Question about Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television
A friend gave me a Zenith LCD projection tv. model no E44W46LCD. She said that when she turned it on the screen was white then it turned itself off. when I got it home I plugged it in and when I hit the power button it didnt turn on but the power light flashed a few times. What could be the problem and is it an easy fix.
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on May 29, 2011
Wont stay on, light with light bulb on it turns red and screen will go blank then tv shuts off completely.
replace the lanp, go online and out in the model number of your tv, when you order make sure you order the entire lamp assebly, on the back of the tv you will find where the lamp is take it out and make sure not to touch the lamp itself when installing the new one
Aug 14, 2010 | Zenith E44W46LCD 44" Rear Projection...
Very dim picture
Ur tv have been in use for at lest 4 or 5 hours a day the last 1 1/2 or 2 year?The projection bulb life it over.Require a new bulb.
May 27, 2010 | Zenith E44W46LCD 44" Rear Projection...
46 inch projection lcd, says tempature is to hot at bottom of scr
If you replaced TV lamp recently then check lamp cover and make sure to seat it properly.
Need further info, let me know.
Jul 02, 2009 | Zenith E44W46LCD 44" Rear Projection...
Reseting the end of lamp life indicator
Hold down mute button on remote and enter on TV
at the same time for a few seconds, you should get
a screen promt asking if you want to reset the timer
for the lamp.
Mar 31, 2009 | Zenith E44W46LCD 44" Rear Projection...
ZENITH TV MODEL #E44W46LCD
you must replace your optic block assembly.
Jan 05, 2009 | Zenith E44W46LCD 44" Rear Projection...
Zenith 44" LCD TV
The yellow spot is due to the BLUE LCD and/or lens assy cracked, reason, to much HEAT! The blue is the darkest color and hold the most heat, so it goes first, always! In some cases it’s only the lens, however most of the time LCD is damage to. Parts are available, however install and alignment is timely. Quick fix is the complete light engine, which for model# E44W46LCD is part# 3141VSN916C, which customer cost is $1,449.27, wholesale for about $1,065.21. Rebuilt, if you can find it around 850.00 to 950.00. However the rebuilt does not always look as good as factory. My advice, TRASH set. This part will fail again in about 3 to 4 years, unless you watch a lot of white video. Remember, on a black or dark picture, all three LCD are blocking 100% of the light, causing extreme heat within the light engine. It’s a bad design.
TV Tech
Jul 13, 2008 | Zenith E44W46LCD 44" Rear Projection...
White vertical lines in Zenith lcd projection tv
Get price of a LCD drive board first, then call a shop to see how much they would charge to replace it. If you have already researched the price you can get a better deal. But I really wouldn't try to replace this yourself. It takes major disassembly and alot of training just to get this model taken apart and put back together. Good luck, Russmann.
Jun 13, 2008 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD 44 in. Rear Projection (Wont Turn on)
I bought an open box unit at Best Buy, it had no remote or manual. Go to http://www.zenithservice.com/, click on owner's manuals, answer the 4 questions using drop down menus and then you can download an owner's manual and save it to your computer/burn it to a CD/print it out. If you choose to print it out, beware, the manual is 60 pages. One of the 4 questions they ask is "Product", choose Projection TV, not LCD TV. The 4th question is "Model Number", mine is E44W46LCD, is guess everyone's here is the same, duh.
For the remote, I looked in the phone book for an authorized Zenith TV repair company. I called them and gave the model number and paid over the phone. I had the remote shipped to my home address. The total including tax and shipping was $50. The remote they sent is a large Zenith mulit-function #6710v00102k. I don't know if that is the remote that would have came with the TV, it worked without having to program it first. It can control TV/VCR/Cable/DVD/Sat. I t has controls for 6 inputs, SAP, mute, Surf, Video, Picture in Picture, Ratio (16:9, 4:3, Zoom, etc), CC, Freeze, Menu, and controls for DVD and VCR (rewind, play, etc). If you can't find a place in your area to get the remote, Email me at gregg@hillscabinet.com and I'll look up where I got mine from. It came from Palm Desert, CA.
I don't know about your TV not coming on, is it plugged in? If it is, that's about all I've got. Gregg
Oct 28, 2007 | Zenith E44W46LCD 44" Rear Projection...
Zenith E44W46LCD 44" Rear Projection HDTV-Ready Television Logo
422 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
