Question about Whirlpool Dryers
Whirlpool dryer MOD: GEW9868KQ2 - touchpad not working
  • 3 Answers
Sounds like the control panel may be dead. If you cannot get any lights to come on at all on the front panel, its probably a goner. You can check the voltage coming out of the control pc board via the schematic inside the dryer panel. I have this same exact problem. I replaced the control board 3 times because the panel seems fine if i plug it into an external power supply but will not work when plugged into my dryer. I have my jumpered and running off of a circuit breaker.
Posted on Feb 17, 2010
  • Krg583 May 11, 2012
    I would like to buy 1 of the control panels.. Email me krg583@yahoo.com
My Whirlpool GEW9868KQ2 dryer is stuck on the towels/cotton setting and will not change to any other setting. Also when i press the stop/cancel button, it wont turn off. Please help!
This is probably due to a stuck button. The only way to fix is to pull the board off and check the buttons manually and/or replace interface control.
Dec 12, 2011 | Whirlpool Dryers
Model gew9868KQ2 wont start E7 code
How do you remove the Toe panel off of the Senseon Electric Dryer?
Oct 18, 2011 | Whirlpool GEX9868J Electric Dryer
My Whirlpool Cabrio dryer Mod. WED 6600 VWO won't
When I turn the dryer on say to 40min,it shows does not come on and it goes to a F1 on the daily
Jun 26, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
We do have Whirlpool Gew9868kq2 dryer , and for
it could be a venting problem cheak out side for a clog and air
Feb 13, 2010 | Whirlpool Dryers
Whirlpool dryer MOD: GEW9868KQ2 wont heat. does turn on ok. have the element out see no breaks. Fuse maybe? where is it located?
You have a bad thermal cut-off . This piece , is a small thermostat looking piece , located ( from the front ) farthest back , on the element housing ( containing the element ) , with 2 wires going to it . Pt # 279769 . This part also comes with the hi-limit thermostat , which should also be replaced .
Nov 22, 2009 | Whirlpool Dryers
Whirlpool gew9868kq2 runs, all program panel lights work no heat under any setting
you may need the element which is #14 in the attached breakdown, part #3387747. OR, it could be a thermostat(s) #47 & 48 come in a thermal cut off kit, part #3977394 and #42 is an internal bias thermostat and the part # is 3976615. hope this helps.
Nov 13, 2009 | Whirlpool Dryers
Kenmore Evenheat MOD# 110 62056100
okay, kenmore elite have had these problems so often, you need to replaced the touchpad, not the board, jjust the touchpad, it cost around $150.00.
Sep 10, 2009 | Kenmore Dryers
Whirlpool dryer mod#len2000k01 press tha start nothing happens
First thing Is the circuit breaker, then the door switch.
Apr 07, 2009 | Whirlpool Dryers
Dryers Logo
509 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
