I was cleaning my laptop keyboard and accidentally popped off the 'N' key, I'm pretty sure the brackets are still intact, but I don't know how to reattach it, could you explain how please?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 324 Answers
Hello and welcome to FixYa,
Carefully remove the cap from any other working key so the key retainer stays connected to the keyboard.
I was cleaning my laptop - keyboard-key-repair-2.jpg Take a closer look at the key retainer, it's connected to the keyboard at four different points. Assemble the disconnected retainer the same way as one on the keyboard and put it back in place.keyboard-key-repair-4.jpg Put the key cap on the retainer and snap the cap back in pI was cleaning my laptop - keyboard-key-repair-5.jpgixya.net/uploads/images/keyboard-key-repair-5.jpg" alt="keyboard-key-repair-5.jpg" class="h_mi" />
It is that simple! They should just 'snap' right back on!
Let me know how this worked out for you. If my solution helped you, please rate this solution!
It doesn't cost anything and only takes a second, but it is greatly appreciated.
KittyTech
Posted on May 30, 2011
I need to remove keys from my keyboard for cleaning
Most keys should 'pop' off but the tricky bit is getting them back on...
If you remove them I would advise taking a photo of the keyboard ... may sound obvious but putting the unfamiliar keys in the right place can be a test on your memory/recall skills to say the least.
1. First up, you need to use a small screwdriver to carefully remove all keys from your keyboard. Then loosen the rubber pieces from each of them and place them separately.
2. Once all keys are removed from your SAMSUNG NP-N145- keyboard, you can either use an ear bud or a cotton swab dipped in water to gently clean the inner regions of the keyboard. However, make sure that you do not use too much water for this cleaning purpose.
3. After cleaning the inner regions of your keyboard you need to start cleaning the individual keys using a light fluid and foam rubber. After cleaning these pieces you need to leave them alone to get dried up.
4. Once the keys are dried up you can assemble them back into the keyboard carefully. Make sure that the rubber pieces too are assembled in their appropriate places.
Regards
Jul 01, 2013 | Samsung NP-N145-JP02US NETBOOK
I cleaned my laptop keyboard and now all of my symbol keys are messed up. I am pretty sure that I hit a button or combination of buttons that caused the problem but I don't know how to undo it.
Ctrl + Alt then Shift and test.
Remove other languages. Go to Control Panel > Regional and Language Options. In Languages tab, click details. Remove extra / other Installed service.
Oct 19, 2012 | Computers & Internet
Broken enter key
enter key on the keyboard?
well,you don't need any expert guide to replace it,all you need to do is shut down the computer, pull the key off from the keyboard gently by hold it on each side with your hand (or it's already taken off)
to put it back on the keyboard,just push it perpendicular
still,if you're not sure to do this by yourself,i suggest you to take it to the notebook center,notebooks hardware is a pretty fragile
Aug 24, 2012 | Sony VAIO VGN-AR630E Notebook
REPAIR ENTER KEY ON KEYBOARD
If the key is intact, position over shaft to match key holes, now press down until you hear a click, that is the indication the key is in place.
Jul 21, 2012 | HP Pavilion dv6000z PC Notebook
Hi, i have a toshiba x205-s9800. my two year old seems to have accidently pressed some keys and disabled the keyboard...please help...
You could have deleted the keyboard in the device manager. If so, rebooting your computer and it will find it.
Are all the keys not working or just some? Take a look at this hint and see if it fits.
http://www1.fixya.com/support/r5966678-letter_keys_now_produce_numbers
I do this for fun & feedback not $$$
Oct 02, 2011 | Toshiba Satellite X205-S9349 Notebook
How can i fix sticky keys on my laptop without taking it to an repair shop
Most keyboards have plastic, mechanical keyswitches underneath the keycaps, and you can probably pop off the keycaps pretty easily (use a small, flat tool and very gently lift up on end of it till you can get a grip on one end of a keycap with your fingers, after which, you can pretty easily lift and unsnap the keycaps from the keyswitches below and see if any foreign matters are present and clean 'em out.
To clean a keyboard, I recommend a used paint brush to dislodge hair and fiber in between keys, a damp (not wet) toothbrush to clean the surface of your keycaps, and a good ******** (don't use a vacuum unless you're willing to dig into your vacuum bag for tiny parts that may get accidentally sucked out!).
Outside of some odd-ball laptops models, most keyboards can be easily found on eBay and are pretty affordable ($10-$15), so I'd look for one on eBay before I start fixing mine - just in case.
Sep 11, 2011 | Computers & Internet
About 2 weeks ago I spilled coffee on the laptop of my Acer Aspire 255D laptop/notebook and quickly turned it over to get liquid out and dried it, wiped it, etc. I have let it dry out and it turns on but...
Check if it has still warranty and if it is covered by the warranty agreement. The circuit maybe moist and will not function due to the moisture wipe it all off then check if all connections are intact. try each key out.
Sep 05, 2011 | Computers & Internet
Some keys on my laptop are hard to press, you must to push a little bit harder before the letter comes up, they are not soft touch anymore. What will I do with that?
You need to clean your keyboard:
Invert your laptop so that the keyboard is inverted over a piece of clean paper: you might be surprised to see all the junk falling out of the keyboard. Briskly blow air between the keys and repeat the exercise several time.
If softdrink or food was accidentally spilt on the keyboard, you may need to very careful and gently lift out the appropriates keys and clean the mess with wet cotton bud. Putting the Press on key caps can be pretty tricky so observe how they are originally fitted.
Hope it helps. Let me know how you go.
Sep 27, 2010 | Computers & Internet
Popped a key off my Notebook's Keyboard
Dear titomb345
Try the following guide.
http://www.laptoprepair101.com/laptop/2007/03/20/key-fell-off-keyboard/
There are no guides available for the DV1000 but this guide will be more than enough to help you through this one.
Regards
Please don’t forget to rate this solution if it was helpful, it keeps us going!
Mar 25, 2008 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
99 people viewed this question
David Payne
David Payne
