Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Ihave a yth2448 husqvarna lawn motor. mower stall out as soon as i engage it. i have noticethe battery is discharging even when mower is not engage. any suggestion. i justv replaced the starter and secondary deck belt
    President:
  • 3,074 Answers
Check the belt as it bound, if you do not think so then take it off(the belt) and engage the PTO if it does not die then it is: the belt, pulley, or blades are/is the reason why it is stalling Tim
Posted on May 29, 2011
Why I can't keep the electric clutch engaged after 10 minutes when I first start cutting.
sounds like you have a frayed wire going to the clutch . it too should be 12 volts full time .
Jul 23, 2015 | Husqvarna Garden
Husqvarna riding mower, (Model: YTH2448) won't turn over
turn on device and wait for response inspect every component for malfunction
May 13, 2013 | Husqvarna Garden
I have a yth2448 , and when I engage the mower blades the elec. clutch is drawing to much electricity (the alternater gauge drops to negative when I pull the knob to engage the blades and its draining the...
Disconsolate the connector from the clutch. Engage the clutch circuit and see if electrical circuit still response as if shorted.
If the response is the same check wiring, switch and relay. Replace/repair defecrive component.
If the response is no problem check the clutch. Inspect the connector at the clutch for broken failed wire connection. Using an ohm meter check for short. The expected resistance is about 3 -4 ohms. If the resistance is less then 1 ohm the PTO clutch is bad. Sorry. It is the solenoid coil has an internal short. Confirm if the clutch is still in warranty.
Check for after market sources for reduced price!
s-l1600-ye4zlyuovxg25rnpc03q42bj-3-0.jpg Hope this helps?
Jun 23, 2017 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Husqvarna CTH180XP rideon lawn mower 42" rear
Hi Sue and welcome to FixYa, I am Kelly. You have been quite lucky to get 7 years out of your battery. Given the age of the battery that is currently installed this is most likely your problem. You have voltage but very little amperage due to thinned out battery plates.... (
Let me know how it goes.
Thanks for choosing FixYa,
Kelly
Aug 09, 2011 | Husqvarna Garden
Yth2448 riding lawnmower blades will not disengage
My craftsman lawn mower will not engage the blades
Jun 08, 2010 | Husqvarna Garden
Llubrication chart for husquvarna riding lawn mower with trans axel . YTH2448
I googled yth2448 manual. A site called ubermanuals.com it came up with an operator's manual you can download.
Hope that helps.
Good Day.
Oct 26, 2009 | Husqvarna Garden
Husqvarna Mdl YTH2448 Riding Mower - Electric PTO Not Working
It sounds like your charge system is not working. If you jump the battery the engine will run with a weak battery but the pto clutch needs a strong battery to stay engaged.Try this to test it,after you jump it leav the jumper cables hooked up and try to engage the blade clutch,if it runs it is either a battery that wont take a charge or a charge system not working. If you put a volt meter on the battery while the engine is running and the voltage is 13 volts the charge system is working and the battery is bad.
Jul 31, 2009 | Husqvarna Garden
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
663 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
