Question about Honeywell Programmable Thermostat Heater
My heating/cooling sys. is electric. I just installed the RTH2300. My original stat was wired as follows R-r, G-g, W-c, B-o, Y-y(with yellow jumper to W). The new stat is wired as follows B-o,Y-y,R-r,G-g with the W removed. Do I need to re-run the Y jumper? My fan isnt kicking on in AUTO only in ON position. Thanks for your time
  • wyazgypsy2 May 30, 2011
    I did re-run that jumper..you are correct, it made no fan difference. I did notice that after re-powering the unit the stat diaplayed 85deg. This was way off..I disconnected the jumper and all is working fine now. Im confused but accept the outcome! Thanks.
  • Honeywell Master
  • 43,501 Answers
Yes, I would rerun the Y jumper... but that probably will not solve the fan issue...that fan runs off of the G wire...
Do you have the th2300 programmed for heat pump??? If not you need to go into the advanced setup and re program it to run a heat pump...
To double check that the G is wired right... jumper R to G and the fan should start... if not then there is another problem...
heatman101
Posted on May 30, 2011
  • D. Floyd Kolb
    D. Floyd Kolb May 30, 2011
    Check that all connections are tight....you may have had a loose connections somewhere... also I have had to restart t-stats already because they mess up on the first start up...not unusual...
    heatman101
5 ton goodman package unit not coming on
If you look on the install manual. It says it will work for a heat pump without backup heat. No heat strips.........If you do not have strips the guide says as follows
"PLACE A JUMPER (PIECE OF WIRE) BETWEEN Y AND W IF YOU ARE USING A HEAT PUMP WITHOUT AUXILIARY/BACKUP HEAT." if this dosnt work check the fuse in the air handler you may have blown it if you did not turn the unit off before installing.
Mar 25, 2014 | Goodman Heating & Cooling
Installed RTH2300 themosat, but there is no heat coming out, I have O, R,W,G,Y,C wire for the old one. Thank you.
well the letters go to wire color but that doesnt mean tha last guy did it right. go to the furnace and look at the termail board in it see how it is hooked up there and do the same on t stat if there is a rh and rc use the rh for heat at the t stat if all else fails hook the red and white wire together and that should bring the heater on then start looking at the t stat for your problem.
Feb 15, 2011 | Honeywell Electronic Programmable...
I just purchased a house with brand new furnace wired to a RTH2300 Honeywell thermostat. It only has two wires running to it. I can't seem to get it to work in "manual mode"-where I set it on...
?? Connect Wires 5.
Labels don't match?
If a wire does not match any terminal on the thermostat,
see next page.
Quick Installation Guide
6
Alternate Wiring
If a labeled wire does not match any terminal
designation, see diagram below.
Do not use C, C1 or X wire. Do not use B wire if you already
have O wire. Wrap bare end of wire with electrical tape.
This thermostat cannot be used if your old thermostat had
any two of the following wires: R, RC, RH, 4 and V.
Place a jumper (piece of wire) between Y and W if you have
a heat pump without auxiliary/back-up heat.
?? Connect Wires (cont'd)
Programmable Thermostat RTH2300
7
Set jumper JP1, on the back of the thermostat, if you
have connected a wire to the G terminal.
Incorrect jumper setting: An incorrect setting is
noticeable in a gas or oil heating system. When heating
starts, you will initially feel cold air coming out of the vents
as the fan is running before the furnace has enough time
to heat up the air.
?? Set Heating Fan Control 6.
HG Leave the jumper in this factory-set
position if you have a gas or oil furnace.
HE Place the jumper to this position if you
have an electric furnace.
JP1
8
Set jumper JP2, on the back of the thermostat, if you
have a heat pump.
Incorrect jumper setting: The heat pump operation
will be reversed, i.e., it will cool in Heat mode and will
heat in Cool mode.
?? Set Heat Pump Reversing Valve 7.
O Leave the jumper in this factory-set
position if you have connected O wire to
the O/B terminal.
B Place the jumper to this position if you
have connected B wire to the O/B terminal.
JP2
9
1) Install 2 AAA
batteries on the
back of the
thermostat.
2) Align the two
brackets on the
top of the
thermostat with
the corresponding
slots on the top of
the wallplate.
