Question about Welding Tools
My Rubbermaid 300 Gallon Stock tanks are cracked. What plastic welding apparatus and procedure do you recommend for farm use? Thanks, Kim Shaklee birdshak@yahoo.com
  • 659 Answers
Personally I would find someone with a Plastic Welder to fix it or grab a Plastic Welder kit yourself ive done this before myself here is a video on it being used for a kayak..
http://vimeo.com/7931904
Posted on May 29, 2011
  • Wesley Gardner
    Wesley Gardner May 29, 2011
    you can get plastic kits that work really well to add more plastic to the existing
Sealing crack in coffee maker wplastic water comtainer
replace it with anew container is the best fix
however there are plenty of you tube movies showing how to weld plastic
go google and type in -- procedures to heat weld plastic
Jul 12, 2017 | Coffee Makers & Espresso Machines
Is a cracked reverse osmosis RO pressure tank safe to use as is, can it be repaired, or should I get a new one?
If it is plastic you can weld it or have someone do that. Body shops, auto body shops usually have this ability. I weld my own plastic with a tool from urethane company. Do a search for plastic weld tool. A
Decent kit is around $300 and fixes a lot of stuff.
Nov 01, 2014 | Televison & Video
Repair crack in floor of acrylic shower
Hello their is a product called Plasweld,it comes in a handy tube,
Carefully scratch along the crack to allow the weld to come flush with the surface of the shower tray,MUST BE PERFECTLY DRY!
squeeze into the crack and it will find its own level ,this produce actually welds the plastic together
Good builders merchants should stock this item.GOOD LUCK
Sep 03, 2014 | American Standard Home
How do I fix a hole in the floor of a rubbermaid shed?
Go get flexseal... if it's a thin crack, you can use epoxy glue which is very strong. Flexseal is sold at Walmart, General Dollar etc... it's basically rubber/plastic in a can... apply gently, then apply again as needed...
Jun 06, 2014 | Elite Rubbermaid Frameworks Outdoor...
Cracked water heater
Clean the crack up and expose clean metal by sanding it or a small grinder. Use JB weld it is a two part mixture that set's up hard as steel. Any hardware store should carry it.
I have fixed gas tanks,glasses and a few other thing's with it.
The main thing the surface has to be clean so the compound get's a grip to the metal. Since you already have a crack the compound will go into crack to get a inside bond.
You may use a small file or sand paper to open up the crack a little by adding a bevel to groove to expose shinning metal to get acurate bond.
Drain tank and let it dry out before attemping to fix.
They make all kind's of JB weld for different types of applications and Lowes or Home Depot will carry it.
Check out this link http://jbweld.net/index.php
Jun 09, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I have a rubbermaid poly farm cart that needs a new wheel. Where can I find one?
Home centers carry wheels for mowers, wagons, and wheelbarrows. Maybe you can find something that will work or adapt. Good luck!
May 17, 2010 | Garden
Crack in farm house undermount sink Kohler
Possible you could use an epoxy or J B Weld to repair it. I have fixed a couple of gas tanks with JB weld it should work on Cast also . It not to expensive and may be a start for you.
May 02, 2010 | Kohler Nice Cast Iron Kitchen Sink
Crack in left front portion of sway bar. Is it possible to weld? The crack is on the back side of the bar saw it when doing brakes and rotors. How much should I spend on a new/used sway bar if welding is...
my opinion would not to muck about with things like that and replace it with genuine parts that way you know it's ganna last price not sure but would not reconmend welding it don't play with your life when it could only cost like 300 to 400 to save your life
Oct 30, 2009 | 1997 Pontiac Grand Prix
Melted hole in side of rubbermaid stock tank
there is a product called all plastic
i have had my best luck with this product
Nov 29, 2008 | Garden
Plastic radiator repair
I doubt you can actually fix it "yourself", but you can save lots of money by taking it to a radiator shop instead of buying a used or new radiator. They can replace the plastic tank for the bad side, but it is usually the drivers side because this is where the hottest water exits the engine and causes the plastic to crack. I removed the radiator myself and took mine to a shop and they repaired it for $40........cannot repair yourself because the tank has to be crimped on!!!! And radiator "stop leak" products will not work because they are for metal tanks!!!
Nov 21, 2008 | 2001 GMC Jimmy
Welding Tools Logo
119 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
