconds, until the screen goes black and the Apple logo appears.
Jul 31, 2013 | Apple iPod touch
My touch screen doesnt respond properly. What could be the probable issue?
tap start>setting>system>screen>align screen, the calibration starts tap on center of +
May 20, 2010 | HTC Touch P3450 Smartphone
My garmin (nuvi 670) touchscreen does not respond to any touch
If the Touch Sceen is not responding properly, calibrate the touch screen.. Turn the Nuvi off then back on Slide Power key to the right (lock) Hold your finger on the secrren for 30 seconds until the calibration screen appears Follow the on-screen instructions
Apr 08, 2010 | Garmin 010-00358-00 GPS Receiver
My Sylvania SMPK8854 touch screen 4GB mp3 player will not respond to touch. I tried resetting it but did not help. How do I fix it?
YEA PLEASE CAN YOU HELP MEE BECAUSE MY Sylvania SMPK8854B WILL NOT LETT ME TOUCH THE SETTING AND I REALLY NEED HELP!! WITH MY Sylvania SMPK8854B!!
THANK YOU THEY MUCH!♥
Jul 09, 2009 | Sylvania SMPK8854 Digital Media Player
My screen is lockedI did a hard reset and screen wont respond
ur touch panel is faulty u have to go to service centre , there are 3 things coupled together Lcd screen then touch panel and then front housing for protection of both , u might dropped it , if ur screen is working partially i mean if it responds to taps at some region of screen then it may be a dust inside the housing u have to clean it from inside if u can , otherwise if it completely not responding then it is faulty touch panel , it will cost u around 50 , 60 $
Feb 12, 2009 | HTC Touch P3450 Smartphone
Touch screen not responding at all
The touch pad is dead...it's a hardware issue...go to the vendor or workshop...within a year it is replaced for free.Good luck.
Feb 02, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Htc touch p3450 is not responding to stylus taps or finger taps
you needto replace the ants which live behind the touch screen
get some fresh once from your garden (or park) if you don't have a garden
Open phone( oh not allowed or warrenty void)
WHAT warrenty?
anywat open phone and you will see a few dead ants behind the screen.
Replace ants with fresh live ones
Close phone (quickly or ants excape)
power on phone
Never do hard reset on phone
It will electrocute some ants
Jan 07, 2009 | HTC Touch P3450 Smartphone
HTC HD2 Smartphone Logo
276 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