3) Push the
thermostat
against the
wallplate.
4) Tighten the screw
at the bottom of
the thermostat.
5) Turn power back
on at the heating/
cooling system.
Nov 27, 2010 | Honeywell Programmable Thermostat Heater
Runs cooling and heating back and forth, when colling set at 73 and heating 65 , wont come off 73 degrees , bad t stat ? or outside temp sensor please help thanks chris
Hi, Chris, this is the thermostat for sure. It has a built in sensor on the circuit board that gives the stat the command to do what its supposed to do. From what you are saying, it has to be the stat. Be sure you mark the wires on this stat, if you have a gas furnace with this central unit, the stat will have markings at the terminals like this, Red wire to either the Red R/C, or R/H with a jumper across the 2, a W, white for heat, Y yellow for cooling circuit, and G green for the fan control. The new stat will come with the red jumper installed for you. Now, if you have a heat pump, the terminals will have more wires such as a R, O, B, W, W-1, Y, G, C, and so on. Heat-pump wiring is much more difficult to install the stat as it has to have the same terminals and if they are not terminated right, you will have problems. You may want a pro to wire it in for you only if you have a heat-pump. If its just a standard stat like I 1st said, turn off the breaker and it is simple to install. The voltage is only 24 volts ac. Please don't forget to rate me Chris as I know you will be kind, and I will also be checking in on you to see how it is going. You can also contact me if you need more help by my user name below.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor.
Sep 03, 2010 | Heating & Cooling
How to install a honeywell programmable thermostat
white wire for heat.. yellow wire for cool.. green wire for fan.... red wire power to t-stat.. or white wire to W yellow wire to Y green wire to G red wire to R leave jumper on stat
Aug 22, 2010 | Heating & Cooling
Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Your original wiring configuration seems to indicate that you have an air conditioner (not heat pump) and either a gas or electric furnace. If this is the case you may need a different thermostat for your application.
Apr 21, 2010 | Honeywell Heat/Cool Thermostat
I am installing honywell thermostat rth111/rth221 old thermostat only has two wires red and yellow new thermostat has terminals marked Y,G,Rh and Rc with jumper,W. where do I connect red wire and also the...
The red does go to RC, but the yellow should go to the W terminal, in HVAC W=heat Y=Cool, so aslong as the same wire is on RC on the t-stat, and RC on the unit, and same wire to the W on the t-stat as to W on the unit it should work!
Jan 31, 2010 | Honeywell Programmable Thermostat Heater
I replaced a Lennox DSL-450LX heat pump thermostat with a Honeywell RTH3100C. Everything works except the gas does not ignite when set to emergency heat. The Lennox was wired as follows: W = white wire Y1...
Hi, If indeed you do have a heat pump, there wouldn't be any gas involved as a heat pump runs on freon with a reversing valve and heat strips for aux and emerg. heat. For gas electric operation thermostat terminals are rc to rh with factory jumper. Red wire to either.W to W for Heat, Y to Y for cooling G to G for Fan. If you have a blue, you wont need it unless this is a commercial stat useing a common for the Led lights on the stat. The unit will get its 24volts through R terminal in combination with y,w,and,g. Cant be a heat-pump if you have a gas furnace.Wrong t-stat. You need a gas /elect stat. And on a 24volt programmable t-stat, the batterys are used for the program only.If the batterys die, than you will loose the program on most residential stats. On commercial stats with the common in play, when batters die the stat defaults back to the factory settings.If you had a Lennox heat-pump stat on a gas/elect unit, you need to change it. Someone was using what they had on hand. Let me know if this has helped you.I will be here if you need me. Sincerely,
Shastalaker7
Nov 17, 2009 | Air Purifiers
There is five wires yellow, green, red, white, the problem that we a facing is to connect these wire into the honeywell theromostat RTH3100C1002-0916
yellow is the cool wire, green is the fan wire, white is the heat wire, red is the power wire. these stats should have a 1 letter icon ,r for red on stat y for yellow and so on ,make sure that Rc and RH are jumpered and install batteris if needed
Sep 29, 2009 | Honeywell Electronic Programmable...
Upgrading Thermostat
Looks like your system is a heatpump system and that t-stat will not run a heatpump , you need a t-stat for 2heat and 1 cool systems
Jan 30, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
97 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
