Question about Maytag Neptune MAH5500B Front Load Washer
Washer is filling up with to much water...
When i start clothes the washer fills up with so much washer it pushes the door open and floods the floor. just spent $360 for a boot replacement and now this.
    Genius:
  • 1,028 Answers
Possible fill valve is sticking open when filling after starting washer disconnect power and listen to see if water is still running in if so replace fill valve.. if water stops possible water level switch or small hose to switch plugged ..drain washer remove screws on each side of door frame front will pull off...small hose on some models was attached to pump housing and would become plugged with lint ckd for restriction in hose from bottom to top remove screws in console to acess other end attached to pressure switch
Posted on Aug 17, 2008
Front-load washer fills with water when not in use.
Water valve is defective. Replace it before it floods your house.
Nov 16, 2017 | Washing Machines
Pump running continuously, Yes there was a drain pack, have emptied water, float switch clicks when moved with screw driver. Only one red light shows ( last cycle - pots ) what else can I do... James
What type of dishwasher do you have? Has your kitchen floor flooded? If it has. The tray under dish washer isn't water tight. Moisture creates some unusual problems. Some of newer dish washer the there control panel under the top of door this also create problem especially if the switches are on the top of the door. Another moisture problem. I have repaired a new Electrolux dish was three times in less than 6 months. The floor would flood from the Maytag side load washing machine. The Madam of the house didn't tell me that the washing machine flooded the kitchen floor. No window in the door and sometime fill water solenoid would stick and fill the tube. When they open washing machine door, 12 gallons of water would spill. So I fix both of them. GB...stewbison
Aug 21, 2011 | Asko Dishwashers
I went to put laundry in the empty washer to find it was filled with water. Why would it fill up with water while just sitting unused (and the door partiallly open - I have always had to leave the door...
It sounds like you have a failing inlet valve. The inlet valves have springs that push them closed when the machine doesn't require water. When you start a load of clothes, the machine controller sends electricity to the inlet valves. The electricity (via magnetism) overcomes the springs and opens the valves. Your valves aren't closing all the way due to them either failing or having a foreign object holding them open.
In either case, you need to replace the inlet valve assembly ASAP. Failure to replace these valves could result in your machine flooding- not a good situation.
Good luck.
Jan 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My maytag neptune will not stop filling with water at the initial fill cycle and will eventually push the door open and empty onto the floor. The water never turns off, even if I unplug the machine, water...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
There is a screen filter in the water supply hose that may need cleaning. A recurring problem like yours is usually caused by sediment in the water which prevents the valve from closing. It's usually just the cold water side because the hot water has a chance to settle before being used. . Being on a well water system or a system where the pipes have been disturbed from repair or construction can cause extra sediment.
Jan 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool Duet GHW9100LW1 fills up with power off
You have a faulty fill valve
If you want to check which one, try turning off the cold supply only before you go to bed
If the washer has water in it next morning it is the hot valve that has gone faulty if it is dry then it is the cold one
They are easy to change and can be bought from a number of suppliers
Jun 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fills on its own door open or closed
I would bet the water inlet valve is weeping. It may not seal shut every time. It could have a piece of rest stuck in it also. It's cheap and easy to replace. The part # AP3128776.
Feb 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My maytag neptune sometimes fills with water and floods my floor
sjhtlh
It sounds like the water valve is starting to go. i would get a tech out just to make sure.
brent
Sep 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Frigidaire Gallery washer is flooding the house
Try turning water faucets off. Does it still flood when done? Does your drain hose empty into stand pipe that is at least 30 inches from floor? Make sure drain hose does not go anymore than a few inches into pipe. If it is pushed too far in, unit can syphon water back into unit.
Nov 22, 2007 | Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
127 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
