Question about Sony DAVHDX589W Theater System with Wireless Speakers
No surrond, it wants me to connect calibration mic, what duse that mean. I put t all front on the speakers then thy all come on.
  • 643 Answers
Usually the rear speakers dont have audio unless something goes from front to back. You could also try some of the different sound fields to get a simulated surround effect. Digital sources will give you the most accurate sound field. Try a bluray dvd player. Hope this helps.
Posted on May 29, 2011
Sub is too loud
While looking at the Sony Home Theatre System screen, push the display button to get a menu. Before this will work, you have to push the DVD/CD button on the remote (can't get the menu if the source is on TV/Cable). Go down to custom then navigate to the bottom option, which is speaker setup. Go to Level Front then go down to Subwoofer and press enter, then change the setting to your liking (1 is the most quiet, 6 is loudest). On a seperate topic (has nothing to do with adjusting volume), I would also put the calibration mic (included) in the designated port on the front of the system and do the auto calibration while holding the mic in the general area where your ears will normally be. It'll adjust outputs of all speakers according to the distance of the speakers to where you held the mic. To start this, push display, go the bottom option again, but this time choose quick. Push the enter button 4 times to skip the other stuff, then click on yes whenever you have the mic plugged in and have it positioned in the center of where everyone's ears will be.
Jul 31, 2012 | Sony DAVDZ170 DVD Home Theater System
Have installed the LG model: HT 503TH and the two rear speakers and the center speaker not working though connected correctly. What can i do?
your settings are incorrect. u i dont know the model but u should slect surrond sound mode . some units will display 2 speakers and a bass spk meaning you are in 2 channel mode which is where u are now. press setuop on your remote go to speaker setup and change it to the other option it gives.
Jun 05, 2011 | LG Audio Players & Recorders
Not all the speakers working
Open your audio control panel and set it to 5.1 surrond sound. Not all speakers will work unless a dolby surrond sound signal is being sent out. There will be a pseudo surrond setting which will emulate the 5.1 for you in the audio control panel
Mar 03, 2011 | Logitech X-530 Computer Speakers
How to connect a mic with yamaha rx-v461
hi,
for connecting a mic to ur receiver, u need a micro phone amplifier. connect the microphone amplifiers out put to any of the analog input of ur receiver( cd,aux). if u need information on connecting calibration mic then feel free to contact.
ok
Dec 22, 2010 | Yamaha Audio Players & Recorders
I have a Dell 5.1 surround system that I bought for my computer. It has three cables, yellow, black, green, that connect to make it a single jack for the computer. I would like to hook up this system to...
well you can connect white and red to green connector(Front Speakers) the yellow connector is subwoofer speaker and the Black connector is for Rear Speakers) is not connected. The Tv dont have any Surrond decoder so to have full surrond needs surrond decoder
Jan 08, 2010 | Audio Players & Recorders
The front 3mm port is disconnected and I don't know where to hook it back up. I can't tell from the manual.
The front 3mm ports are for mic input / headphones output. The pin connectors are as follows. You need to use the JAudio header, which are in the lower-right corner of the motherboard closest to the front of the case when it's installed.
This header has 14 pins, and allows user to connect the front audio out put cable with the PC front panel. It will disable the output on back panel audio connectors.
Within this header, pin 1 is in the lower left corner, and pin 14 is in the upper right corner, like this:
2 ... ... ... 14
1 ... .. ... 13
The pinouts are:
1 Mic in/center
2 Ground
3 Mic power/Bass
4 Audio power
5 Right line out/Speaker out Right
6 Right line out/Speaker out Right
7 Reserved
8 Key
9 Left line out/Speaker out Left
10 Left line out/Speaker out Left
11 Right line in/Rear speaker Right
12 Right line in/Rear speaker Right
13 Left line in/Rear speaker Left
14 Left line in/Rear speaker Left
Aug 27, 2009 | Biostar P4M800-M7A Motherboard
I need help with my surround sound!!
The calibration mic thing is to balance the sound evenly on surround sound systems, it replacles the older systems "TEST TONE" speaker setup, in other words it will balance each speaker say in a 5.1 setup to adjust the level output so the listening position is not overwhemled by say the rear surround speaker overriding the front left & right speaker or the most critical the center speaker. The calibration mic uses computer tech to make it easier for the user, no sound pressure calibration is needed as with the test tone setup mentioned earlier. The wireless speaker situation could be possibly waiting for the calibration confirmation, Read any user manual information if available.
Jan 25, 2009 | Sony DAV-DZ100 System
Need help understanding microphone
as described in the owners manual, set the microphone at the primary listening position at ear level, prop it up somehow, a camera tripod works well, plug the mic into the receiver front port, near and under volume dial, and follow instruction on the receivers screen.
Jun 04, 2008 | Onkyo HT-SR800 System
Front panel how too
Hi slider1958,
You want to connect the new case's front sound & mic.
Just about every case will come with a pre-assembled connector for front USB's & sound & mic. Your board has a set of ten pins used just for this. They are loacted just under the boards rear external sound / mic silver housing. Noted in your manual on pg. 15. Named AUDIO1.
def37da.jpg Notice there is one pin missing. Line your case connector to match.
The manual is uncleare if you are able to use both rear speaker & front speaker at the same time. I would think not. Newer boards with HD do allow this.
Good Luck & Kind Regards.
& please vote.
Mar 18, 2008 | Intel Motherboard
Calibration mic problems
I had the same symptom on a SONY DAV-DX375. The problem was I didn't have the mic plugged in far enough. The receptacle is very tight even though it is very tiny. Make sure to push plug in until the plastic part is against the front panel. It sounds obvious, but I was surprised how much force it took to seat the plug.
Aug 26, 2006 | Sony DAV-DZ100 System
Sony DAVHDX589W Theater System with Wireless Speakers Logo
96 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
