Question about Tecumseh Air Filter Assy 33268 Generator Chipper 8hp
My craftsman 8HP chipper/vac (attached to my John Deere riding mower) is shooting out white smoke big enough that my neighbor sees it. The engine still runs, but a big chuck-chuck-chuck noise when the smoke comes out or like 5 seconds or so and then back to normal for about 5 seconds or so and the smoke repeats. What seems to be the problem? We bought this without a manual. And didn't know where to pour the oil (SAE 10W 30). We poured it in that long tube (where you take out the oil metal stick out and check the levels). Now I'm beginning to wonder that caused the problem. Are you supposed to pour the oil in the same tank as the gas tank?? Help, help!!
  • 78 Answers
You may have overfilled the oil base. Make sure the unit is sitting level then measure the oil. The oil does go into the same tube as the dipstick.
Posted on May 18, 2017
4 Suggested Answers
  • 472 Answers
SOURCE: have a troy bilt that was just given to me - Clean
Posted on Oct 21, 2009
SOURCE: Troy-Bilt Chipper/Vac 5HP gas leaks out the carburetor
this problem sounds like a stuck float or the needle valve that attaches to the float is not properly seating in the carb body.Remove the filler bowl from the carb body and insure that there is no debris in the float needle valve and also if it is a metal float,make sure it does not have a hole in the float.After cleaning the needle valve, reinstall the pin that holds the float and make sure the float moves up and down with the needle valve seating in the carb body. Reattach filler bowl insuring that it does not interfere w/the float.Hopefully this will solve your problem. good luck Tom Murphy
Posted on Nov 03, 2010
  • 66 Answers
SOURCE: 13 hp tecumseh riding mower won't start unless gas is poured into carb. removed the bowl from carb has a wire snap holder float and needle and seat works OK and all passageways seem to be clean
remove the bowl again and get the centre jet out and lok very closely use a jewlers eye piece you wll find a passage that is plugged on the side of the jet look around it you ll see some sign of a hole that is not clear through its pretty small use a welders torch cleanng tool with various size rods use very thin one dont make the hole bigger
Posted on Oct 10, 2012
Testimonial: "thanks for the ideas on fixing my problem I'm going over to my neighbors on Sunday and I'll try out your suggestions thanks again Al"
Spark plug gap on 8hp
20 thou or .51mm
Specifications - John Deere
  1. Cached
  2. Similar
Model Series 121602, Intek. Horsepower 5 kW ... Spark Plug John Deere M78543, Champion RC12YC. Spark Plug Gap 0.51 mm (0.02 in.) ... JS63 and JS63C. John deer model 63 Google Search
Oct 10, 2016 | Garden
Why is my john deere d140 having white smoke coming out of engine
If white smoke is also coming out of your exhaust oil is leaking past the piston rings into the combustion chamber and is being burned along with the fuel. If its not coming from the exhaust it may have been overfilled and oil could be leaking out and burning when it comes into contact with the engine.
Aug 30, 2014 | Garden
J power and smokes white
Possibly a head gasket problem (as the head heats up it warps slightly, allowing coolant to seep into the cylinders, which is the source of the white smoke--steam) Is the motor using coolant?
Aug 17, 2012 | John Deere 420,1020,2010,2020,2510,2520...
14.5 horse I/C ohv with oil
sounds like the needle valve and seat in the carb is bad
Jun 02, 2012 | John Deere Garden
No spark to the plug Kohler 8hp lawnmower engine
Check ingition switch, check battery voltage 12-12 1/2 volts,check in run position same voltage, check in start position same voltage
We've check switch first. If not problem we've check the points for proper voltage and opening and closing.
Jan 17, 2012 | John Deere Garden
Hello my name is John. I have a 345 John Deere lawn tractor. The problem is that it starts idles rough won't idle up and does not run strong enough to move the mower. It just chugs and puffs white smoke...
345's have a habit of the choke sticking at the carb.Another problem they have is the fuel pump diaphram will crack and allow your engine to fill up with fuel,to much fuel in crankcase will end up past the rings when not running and smoke pretty bad when fired up.
Jun 20, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Mower smoking and running rough
Check the gas you put in, it sounds like it had water in it.
Apr 26, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Craftsman 6.5 Chipper vac
I have the same problem with no manual. You can go to & type in your model number & if it is in thier archives they will send a manual to you for free. Unfortunately they have not been able to find mine. Good Luck.
Nov 07, 2008 | Craftsman 6.5 Hp Chipper Vac
Tecumseh Air Filter Assy 33268 Generator Chipper 8hp Logo
1,478 people viewed this question
Top Tecumseh Heavy Machinery Experts
Level 1 Expert
Are you a Tecumseh Heavy Machinery Expert? Answer questions, earn points and help others
