Question about Boating
1957 evinrude gas\oil ratio need to know - Boating
  • 608 Answers
Hi, 50 to1, regards Phil.
Posted on May 29, 2011
I have a 1998 model E25RMECA I NEED TO KNOW WHAT TYPE GAS TO USE IN IT. AND IF IT IS 2 CYCLE OR 4CYCLE.
I found a mixture of sites for the information
one owner of a 1998 25 hp evinrude says that it is a 2 stroke with a fuel mix ratio of 50:1 as 25:1 is a bit smokey
another site says that the recommended octane fuel rating is 87 although it might run better on 91
best advice is to find an evinrude service dealer and get the right information as the later 25 hp units are etec engine which will be 4 strokes
Oct 23, 2015 | Clymer Evinrude/Johnson 5-70 Hp...
Doesn't seem to use oil? Oil reservoir never seems to go down?
The fuel to oil ratio should be 50:1, which means for every 50 gallons of fuel you use, you should use 1 gallon of oil.
You should see some smoke haze at starting and during running.
Having run an Evinrude that had had the auto pump disconnected in favour of pre-mixing fuel, I would take the boat to a marine engineer to check the pump and delivery. You know it is pretty disastrous when all the oil is burned out.
Sep 10, 2015 | Evinrude / Johnson 135-150-175-200 HP...
Evinrude outboards
Johnson and Evinrude carbureted 2-stroke outboards since 1964 require a 50:1 fuel to oil mixture (2%) on engines without an automatic oiling system - 6 gallons of gas to 1 pint of outboard oil.
Aug 30, 2014 | Garden
What is the oil to gas ratio in my 4 horse Evinrude< Model # E4BRHCOB Ser # B101702
50:1 since the late 60's
Too much oil will gum up the rings, smoke too much and foul plugs. Use ONLY major outboard manufacturers oil, Mercury, Yamaha, Johnson/Evinrude TCW-3. They work the best, and no alcohol fuel.
Jul 11, 2014 | Sierra International 18-3090 Marine...
Fuel mix ratio for 1939 evinrude 3.3hp motor
If you use synthetic or newer oils, follow the recommendation of the oil manufacturer.
Being from 1939, a 2 stroke engine would have been designed to run leaded gas and a very unrefined oil that would burn easily in the combustion chamber. Today's gas and oils aren't even close to what they were in 1939.
If you use a synthetic oil, the mfg's recommendation is usually something like 50:1.
Jul 21, 2010 | Boating
Oil weight to use for 1989 evinrude 2 stroke 90 hp outboard motor
The oil is mixed with the gas, just buy 2 cycle engine oil and follow ratio mixture
Sep 29, 2009 | Boating
Missing operators manual for Evinrude 2 hp outboard motor
Your best bet is ebay for a replacement user manual. Take a look around, you will come across one... For the meantime, gas oil ratio should be 50 parts gas to 1 part oil, i.e. 50:1. General care: Dont go full throttle for any length of time. Cruise of 3/4 throttle... Always flush engine after use in saltwater, including washing down exterior. Keep spark plugs in good order and check prop for fishing line wrapped around in near the prop hub. Otherwise, get a yearly service and have them check the water pump and replace as needed, get it tuned etc and gearbox oil changed.
Jun 15, 2009 | Boating
Oil to petrol for 5.litre can
the fuel to gas ratio should be 50;1 50 parts oil to 1 part fuel
Mar 26, 2009 | Water Sport
Boating Logo
124 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
