Question about Texas Instruments TI-30X-IISTK Scientific Calculator
I have accidentally set the rounding setting to low -- I want to have it display beyond 1/10th. I cannot find how to reset it back to where it was. Thanks for your help. Vicki Nashert
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Press 2nd [SCI/ENG] and select "FLO" for floating decimal notation.
Posted on May 29, 2011
Tip
How to reset your ps3's default settings
you simply turn off the system to start with,
then you hold the ON/OFF button until you hear a SECOND BEEP.
then let go and soon enough, your ps3 should have reset your display settings.
if it turns off, youve held onto the button for too long.
this is useful if you have got a new TV, or if you accidentally messed around with the resolution and display settings.
on Mar 01, 2010 | Video Game Consoles & Games
How do i play a dvd movie in ilo dvdr05 dvd recorder
You may have to connect to a different output until you can change the settings back.
Dec 03, 2014 | iLO DVDR05 DVD Recorder
Forget user name and pass
There will be a manual reset button on the router. It is probably tiny and unlabeled. It may be a little round dot in a dimple on the case (may be near the power button or on the bottom or back) or a tiny hole through which you stick a paperclip tip to activate. This button may need to be pressed for several seconds, to avoid accidental resets. Once reset, your router will revert to default settings. The ID and password will reset to defaults like "admin" and "1111." security will be disabled. You will then need to enter the configuration setup to personalize the name, set a passord, and set up the security protocol. To enter the setup procedure, you will need to access the router's url with a browser (the address will be something like 192.168.1.01; the actual address will be in the router's documentation). Follow the on- screen instructions. These instructions presume some knowledge of router protocols: if you need help, contact the router manufacturer's customer service.
Jul 28, 2014 | Computers & Internet
How do i reset a Bosch fridge freezer after switching it off
usually have to wait about 15 minutes before turning it back on otherwise the compressor will reset itself on and off till you pull the plug out for 15 minutes
Hope this helps. God Bless :O)
Apr 21, 2014 | Refrigerators
I was givin a phone in its locked and i can not get in contact with the person who gave me the phone in i need to get it set back to the defult code how can i do dat
http://www.resetcellphone.com/solution/Sanyo/SCP-2700-Juno
Steps to Reset Settings
Resetting the default settings restores all the factory defaults, including the ringer types and display settings.The Contacts, Call History, Calendar, and Messaging are not affected.
  1. Press Menu (the round key in center)> Settings > More... > Security.
  2. Select Delete/Reset > Reset All Settings and press OK (the round key in center).
  3. Read the disclaimer and press OK .
  4. If you are certain that you would like to restore all the factory settings, press Yes (left softkey).
Steps to Reset Phone
Resetting the phone resets all settings, including the ringer types and display settings.This option will delete all data on your phone.
  1. Press Menu (the round key in center) > Settings > More... > Security.
  2. Select Delete/Reset > Reset Phone and press OK (the round key in center).
  4. If you are certain that you would like to reset your phone, press Yes (left softkey).
Warning!: While reset/restore operation under process, you are advised not to remove your battery until the operation is completed and cellphone restarts otherwise phone damage may occur. *Disclaimer:Performing a master clear/master reset/hard reset will erase all your data (photos,videos,contacts etc) completely and reset all the settings to Factory default. The information contained in this website is for general information purposes only.In no event will resetcellphone.com be liable for any loss or damage including without limitation, indirect or consequential loss or damage. For complete disclaimer notice please visit Disclaimer. The brand names are the registered trademark of respective manufacturers.
Jan 01, 2011 | Sanyo SCP-2700 Cell Phone
Mitsubishi ws-65807 65 inch. The sound is very low, distorted and very scratchy noise. It is not the audio exit, it has already been changed. What else could be the problem and what parts would need...
Hi
Thanks for using FixYa. Please reset the TV by unplugging the power cord for more than 4 hours and plug it back in. Now check that the sound is coming normally from the set. You’ll need to also check these parts---
Breakdown or overheating of some components of amplifier, wiring, speakers, function settings, power supply and sound detector inside the signal IC processors are fine.
Go to the on-screen-display and make sure you are set for stereo audio. Please check that the on screen display is set up for internal speakers and stereo audio. Also, check any other settings that may have gotten disturbed accidentally. Make sure that all the settings are correct and that the internal switch on the back is set right. Use headphones and check if you’re getting sound through them. You’ll need to check that the issue is with the speakers, wiring or the amplifiers.
If still the issue is not resolved then check the audio chips are fine. If you’re using RCA cables then switch to HDMI and vice-versa.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 12, 2010 | Mitsubishi WS-65807 65" Rear Projection...
I have a 6 disc changer that goes with this but after installing the display reads no magazine? any ideas?
Unplug the changer, let it set for about 30 seconds then plug it back in. The round cable on the side, it has a slide clip. Push in on the cable and pull back on the larger ring with the arrow on it and it will come out. If it still persists, slide open the magazine door and look at the bottom right corner of the chasis, there is a small dot, that is a reset button, an inverted bump. Push it in with a pen and hold for 3 seconds, that causes it to reset. Beyond that, it would need service. Hope this helps
Aug 17, 2009 | Sony XR-CA650X Cassette Player
Display shows nothing
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes. Then let us know if the hard reset does not fix it.
Also, Please reply back with your brand and model number so we can help you.
Mar 02, 2009 | Microwave Ovens
Texas Instruments TI-30X-IISTK Scientific Calculator Logo
65 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
