Question about Diamondback Option BMX Bike (20Inch Wheels)
Handlebar stem developed wobble, bike only 3 days old
    Brigadier General:
  • 8,546 Answers
Google this...
"how to adjust a headset bicycle"
These types of questions are best served by search engines and yield immediate answers with video.
Posted on May 30, 2011
Raising handlebars on schwinn ditch 2.0 dn
The above answer is incorrect. The Ditch has what is called a "threadless" fork/stem setup. One cannot raise the stem at all unless there are spacers above it. Raising the stem is also not the only option. A stem with a shorter "reach" may be sufficient. Google "threadless stem riser" to see options for raising the stem. Following is a video with the procedure.
Jun 09, 2016 | Schwinn Cycling
Bike developed a wobble, has side to side movement in front wheel
First check the tire-pressure, then the fork oil; see if the wheel has a loose bearing play.
Speed Wobble - When The Bike Shakes Its Head - Cycling ...
cyclingtips.com.au/2011/.../speed-wobble-when-the-bike-shakes-its-head...
Speed wobble is the term used to describe a quick oscillation of the handlebars ... 2 A scenario seen relatively often is that the top tube of the bike is under-built.
Road Bike High Speed Wobble 1st person view ( Shimmy ...
? 1:27
www.youtube.com/watch?v=hMNFS2ap3fU
Jun 23, 2014 - Uploaded by Aurimas Petraitis
Road Bike High Speed Wobble 1st person view ( Shimmy ) .... causing my bike to be so twitchy on descents ...
Oct 30, 2015 | Motorcycles
Raise handlebars on mountain bicycle
This will depend on what sort of stem you have. Most mountain bikes these days use a clamping style stem that simply grips the steerer tube on the fork. Some will have limited adjustment in that they may have a stack of 2 or 3 spacers that you can place either over the stem or below the stem. This does not give much adjustment. On my wife's bike the stem is actually adjustable similair to this: MEC 110mm Adjustable Stem Mountain Equipment Co op
and might be a good option for this bike.
Sep 18, 2014 | Huffy Granite 26 Women's Mountain Bike
Can't control the handlebars. They wobble.
IF you are saying the wobble is side to side then the main bolt that goes from the handlebars to the fork is loose.
Aug 29, 2014 | Next Kent La Jolla 24" Girls Cruiser Bike
Raise handlebar stem on a K2 Attack Mountain bike
you can't tell without looking to see what is on the bike but if it is a thread-less stem you can try taking handlebar off an then take stem off head tube and turn it a 180 degrees, the two are connecting the opposite things. that should raise the angle of the stem and bring handlebar up. that is a free solution.
Jan 21, 2013 | Cycling
Adjust handlebar height on Schwinn Varsity
I'm answering 7 years later. I have a Schwinn Varsity 2500 Bike made probably in 2015. The Schwinn Varsity Bike is not set up the same way as a traditional bike. I loosened the center compression bolt and the two side stem clamp bolts and it came loose where I can adjust it up or down but, there's nothing to tighten the slack up below. I did some research. My original post here was to add or remove a spacer. I think you can remove a spacer to lower but, I don't think the stem is long enough to add another one. I've seen they sell an extension that you can add-on to make the handle bars higher.
Jun 25, 2012 | Schwinn Cycling
How do you raise the handlebars for the animator first bike by Giant bikes?
David-
To raise or lower the handlebars, first loosen the hex screw on the top of the stem. One or two turns is all that will be necessary. Next, you will need to stand in front of the bike with the front wheel between your legs to brace it, and give the handlebars a forceful twist to the left or right. This action will break the friction of the handlebar stem and the headtube (the headtube is part of the frame where the front forks and the handlebar stem meet...). With the handlebars loosened you can adjust the handlbars up or down. Keep in mind that the stem has only a specific amount of adjustment available...there is a limit to how far it can be extended up, as indicated by a line marked on the stem shaft. Once adjusted to the desired height, check that the handlebars and front fork and wheel are aligned. Tighten the screw in the top of the stem and you're done!
Hope this helps.
DIYpro
May 03, 2011 | Cycling
The front tire and the handle bar are not turning together. When I turn left or right the handlebar is all that moves. The front tire is just kind of "there". How do i get the two connected so...
Depending on how old your bike is there is an allen head or a nut at the top of your handlebar that when adjusted properly tightens the stem of the handle bar. You just have to tighten it down. Most use metric allen wrenches or sockets.
Mar 05, 2011 | Cycling
Swapping handlebars across bikes
Wouldn't it have been easier and cheaper to get the gears replaced on your old bike?
There really isn't enough information here to answer your questions. There are so many variables between the old and new bikes:
Drivetrains compatible?
Handlebar diameters equal?
Stems compatible? (maybe swap the whole cockpit, brakes, shifters and all)
Don't take this the wrong way, but if you don't understand these questions or their implications, maybe you should take your old bike and the new one down to a real Bike Shop and let a mechanic see what it is you have to work with and offer suggestions.
Feb 28, 2010 | Cycling
Diamondback Option BMX Bike (20Inch Wheels) Logo
292 people viewed this question
Top Diamondback Cycling Experts
Tony
Ed Hauk
Ed Hauk
Level 1 Expert
Are you a Diamondback Cycling Expert? Answer questions, earn points and help others
