My rca 13gp235 was damaged in the storm it had blown a fuse and two diodes in the power supply. i changed them out and the tv will now turn on and off continuosly it will not light up the screen but it will show the three colors of the guns just before it turns off and then starts back up again.
  • Vernon Johnson
    Vernon Johnson Jun 04, 2011
    yes this helped solve my problem in the chip
  • 11,800 Answers
Something else was fried - judging by what you describe it appears that the deflection units no longer receive the synchro signal. This is caused by a malfunction in the jungle circuit, you will need to check all the voltages on the supply to make sure all are on and then the circuit itself.
Also check for the presence of the high tension on the tube.
Posted on Jun 04, 2011
Tv wont turn on after storm
test the power switch for open or defective 2) test the diode in power supply 3) test the fuse and replace it.
God bless you
Jul 11, 2013 | RCA Televison & Video
19 in lcd sharp keeps blowing fuse
check the primary section of the powersupply mostly diodes and transistors inside and alo there filters.
Feb 06, 2013 | Sharp 32R-S50 32" TV
RCA DVD Home Theater System popping noise now wont turn on
if no any power indicator the first place to be check is the power supply where in the fuse get blow. if the fuse blown with darkened color that was mean has shortened line, might the amplifier circuit get damaged that cause of popping before it totally down.check for bad amplifier ic and shorted diodes.
Jul 26, 2012 | RCA Rtd315w Dvd Home Theater System...
My fuse blew in my Samsung 53" Plasma TV. I changed it, but it's blown again? What should I do next?
The fuse blown because theres a short circuit connection in the PCB power supply of your television.Please check the power supply inside,remove the back cover to see the power supply section.unplug first to avoid electric shock.Will you check the bridge type diode first.If the bridge type diode or diodes is shorted the fuse is always blown.Using digital tester check diodes,regulator transistor,and other transistor around the power supply.
Jul 16, 2011 | Televison & Video
Ref: Philips LCD DVB 26"
You have a diode arrangement in your power supply that converts the AC power to DC power so that it can be stepped up to operate the high voltage power supply of the set. If those diodes are blown, which happens frequently in a storm, then you have no voltage to your high voltage. You are going to have to check that diode arrangement by making a continuity check both ways on each diode. A diode blocks voltage one way but lets it pass the other way, thus producing a DC voltage.
Feb 03, 2011 | Philips 26PF5521D 26 in. HD-Ready LCD...
Power went out during electrical storm. tv never
it is problem power supply some of components are demage such as capacitor or diod is bad. You go to a service centre and repear it by a good technician
Nov 22, 2009 | Panasonic PT-47WX53 47" Rear Projection...
I had an electrical storm and my Advent TV will not turn on. Could it be fried? Is there a reset button? model Dv2418A
If you had TV on True surge protector and all other devices are still in the mix you should check out TV's power board for obvious damage or blown fuse(s).
Aug 22, 2009 | Televison & Video
56'' RCA WON'T POWER ON AFTER STORM
your tv may have a damaged circuit board - the only other cause might be a blown fuse, check the manual for fuse locations.
if that dosnt work you will likely be in need of a tv repair man.
Aug 06, 2009 | Televison & Video
RCA TV blown fuse
Hi
you have bad Rectifier Diode or Ic regulator.. check first the unregulated power supply before you go to regulated power section! then check,.
Thanks!
Likha
Oct 23, 2008 | RCA F27242GY 27" TV
NO POWER, Yes blown fuse.
Was this the 220 ohm in the power supply??? and if the 5 amp blew right away then it probably took out the bridge rectifyer with the power surge that comes alog with hurricane damage to the power lines as I used to live in florida and repaired lots of sets damaged from storms!! After you check the bridge rectifyers I would start looking to find any other shorts. First measure across the ac line with the fuse replaced but not plugedf in . If its shorted check what I mentioned before if its good after you replace the shorted parts you maybe in luck. need more assistance go to sams photo facts download a schematic and we will trouble shoot this together if you post it here so i can look at it. good luck
May 02, 2006 | RCA P52929 52" Rear Projection Television
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
