Question about Dryers
Hi I have a siemens extraklasse 753 and the dryer has stopped drying, I have checked the feed on the heater itself and the reset switch and found no live feed, I have checked the sump pump and switch are working and all wire connections seem to be intact
    President:
  • 3,074 Answers
Http://www.applianceaid.com/whirlpool-dryers.html#no-eheat
Posted on May 29, 2011
Is this a design fault or something we can mend?
on top of the dryer unit
is two thermal switches
then go on and off with the temp {and dryer motor speed}
so could be a bad dryer motor
but if it does not heat up to dry
then most machine have 'reset able' thermal switches
ie most machines have two sets
two can be reset for overheat
and two are a fail safe
so check all four switches
to reset the reset able ones
then press the little plastic post in the center of the switch
otherwise with the thermal protectors you need to replace them
after clearing the issue causing the dryer to massively overheat
usually someone has just over loaded the drum
and the drying heater has tripped the thermal cutouts
and not the fail safes
so press the centers of both the thermal cutouts
and try again
good luck
and please post your results
Aug 21, 2014 | Siemens WK61420GB Front Load Washer /...
Siemens ultra sense dryer stopped working, found broken belt, replaced belt but dryer still won't run!
-There are couple things that cause a dryer not working:
-Thermal fuse.
-Heater element.
-Timer switch.
-Door switch.
-start switch.
-Or the motor.
Check these components.
Good Luck
Mai
Dec 05, 2013 | Kenmore Elite HE4 Electric Dryer
My siemens dishwasher runs for about 4 hours what's the problem?
Could be the instantaneous water heater, the power module or both.
Or it may not be taking sufficient water to allow the heater to turn on as it has a boil dry safety. Check the following to rule out water shortage
if you remove the lid (no screws on lid, there are two clips at the rear, release them and the whole lid will slide back and then off) and take the two t20 screw off the left side panel at the front you should check the pressure chamber and its hose are not blocked. Use the link and go to page 4 to see where they are located, parts 480748 and 298556.
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=SE25A266GB%2f27&ESHOPTYPE=S
Best of luck.
Jul 10, 2010 | Siemens 24 in. SE25A266 ExtraKlasse...
Dryer does not start after selecting a program
How old is the unit?
This was my experience...
http://www.fixya.com/ThreadAsker.aspx?thid=1179929#
Feb 09, 2010 | Siemens Dryers
Siemens Extraklasse dishwasher - Salt light on
You can buy from any supermarket & it goes in container on left hand side of the dishwasher base(large knurled lid unscrews)
Mar 08, 2009 | AT&T Siemens S46 GSM Cellular Phone
I have a Siemens Washer/Dryer WDI 1440. The problem is that when I put it to dry, no heat is produced and my clothes are staying wet. What do I do? Many thanks
take top off. you will see dry manifold running across the top with various stats mounted on it. one of these stats will be resetteble ie with a small knob in middle. press and stat will reset. also check continuity thro the dryer heater and the other stats.
if a resettable stat has popped out, check also for lint blockage in the dryer duct
Nov 17, 2008 | Siemens Dryers
Bosch nexxt 500 series dryer
I just had the same problem, motor runs but no heat. I had a fun time figuring out how take the front panel off, hint the rubber seal comes off easily. It looks like mine tripped the resettable over heat sensor. So far so good.
Jul 30, 2007 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryers Logo
234 people viewed this question
Top Dryers Experts
