Question about Indesit W 123 Front Load Washer
I have a IDL146 washing machine, always the 1400 spin cycle was noisy but now it sounds like a jumbo jet taking off! Are there bearings that can be replaced by a DIY person? If so,please can you tell me the part number I need to buy. Thank you
  • 3,740 Answers
Hi and welcome to FixYa,
These are the bearings making noise.
http://www.yourspares.co.uk/parts/hotpoint/washing-machines/widl146/parts/ys75567/bearing-kit-HPTC00203002.aspx
However.. this is not a task the average mechanic will be able to accomplish. It involves complete disassembly of the cabinet, the removal of the outer tub front cover and finally removal of the inner tub.
Additional issues that can be encounterd are:
1. Establishing a proper "Tub balance" post bearing / seal change
2. Outer tub seal leaking in the front of the machine.
3. Drive belt damage
4. Tub spider damage if the bearing is very difficult to remove.
This is one of those tasks that has resonably priced spare parts for the initial problem but, can very easily result in the need for several other spares and added expenses.
If your going to DIY just understand what your getting into and take your time. Make sure to clean the front outer tub seal quite well as it will leak if there is even a hint of debris on the seal post repair.
Thanks for choosing FixYa.
Kelly
Posted on May 29, 2011
SOUNDS LIKE JET PLANE WHEN IT GETS BY RINSE AN SPIN TIME
I assume you mean it sounds like a jet plane when it spins, if so, I suspect a bad tub bearing. Depending on age of the machine, probably too expensive to repair.
Mar 07, 2015 | Maytag Neptune Washing Machines
What can cause noisy spin on wd960 hotpoint ?
bad bearings, seal leak let water in bearings
Tub seal leaking letting water get to tub bearings need shaft and bearings replaced. takes special tools
Aug 31, 2014 | Hotpoint Washing Machines
Noisy spin cycle
IT SOUND LIKE YOUR REAR BEARING IT GOING OUT ON THE WASHER
Nov 02, 2012 | Kenmore Washing Machines
Loose drum
If your machine is a front load washer, and it's a few years old a loose drum which is noisy, probably means that the bearings at the rear have collapsed.Water gets through the seal and goodnight bearings and probably the shaft as well......Sorry......Nomess
Apr 18, 2010 | Washing Machines
Noisy during spin cycle, sounds like a jet plane at full spin.
the drum bearings have gone, expensive repair, this is caused by over loading the machine
Feb 02, 2010 | Maytag Neptune MAH5500B Front Load Washer
VERY noisy spin cycle wf860
it sounds like your concrete block is loose. unplug machine and remove lid check block on top of drum there is also 1 at the front of the machine below the door seal. WARNING DO NOT OVERTIGHTEN THE BOLTS.
Mar 20, 2009 | Hotpoint Ultima WF860 Front Load Washer
No spin & drum is very noisy during cycle ,like a jet engine
Sounds like the drum bearings have gone and the belts come off.
Im afraid this is an expensive repair and not a diy job.
Sorry to be the bearer of bad news.
thankyou for using Fixya.
Mar 15, 2009 | Washing Machines
AWM 8163 Whirlpool washing machine
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Aug 29, 2008 | Whirlpool AWM8163 Front Load Washer
Noisy Spin Cycle
frigidaire frontloader infamous for rear bearings going bad,NOISY is probable an understatement. I wold open door and grab hold of inner tub, try to lift it up a bit, problably a bit of play in there, thats an indication of bearing failure, call authorized servicer possible warr parts
Feb 22, 2008 | Frigidaire FWT449
Indesit W 123 Front Load Washer Logo
299 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
