Question about Maytag Refrigerators
Is it cost effect to replace condensor - Maytag Refrigerators
    Master:
    Sergeant:
  • 385 Answers
No not really
Posted on May 29, 2011
Testimonial: "it will enable me to make a decision re: buying a new one"
I have a carrier air handler heatpump can I use a Rudd heatpump condensor
Yes if they match up correctly. I would stay away from Ruud though. Best off with Carrier or Trane in my opinion. Also, if your spending the money to replace the condenser, you should spend the extra bit and replace the air handler as well. New systems use a new refrigerant that is more cost effective and better for the environment.
Jan 26, 2014 | Heating & Cooling
Bad condenser unit GOODMAN
it is a 3 ton condensor you still can buy r22 freon condensors new but they have nitrogen charge and its expensive to charge I recommend to go with 3 ton goodman condensor which is new 410a puron and also change indoor coil and flush the line set so you dont endure the high cost of new copper lines these new systems come with 10 years warranty and the r22 systems come with only five years
Feb 26, 2013 | Heating & Cooling
I'm replacing the a/c compressor, the orifice tube and the accumelator dryer. Question 1, is the accumelator dryer and the condensor the same thing? Question 2, is it necessary to use a shop vac?
CONDENSOR IS THE SMALL RADIATOR LOOKING DEVICE WITH COOLING FINS IT IS MOUNTED IN FRONT OF THE RADIATOR. THE ACCUMULATOR LOOKS LIKE A CANISTER OR LOOKS LIKE A CAN.YOU NEED TO ADD 1 ONCE REFRIGERANT OIL TO CONDENSOR AND ACCUMULATOR. YOU NEED AC VACUUM PUMP. NOT SHOP VAC. THE AC VACUUM PUMP COST ABOUT $400.00 YOU CAN BUY CHEAPER ONE FOR $60.00 YOU NEED A AIR COMPRESSOR THAT OPERATE AIR TOOLS WITH.YOU NEED VACUUM PUMP TO REMOVE ALL MOISTURE OUT THE AC SYSTEM BECAUSE MOISTURE WILL FREEZE UP IN THE SYSTEM.
Jun 19, 2011 | 2001 Chevrolet Suburban
The blower on my 2002 Nissan Quest suddenly stopped working. The blower is good so what else could be the problem?
You need to buy a CONDENSOR which is held Under your glove compartment by 2 small bolts. It cost me $100 to have MY condensor replaced... and the part only costs about $45 with tax. Your blower is probably fine. Mine was!
Jan 28, 2011 | 2002 Nissan Quest
Everthing works will not heat
Micowave is not working or emitting a wave form. Needs to be replaced. There isn't a way to replace this in a cost effective way. Replacing the microwave is the best, and most cost effective solution to this problem.
Nov 16, 2010 | Microwave Ovens
Condensor fan running all day
when you say you removed the cardboard, did you remove the back panel that covers the compressor, fan, and coils from the back? If so that is what is causing it to run too much, this will also effect the cooling.
May 29, 2010 | KitchenAid Superba Architect KSCS25INSS...
Due to high voltage my Onida Television got
the power supply filter condensor got leaky in ur tv,,,,,
well it will cost 80 rs... the picture will wave ,, call a tech person to change it. value of condensor 150mfd 450v
Mar 23, 2010 | Televison & Video
Ac runs hot
If the electrical cooling fan for the AC condensor is operating, I'd just try adding a can of R134 to your system. It isn't costly and it may have just fallen too far to be effective. The coolant molecules are so small, hardly any system remains tight enough over the 8-9 years you have used the car to avoid some losses.
If the fan isn't operating, you need to find out if the fan motor is at fault or a relay isn't turning the fan on with the AC.
May 22, 2009 | 2000 Plymouth Neon
I need help selecting the best Amana 5 ton furnace/ac.
I believe you are asking which furnace to go with?
Just some clarification first.
The "condensor" is the outdoor unit.
A "Compressor" is the device inside the outdoor unit that pumps and "compresses" the refridgerant.
An evaporator is the indoor coil, it has refridgerant running through it.
The furnace is completely seperat from the condensor and evaporator.
I "THINK" you are saying that you are looking to buy an AMANA system with a 5 ton 14 to 16 SEER condensor, and a furnace, but you need suggestions on the furnace.
typically when you purchace a condensor, the evaporator coil is simply matched by the manufacturer to the specific condensor you purchace, there is no choosing to deal with. All condensors ofcourse come with a compressor already installed.
If my assumption about your request is correct, maybe this will help.
Amana's 90+ furnaces are great units. I would recomend them to anyone. The 80+ uses a somewhat inferior heat exchanger, and is ofcourse less efficient.
Anything higher than a 90+ can take quite a while to recoup the costs of the enitial purchace through your efficiency savings.
If it were my home, I would go with the 90+ furnace, and the 16 SEER Condensor/evaporator system. But ultimatly, its up to you, your efficiency standards and your wallets potential.
If you live in a northern state where AC is little needed, I'd go with the 14 SEER AC.
Again, an initial cost verses long term savings issue.
Dec 09, 2008 | Amana Heating & Cooling
Refrigerators Logo
177 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
