Question about Krups 203-42 Electric Blades Grinder
The grinding blade is clogged and will not turn, what is the best way to clean it out?
My Rancilio Rocky Burr coffee grinder w/doser is not grinding the beans they simply remain in the hopper
It is most likely that something is blocking the pathway to the grinder. As the Rocky is a direct drive grinder there is no gear that could be broken.
Try to remove the beans from the hopper and inspect the pathway, move the beans that might be under the 'disk'. If that is not working you might have to open the grinder;
  • remove all coffee beans
  • unscrew the three screws in the bottom of the hopper
  • remove the hopper
Now you can see the grinder wheel and tell if it is turning normally.
This might be a good opportunity to give the grinder a thorough cleaning.
Do not soak it in water, just a stiff small brush (e.g. a toothbrush) is the best tool. And perhaps accompanied by a vacuum cleaner :)
If you have been using very 'oily' beans for a long time they might have clogged the grinding wheels.
Good luck,
Villi
Mar 02, 2015 | Rancilio Coffee Makers & Espresso Machines
Where can I get replacement blades?
http://www.amazon.com/Sunmile-Grinder-Cutting-Strictly-SM-G70/dp/B00M0ST9D4/ref=sr_1_1?ie=UTF8&qid=1417299151&sr=8-1&keywords=Blade+SM-G70%2FG73
Jun 15, 2014 | Sunmile 1.6HP 1200W 8 Meat Grinder UL...
Zero turn cub cadet mower, deck keeps clogging with grass
do you have the right blades for bagging ?is the deck belt slipping?
Apr 22, 2012 | Briggs & Stratton Garden
Bad vibration and noise from saw
Are you sure blade is straight, and mounted on arbor correctly? that's the first thing to check. Or remove blade and 2 arbor plate's and run saw. If you have a vibration after that you have a bearing problem.( rear bearings go bad on these saw's) other they are the best saw for the price. We have about 50 of the 4000 model. hope that help's Never had a vib problem.
Jun 01, 2010 | Bosch 4100 10" Worksite Table Saw
Cleaned the machine and now the grinder does not grind any coffee, it sounds like its grinding but it keeps showing that I need to add beans after it attempts to grind. yes it has beans in it
Did you cleaned the grinder with any fluids? This will not help , the blades got wet and coffee grounds are stuck (cemented) on to the blades.You will have to cleaned the blades and KEEP it DRY.
May 25, 2010 | Saeco 00041 Espresso Machine
Badger 1 1/3 insinkerator not grinding
Hi, Sounds like motor went bad..
Here is a tip that I wrote that will help you to figure out what is going onwith your garbage disposal and why it is not working.
Garbage Disposal Clogged or Jammed heatman101
May 15, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Stopped up garbage disposal. no grinding action when turned on
Hello there:
you will need to make sure that all of the hoses from the unit are free of debris first ok
than if you need to remove the blade assembly and clean out the area around the unit and than reassemble the blades and see what happnes ok if not you will need to remove the entire unit and see what is making the unit malfunction. ok
best regards michael
Aug 27, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Clogged?
I've been having the same problem. I would clean out the burrs and it would get clogged right away. But I found that at the top of the chute where the coffee comes out that there's a flap type device. Mine was clogged with coffee. When I unclogged it it would swing freely. That seems to have helped. You need to use a skewer or long toothpick to clean it and free it. Use a flashlight to see the flap. It looks like it has a weight attached to it and probably swings back and forth as the coffee is ground.
Aug 24, 2008 | Solis Maestro Electric Burr Grinder
Krups 203-42 Electric Blades Grinder Logo
110 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
