Question about Whirlpool Calypso GVW9959K Top Load Washer
Stinky Washer Every time we wash a load this awful moldy smell fills the house.
  • designgirl01 Aug 23, 2008
    We have this too as well as now it won't even work it has several error codes popping up and Sears will do nothing even though there are tons of people experiancing problems with this extremely expensive washer.
We had that problem too...  we ran a load with just bleach (about 1 cup) and white vinegar (about 1 1/2 cups) poured directly into the washer with hot water and it seemed to help, but this does need to be repeated about once a month or so...
Posted on Aug 24, 2008
SOURCE:
I have a front loading washer - have had for 8 years or so. Began smelling moldy smell - noted little stuff around the holes in the rubber seal around the door. Then I began to pull it back and found mold...
you need to wipe down that part of boot seal after every wash,tide has tablets that you stick in the washing machine and run it through and it removes the smell but it will come back if you don't wipe it down.also if you are using to much detergent that will make it stinky and eat the spider gear and if that happens it's new washer time,you hear a loud banging noise when it's in spin.call your local appliance store and ask them for the pack of tablets,it's like washer magic or something like that,good luck.let me know how you make out
Aug 26, 2010 | Kenmore Washing Machines
Do not buy an LG Tromm front loader unless you want stinky, moldy clothes! The first few months, I LOVED this washer, but now I think the machine is possessed by smell demons! I've tried everything, but...
Stinky clothes are usually the result of washing in cold water. Cold water will NOT kill bacteria.
Add one cup of vinegar to the wash before you start the machine - try it.
The vinegar will kill the bacteria during the wash. Your wash will NOT smell of vinegar.
The dryer level of dryness on most auto dryers needs to be set three clicks toward + on most machines. LG is no different.
Apr 02, 2010 | LG WM1812C Front Load Washer
Same problem. Stinky, moldy, gunky. Clothes won't clean.
First take a gallon o bleach pour it in on hot and run,then from know on after washing leave the door open so it can dry out and not mold between loads.
Nov 15, 2009 | Frigidaire GLTF2940ES Front Load Washer
Stinky washer
you will always hear a bit of water in the tub after washing. buy a package of 3 tablets called AFRESH and follow the directions on the package. this product was designed specifically for the problem you are having. also, always leave the door open a little bit after washing. hope this helps.
Oct 24, 2009 | Maytag Neptune MAH5500B Front Load Washer
Stinky, moldy smell on clothes
I agree with your concerns, but, unfortunatly, leaving the door open and emptying the drain trap is all you can do. I would also start washing your laundry with at least a 1/2 cup of borox with each load. This will help with the smelly cloths as well as running the monthly clean cycle or an empty express wash with only bleach.
Jun 06, 2009 | Kenmore Elite 45986 Front Load Washer
Moldy smell
Hi Jewel,
You may want to try some Washer Magic, or similar product specifically designed to clean out washing machines. I personally use Affresh in my front loader and it works very well.
SG
Mar 29, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Moldy smell
try running it throgh a cycle with nothing but hot water and bleach let set for a couple of minutes between cycles with water in it may have to do a couple of times
Mar 29, 2009 | Whirlpool LSB6200KQ Top Load Washer
LG TROMM - awful smell while washer is running
Use the aafesh tablets as instructed, this will clear hoses that have developed some mold, also inspect drain at the wall, these get moldy and as machine runs, smell comes out of there as well.
Jan 20, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
The machine smells moldy...
moldy smell, may not be mold at all, in fact most "moldy musty" smells actually come from user not using proper detergents, you NEED to be using an HE detergent and little amounts of that even. cut back on fabric \softneer if using, www.affresh.com new product to help alleviate this issue
Nov 29, 2008 | Frigidaire Affinity ATF7000E Front Load...
Whirlpool Calypso GVW9959K Top Load Washer Logo
154 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
