Question about Uniflame Endless Summer Patio Heater
Need spare parts for table top patio heater eu 60300 heat reflector domm and flame emitter where can these be bought
Hi , my table top patio heater does light initially but when you release your hand to the "higher burn activation i.e small flame to big flame" heat instanly disconnects . If anyone can give...
YOU WILL SEE A PROBE THAT IS IN THE FLAMES PATH, MAKE SURE IT IS GETTING GOOD CONTACT WITH THE FLAME, YOU MAY NEED TO TWEAK IT
Jun 15, 2011 | Garden
I have an endless summer 92000 table top propane heater. Lights fine, but the flame does not burn at the edge of the burner. Instead, it only burns in the very center of the burner... much like a Bunsen...
Actually, it's a gas pressure issue. But, it's fairly easy to solve. First, you need to be sure that your LP Tank has a sufficient amount of gas. If it does, turn the propane tank valve OFF. Disconnect the hose from the tank and wait 5 minutes. Then reconnect the hose to the tank and turn the valve ON VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open, light the burner as you normally do and turn the burner flames to HIGH. Has the burner flame returned to normal? If so, you solved the problem. Just remember to always turn the tank valve ON very, very slowly.
If it didn't solve the problem, you will need to replace the heater's hose/regulator assembly. Generally, i's the same type that a gas grill uses. So, it won't be hard to find one.
Hope this helped to troubleshoot and solve your problem. Please let me know.
Apr 30, 2011 | Endless Summer 92000 Table Top Patio...
Want to replace heater burner screen were can I find part number or style number and where to oder from
Flame emitter screens are supplied in different sizes, best to remove the old one and measure the diameter first. If UK based the most common one is 27.5cm flame screen , other types are harder to find.
Jan 10, 2011 | Rta International Patio Heater
The heater will not stay lit unless you hold the button in. Thanks, Susan
Try cleaning the thermo coupling, sometimes soot will cover this and it cannot detect a flame, light abrasive sandpaper will work. ( The thermo coupling is what the pilot flame touches
Jan 04, 2010 | Stainless Patio Heater - Steel Outdoor...
Table top propane heater: tank freezes, fire goes out
I have a table top heater and was wondering why I have flame shooting out of the top of it when I should have like a blue flame, what can I do
Dec 14, 2009 | RTO Bernzomatic Brushed Nickel Patio...
Need parts: pilot assembly and thermocouple
THe thermocouple either has 2 wires or a coppr tube going to the gas valve. They can be bought at a good hardware store or a plumbing supply. The length of the wires or copper tube will be the determining factor as to which one you need. As these thermocouples, when heated generate a small electric charge tha keeps the gas valve open. Should cost no more than $10-15 USD
Oct 10, 2009 | Berkeley Forge G-PH001PSS Open Flame Patio...
My patio heater does not heat up properly
you need to replace the pressureregulater or have it ajust if it is ajustable thanks from gilles
Mar 14, 2009 | Rta International Patio Heater With Table
RTA International Patio Heater Won't Burn Properly
I would check the burner is not blocked and check the injector as well.
May 06, 2017 | Rta International Patio Heater With Table
Uniflame Endless Summer Patio Heater Logo
Top Uniflame Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you an Uniflame Pool and Spa Expert? Answer questions, earn points and help others
