Question about Microwave Ovens
Lamona double oven hja4560 ,the fan for the top oven seems to be on all the time,can only stop it by turning off at the wall and this loses the clock
Skill Will
  • 53 Answers
SOURCE: Roper Double Wall Oven
hi,
sounds like you may need new hindges, unfortunatly they may not be available any more, it may be time for a new oven.
Posted on Mar 23, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: my lower oven does not work; top oven works fine
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Thereshould also be a "mini-manual" (tech sheet) hidden inside the unit behind thecontrol panel or hidden inside behind the back cover, etc., and it's very helpful when troubleshooting, testing, and locating components.
Posted on Nov 25, 2008
blueextc3221
  • 15935 Answers
SOURCE: Hi...I have a Kenmore countertop microwave oven,
It appears your Controller board has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
KevinWhite
  • 1902 Answers
SOURCE: Since using self-clean the wall-oven
Hello & Welcome to FixYa
This is a common problem that occurs after few years when the self cleaning is used. This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then the problem is with the door switch. Please get back to me if you have any other questions.
Kevin
Posted on Jun 09, 2011
espressonist
  • 1711 Answers
SOURCE: I need a repair manual
We have here the link with all parts diagrams of your model and many other service informations. You can also find any part you may need and order it online
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=232287&diagram_id=190571#d190571
You can use the wiring diagrams and find where you have the wong wire connection since this how you have this mulfaction
Posted on Jul 23, 2011
How can I reset clock on Lamona HJA7030 microwave. I have followed instructions in manual without success
Press the clock button for 3 seconds: the hours digit will flash. press the +/- to set hour. Press the clock button again: the minutes digits will flash. Use +/- to set. Press the clock button again. Done....
Oct 29, 2017 | In Microwave Ovens
Kitchenaid microwave mondel #KBMS1454RSS seems to have a short somewhere
see the information attached and test the main component for SHORT. God bless you
Sep 24, 2012 | KitchenAid KBMS1454RSS Microwave Oven
The microwave does't make any noise ,,,but the count down on clock is working ...light is working but no fan ...or huming noise ...what could it be
HELLO.
The likely thing to be is that the microwave fan is faulty.the solution is to replace the fan.
Needed instrument:Phillips-head screwdriver.
Instructions on how to replace the fan is detailed given below.
    • 1. Unplug the microwave from the wall outlet to prevent an electrical shock while
    • working on the microwave oven.
    • 2 .Remove the screws holding the fan shroud to the top of the microwave oven. Using a Phillips-head screwdriver, turn the screws counterclockwise to back them out of the panel. Set the screws in a safe place so they will be available for installing the new fan.
    • 3.Slide the fan shroud--also referred to as a damper plate--forward, toward the front of the microwave, to remove it. Set the shroud to the side.
    • 4. Lift the fan assembly out of the microwave. An electrical cable and plug is accessible once the fan assembly is out of the way.
    • 5. Unplug the electrical connector from the fan and fully remove the fan assembly.
    • 6. Set the new fan assembly close to the top of the microwave to facilitate plugging the new fan into the microwave's connector. Plug in the fan assembly.
    • 7. Position the new fan in the same orientation as the old fan's before its removal. Lower the fan assembly into position.
    • 8. Slide the fan shroud in place and install the screws to secure the shroud.
    • 9. Tighten the screws with the Phillips-head screwdriver by turning the clockwise.
    • 10. Plug the microwave oven into the wall outlet and test the new fan installation.
Thanks
Sep 20, 2011 | Haier Microwave Microwave Oven
Won't turn on after disconnecting the power code from the wall socket,
Press stop / cancel
Then press Clock
Enter time
Press clock.
It should now be working normally. If not respond here again and I will help you.
Thanks for choosing FixYa,
Kelly
May 12, 2011 | Whirlpool MH6150XM Microwave Oven
My Lamona single fan oven. The problem is it always flashes to 'auto PO:OO' so the oven does not go on unless it stops flashing and then sets it self for two minutes, sometimes it stays on the flash mode...
can someone please tell me what is wrong with my Lamona single oven it will not turn off. you have to switch it off by useing the switch on the wall if you can help please email me
sarahnichols206@hotmail.com
Oct 17, 2010 | Microwave Ovens
GE Spacemaker Microwave Clock inop
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
You can download GE owner's manuals and installation instructions here.
Oct 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
I have a double roper oven Model #39758B0 Serial # 8Roo896 Problem when turning the top oven on I get an F-5 signal and the oven does not turn on. I need to know how ro fix this problem. Thank you, Rita...
My problem is with a roper double wall oven not a micowave. When turning the top oven on I receive a F-5 signal and the oven does not turn on. I misplaced my manual hoping you can solve this problem or send me the manual.
Thank you,
Rita
Sep 16, 2008 | Roper MHE14XKB Microwave Oven
We are house sitting for friends. They have a Miele Classic, wall mounted combi oven. It has a single dial at the top left of the silver facia. To activate the microwave, I turned the dial one click...
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Please reply back with your brand and full model number.
May 11, 2008 | Microwave Ovens
Microwave Ovens Logo
151 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
