My Sony receiver, model STR-K750P, is showing "unlock" on the screen and I can't get any sound. What do I need to do to get the sound back?
  • 3 Answers
SOURCE: code for sony receiver model str d565 protect mode
If you need support you can log into:
http://esupport.sony.com/US/perl/support-contacts.pl?mdl=STRDG510
for free tech support on sony chat line
Posted on Jun 02, 2008
SOURCE: Protector flashing on Sony AV receiver--Model STR-DG600
Me reicever rite protect some time ,i put the sytem off and a start again
Posted on Jan 25, 2009
mlapres
  • 757 Answers
SOURCE: Sony STR-DG510 hook up with BDP-S560 no sound
The Sony manual for this receiver is not wrong, it is just a little misleading.
It does in fact use HDMI but ONLY for the HIGH DEFINITION video portion of the signal, as output from the receiver to your television. High Definition Multimedia interface carries both audio and video, however, your receiver is not decoding the high definition AUDIO portion of it and passing it through the HDMI, nor is it passing any form of multichannel audio through HDMI. So you can see why the receiver is no longer available for sale from the Sony website. The HDMI connection on your receiver is redundant unless you are not using a multichannel audio format, in which case you would be using either the TV speakers or connect an additional audio cable from the TV's "audio out" back into the receiver for external speakers.
All that should be done is use the HDMI cable from your blu-ray player connected directly to your TV. That will give you your picture, and possibly a better one since the receiver will no longer be in the signal path.
Then connect either a coaxial or optical cable from the blu ray player to the receiver for your audio. You will then be able to have Dolby Digital and DTS surround formats.
Your service person was wrong.
Posted on Jan 18, 2010
Testimonial: "Thank you excellent report spot on with the hook-up. Will buy new receiver. John McMullan."
smarthome2
  • 1114 Answers
SOURCE: Sony STR-GX800ES receiver "protector" blinking - no sound
The most common problem found on FixYa for Audio Video2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jun 13, 2010
dunnbiker
  • 8546 Answers
SOURCE: my sony STR-DE345 amp says "protect" and there is
The manual says it thinks there is a short circuit on the amplifier output side. If it still says Protect after disconnncting all the speakers wires there is an internal problem. Take it to a hands-on tech.
If the problem disappears, you had a short. Attach speakers one at a time to isolate the cause.
http://www.retrevo.com/support/Sony-STR-DE345-Receivers-manual/id/387bh943/t/2/
Posted on Dec 25, 2010
I have a Sony STR-K750 receiver running with a Samsung 50 inch series 6 tv.There is a digital lead running from the Austar receiver to the Sony receiver for sound.I have a Hdmi lead running from the Austar...
Run both audio and video to the tv, then use the tv optical audio out to go back to the receiver. The problem is, when you split the signal, the tv takes longer to decode the hdmi signal =, thus delaying it from the original audio signal.
Aug 06, 2013 | Sony STR-K750P A/V Receiver
Why does my Sony STR-K750P AV receiver automatically switch to Video 2?
Some models of systems will switch to a new source automatically if the source sees a new signal coming on. Try disconnecting the device on your Video 2 to see if this is the case.
I have seen the IC or component(s) in the switching circuits become defective and cause unpredictable or faulty operation. This can also be a fault condition you are seeing.
Apr 02, 2017 | Sony Str-k750p Av Reveiver
Sony digital audio video control center STR-K750P (protection- what is that?) no sound
What is the device code for the Sony STR K750P? I'm tying to set up a universal remote control and need the 4 digit code.
Sep 26, 2010 | Sony Audio Players & Recorders
No sound in DVD mode
when i turn on sony receiver it will not play it just says protect on the screan
Dec 21, 2008 | Sony STR-DE445 Receiver
Sony receiver optical sound "unlock" str-de898
Just fixed it, The Optical cable wasnt properly plugged in on the other end.
Found the fix here:
http://esupport.sony.com/US/perl/model-home.pl?mdl=STRDE945&LOC=3
Oct 09, 2007 | Sony STR-DE898 Receiver
127 people viewed this question
 Grubhead
Grubhead
