Question about Watches
How to set correct time on the black dice cash watches? Thank you
2 Suggested Answers
  • 5631 Answers
SOURCE: Black dice watch setting time
Any tip from this video?
Black Dice Watch
BLACK DICE GURU Multifunction LED Watch
If no tip, look if box has any URL address to contact manufaturer. You can ask also in the shop where you bought it.
Sorry... I couldn't find any Weppage on internet related to a watch manufacturer producing Black Dice watch
Posted on Aug 02, 2015
Black Dice Watch
Aug 02, 2015 | Black Watches
GW40001A, time is incorrect by hours
make sure the dial is pressed all the way in
Mar 02, 2014 | Casio G-Shock GW4000-1A Shock Resistant...
How do you change the battery in a black dice flow watch
You need to open watch case back using appropriate tools. There are two batteries in this model - one for each watch movement. Unscrew/un-clip battery contact. Memorize polarity (+ and -). Take the battery to your nearest watch battery shop or watch repair shop and buy the same one. Fit new battery back in watch (remember polarity!). Fit back contact as it was. Close the watch case back. Set the time. Done.
Feb 25, 2011 | Black Dice Industries BD04101 Flow From...
I have an OCW-M 800. I have downloaded the manual from mfg. website and cannot seem to get it to set the time for EST correctly. THis watch cost me over $500.00 and is so complicated that I fear I have...
I am not American, so I am not familiar with the definition of "EST" or which of the four "city" settings is correct for you.
Having read the instructions I see that for America you have to select "USA" first and then the appropriate city, have you done this?. The list of four options covers 4 time zones, so you should be able to get the correct time for your area.
When I bought an atomic watch recently, I had to leave it overnight to catch the timekeeping signals. I see that you posted your question only 14 hours ago. How long have you had it. GIve your watch a day or so for it to latch on to the correct time.
Check that the "autoreceive" is "on".
Check that the daylight saving time (DST) is correctly set. The manuals indicate that some areas may not be using it?
Keep trying - it is nice to have a watch that is always correct!
Oct 04, 2010 | Casio OC500 Oceanus watch
I have an aquatech watch and don't know how to set it.
Thank you for contactng FixYa.
Setting the Time and Date
  • To set the time and date on your Aquatech watch, begin by pressing the "Mode" button three times to access the time setting screen. Use the "Lap/Reset" button to set the hour on your watch. Use the "Start/Stop" button to advance the numbers to reach the correct hour. When you've set the hour, use the "Lap/Reset" button to set the minutes, using the "Start/Stop" button to advance to the correct minute. Repeat the procedure to set the seconds, month, date and day of the week on your Aquatech watch.
  • Setting an Alarm
  • To set an alarm on your Aquatech watch, begin by pressing the "Mode" button two times to access the alarm setting screen. Use the "Lap/Reset" button to set the hours place, using the "Start/Stop" button to reach the correct hour. Repeat the same procedure to set the minutes for your alarm. When you have finished setting the alarm, activate it by simultaneously holding the "Lap/Reset" and "Start/Stop" buttons until the alarm icon appears. When the alarm sounds, silence it by pressing the "Lap/Reset" button.
  • Deactivating the Hourly Chime
  • Many Aquatech watch models feature an automatic hourly chime. This can be inappropriate and inconvenient in many situations. To deactivate the hourly chime on an Aquatech watch, simply press and hold the "Lap/Reset" and "Mode" buttons simultaneously. After you have correctly deactivated the hourly chime, the hourly chime indicator icon will disappear from the watch's main screen.
  • Best regards. Jewel
    Sep 18, 2010 | Watches
    Mid Size Sports 1440 Black Nylon Strap Watch: hi i forgot how to set the time on my timex 1440 s...
    You can easily change the time of your Timex watch by following the steps below.
    1. With the time and date showing, press the top left button.
    2. Press the right top button (this sets seconds).
    3. Press the bottom left button. This flashes the hour; press the top right button until you have the correct hour (there is no symbol for am, pm will show if pm).
    4. Press the bottom left button, minutes flash. Press the top right button until correct minutes.
    5. Press the bottom left button, month flashes. Press the top right button until correct.
    6. Press bottom left button, date flashes. Press the top right button until correct.
    7. Press bottom left button, day flashes. Press right top button until correct.
    8. Press bottom left button, time format flashes (can be set to 24 hour clock). If correct, you're done. Press top left button if you're done (can be pressed at any step if you're finished).
    To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
    Hope it helps.
    Thank you for using FixYa.
    May 18, 2010 | Timex 1440 Nylon watch
    CAN YOU EASILY EXPLAIN HOW TO SET ME TIMES 1440 SPORTS WATCH. SINCE TIME CHANGED WE ARE UNABLE TO SET AND CANNOT FIND INSTRUCTIONS THANK YOU
    Hi garysuzie,
    To set the digital time and date on your Timex, please follow the steps below.
    1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
    2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
    3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
    4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
    5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
    6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
    Hope it helps.
    Nov 03, 2009 | Timex 1440 Nylon watch
    I would need to set the time on my timex WR50M watch and I have missed place my instruction sheet. I would need th instructions Thank You
    Hi fuscoromeo,
    Timex Digital Watch
    Hope it helps.
    Nov 02, 2009 | Timex 1440 Nylon watch
    How do you set the time
    This watch has the time set automatically by a radio signal. Leave the watch in a windowsill overnight whichever direction would face Denver Colorado. At 2am, and again at 3am, it will attempt to make radio contact and automatically set your watch! All you'll have to do is to set the correct time zone. Good luck, and let us know if this worked for you.
    Aug 02, 2009 | Casio Wave Ceptor with Analog Black Dial...
    My boss has a Citizen Eco Drive Skyhawk watch . . . how in the world do you set this thing? Every time I try, the second hands goes buck-nutty and spins around the dial a million times, then goes...
    good morning ! to set the Eco Drive Skyhawk citizen watch,full the crown carefully wind it slowly until you reach the correct time after that push the crown back to normal possition, if the hand is turning back to the wrong time just press the button on the up side until the turn to the correct time,thank you ! god bless !...
    Aug 28, 2008 | Citizen Watches
    Watches Logo
    35 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
