Question about Belkin Computers & Internet
Whats is a Isp code - Belkin Computers & Internet
  • Anonymous May 11, 2010
    Im not sure what you mean by ISP Code..... Or did you mean LSP code?
    I searched google and found more convincing results for LSP code as opposed to ISP Code.
    President:
  • 2,961 Answers
If you mean you need to obtain a MAC Code from your current isp, this is a code that enablesyou to transfer from one providers broadband to another, the code lasts for 30 days which you need to provide your new ISP with to make a seamless change over
Posted on Aug 17, 2008
SOURCE:
Im trying to download net flix on my wii and im getting the error code 52031...what does that mean?
Error 52031: It's possible that the wireless security pass code for your home network may have been changed or is entered incorrectly on the Wii console.
However if you're using Wi-Fi to connect to the internet, your ISP may be blocking the ports allowing you to use netflix from your WII. You may need to contact you ISP in order to verify this problem.
Aug 23, 2011 | Nintendo Wii Console
HUAWEI FOR MOBILY IMEI: 359767034606237 S/N : NJ4CAA1073105250 MODEL: E1750C Please send me the unkock code
You will find your unlock code for your device if you telephone to your ISP, or when you buy it in the device box you find with your SIM card two unlock codes, use them. Unlock code can be use only with your device and it's give it to you by your ISP.
Mar 24, 2011 | Computers & Internet
Password codes for f480
Here is Samsung F480 Secret Codes
Admin Settings: *#6984125*#
Admin Settings
Internals (sub menu): *#9072641*#
Developer Settings: *#0523#
Camera test mode:
Press *#36287# key string in the dial screen to enter camera test mode -
[1] Auto focus [On]
[2] ISP firmware write
[3] ISP firmware version check
[1] Press the "1" key to disable auto focus. In order to enable auto focus, press the "1" key again.
[2] Press the "2" key to write the ISP (Camera Module) firmware. "ISP firmware write [Please wait]" will be displayed during 2 minutes. Then "ISP firmware write [SUCCESS]" will be displayed when the firmware upload finished.
[3] Press the "3" key to display ISP firmware version.
Latest ISP firmware should be 0x1f4d8723 (found in F480XXHF7)
IMEI : *#06#
Software version : *#1234#
FTA S/w version : *#1111#
Hardware info : *#2222#
F/W and H/W version : *#0206*8376263#
Test menu : *#0*#
battery info : *#0228#
Master Reset : *2767*3855#
GPRS info : *#4777*8665#
Bluetooth ID : *#232337#
LCD Brightness : *#8999*523#
Call List : *#2255#
External Displayl : *#8999*3825523#
Java Status Code : #*536961#
This code has something to do with phone locking. : *#7465625#
Mar 01, 2011 | Samsung Cell Phones
Y have problem whit the internet it to slow
dude that is in terms if your ISP.
but before you call your isp try to do this:
Scan for viruses ( but first update the antivirus software you use to the most updated virsion )
CMD codes ( Cant connect to Internet )
1. Go to command prompt
2. Type-in Ping 127.0.0.1 = Lan Card address
3. Get the value of the pockets Sent, Recieved and Lost.
4. If the value is ( Sent = 4, Recieved = 4 and Lost = 0% ) Then the lan card and wireless card is working fine and the problem is with the ISP = Contact ISP
OR
No Connection using router
2. Type in ping 192.168.0.1 or which ever the address of your router.
4. If the value is ( Sent = 4, Recieved = 4 and Lost = 0% ) Then the lan card and wireless card is working fine and the problem is within the Router configuration. = Advice the CX to Contact the Router manufacturer or ISP
Aug 21, 2009 | Acer Aspire One PC Notebook
HOW CAN I GET MODEM ACCESS CODE ON SPEEDSTREAM 5100
hello
When you have modem plugged straight into computer, you can access it at 192.168.0.1, should ask for modem access code, (on bottom), then you can click 'advanced' > ppp location and set it for 'on computer'. There may also be a link for technician stats, it will give you info about isp connection. You should / might be able to browse but ISP may need original MAC address of machine (network adapter} you used when 1st signing up. Or if set to PPOE, it would look for name / PW in order to access INternet through ISP.
Anyway, try (after setting PPP on computer) Modem into WAN of router, access router, set PPOE > insert Log-in name / PW and save all settings. Then try homepage, if no, have router "clone MAC address" of the Network adapter you had the 5100 plugged into. Now it should work, even if no <INTERNET> light. ETHERNET light should be constant. Have router use DHCP to address machine independantly of what ISP addresses router, which it will do when modem (having connection confirmed with DSL light)
The other way, PPP location set 'on Modem', means the modem signs into ISP and then it assigns IP address with a timeout around 20 minutes. By getting connection test results when modem is connected to computer, it may seem to make sense, by understanding how ISP knows that modem access code / MAC address, and lets the settings of modem determine if router needs to sign in or not. If PPP is 'on modem', it will be looking for the MAC address of computer, that is why you may need to clone that address into router, so the router can appear as the machine to the modem, than the router assigns net address to computer.
Regards
Jul 09, 2009 | Efficient Networks SpeedStream 5100 Modem
I i forgot my phone lock code for my samsung sgh-f480
hard reset *2767*3855#
All Samsung Hard Reset Codes
In those steps:
1.)*2767*3855#
2.)*7465625*638*00000000*00000000#
3.)#7465625*638*00000000#
Now your phone is unlock forever Permanent
Admin Settings
Camera test mode:
[1] Auto focus [On]
[2] Press the "2" key to write the ISP (Camera Module) firmware. “ISP firmware write [Please wait]” will be displayed during 2 minutes. Then "ISP firmware write [SUCCESS]” will be displayed when the firmware upload finished.
Jun 08, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
What is pops and how can i send out mail when i try to send out some emails a widow opens up asking about pops3 i dont know what to do.
if you have MS Outlook, open it, even if you do not use it, go to tools, then to accounts, click on that, find new accounts, POP3- (your isp info)
SMTP-(your isp info)
to find your isp info - go to your isp (email) support site
enter isp info and click finish a new box will come up telling you that you have successfully created a new email account
Apr 28, 2009 | Computers & Internet
Aspire 3680-2682 Laptop
the isp code is yor internet service providers code that tey should of given u if they havent ring them up and ask them
Jun 26, 2008 | Acer Aspire 5610-4648 Notebook
Open Questions:
Computers & Internet Logo
24 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
