Question about Krups KB720 5 Speed Blender
Krups kb720 press any button ,it makes a faint clicking sound when any speed is pressed is there any reset switch on unit
  • Joshua May 01, 2013
    Same problem here. NOt sure what the issue is but trying to figure it out and there doesn't seem to be much online
Krups blender switch lights, but motor doesn't turn
Hi I take it that the bottom was not screwed tight when the milk spilled. Try unscrewing the bottom, take it apart and clean it in warm water and mild washing liquid . Put it together again and screw tightly. And off it should go.
kolbrun
Mar 14, 2014 | Krups KB790 Blender
I have a Vita Mix 3600. I was making a fruit smoothie (banana, blueberry, raspberry), milk, small scoop of protein powder . Speed was on 1. I depressed the lever to reverse. I don't remember if I had...
Yes that is strange, if you let it cool down and try it again with pushing the re-set button and still does not work, try plugging it into a different outlet. Find something in your place that you know outlet is working, lamp, toaster you know. If does work in another out let, then you of course griped that breaker. Then check your breaker box to see what breaker is tripped, and switch it back on, might just of had a power surge based on putting on reverse. If that don't work, I suppose possibly something in motor or switch went out. Please let me know, if it works, I will take a banana smoothie LOL
Jun 09, 2011 | Vitamix Vita-Mix 1364 3-Speed Blender
Motor sounds like its running, but the blades
It sounds like a gear might of broken either under the blender jug or in the unit itself. Best bet is seek out an appliance repair shop locally.
Feb 02, 2010 | Krups KB720 5 Speed Blender
WHEN i PUSH ANY BUTTON TO TURN IT ON, IT WORKS FOR A FEW SECONDS THEN IT STOPS, i HAVE TO UNPLUG IT AND SHAKE IT, IT WORKS FOR ANOTHER FEW SECONDS THEN IT STOPS AGAIN. wHAT CAN i DO TO FIX IT?
Sounds like the brushes are not making good contact or you have a defective switch. Run the blender witout the container or blades . Free run it for 5 minutes id you can and see if that helps.
Oct 20, 2009 | Krups 574 Power Xtreme VI Premium Work Top...
Uhh....... the blender mafuntioned when i plug in it blens even when i dont turn it on
Sounds to be a switch is stuck or button . Tap each button vigorously and turn each one on and off. Pressing another speed should cancel what ever button is stuck. Good Luck, Ned
Sep 27, 2009 | Sunbeam 4192 Work Top Blender
Kitchenaid Blender Classic
Same thing happened to me. Opened it up and along the red wire to the motor is a bass fuse. Went to the hardware store and then I replaced it. Works fine.
Apr 12, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Spillage onto base of blender!
Usually leakage into the base can compromise the motor's performace. Since it sounds like this also has digital displays, you don't want to risk messing it up even more by turning it on. The company should have service places you can take it into to get checked out, some might even do an estimate for free. I would call the company and see if that's possible and maybe just a quick cleaning can fix it.
Mar 05, 2009 | Krups KB7207 4 Speed Blender
Blender has lost top two speeds
With my blender, some of the buttons stopped working, and I found a simple way that fixed it like new, with no special skills or replacement of parts. To determine if this fix will work for you, unplug the blender and press on each button. As you do this feel and listen for a definite 'click'. If you here it for the buttons that are working, and not for those that aren't, you probably have the same problem.
I discovered that there is a tiny mechanical push button switch under each button. The switches are held snug to the bottom of each button by a thin metal bracket. If you have heavy fingers, the force of pressing the buttons over time, causes the bracket to deform, moving the switches further and further away from the buttons until, eventually, no matter how hard you press, they are no longer close enough to depress the switches underneath.
The solution is to simply open the blender (with the power cord removed) and gently push the button assembly back towards the buttons. To get inside you need to pull out each of the four rubber feet, and unscrew the phillips head screws that are hidden under them. Next, seperate the top and bottom sections by gently pulling the power cord through the strain-relief (don't worry, it goes back together very easily). Before putting it back together, check the buttons (always with the power cored unplugged !!!) for the 'click'. If this doesn't work, you may have to take out the two screws that fasten the bracket to the blender, and bend the bracket hold-down tabs with a plier, in the opposite direction of the switches (that way when you put the screws back in, they'll move towards the buttons. That's it.
Hope this helps someone like me save about $150.00 for a new one and keep another 10lbs. of junk out of the landfill.
Nov 08, 2008 | KitchenAid KSB5 Ultra Power Work Top...
Buttons click but it won't run.
i had the same problem after only one month, took in back to walmart and they would do nothing. i love the big heavy glass jar on this model so i baught another on thinking i broke it some how and guess what, the second one stopped after one and a half months. called around and no one would do anything for me, company sucks, i took the bottom cover off the blender to expose the problem and there is a problem with the curcuit board and built in breaker. i ripped out all the speed buttons and curcuit board and just wired in a on/off switch to the motor. works great again. i still had a extra broken blender so i took a old chain saw i had and turned that one into a gas powered blender. problem solved, any questions please feel free to ask, strawsj1234@hotmail.com
Mar 17, 2008 | Black & Decker BL5000 ProBlend Work Top...
Krups KB720 5 Speed Blender Logo
90 people viewed this question
Top Krups Blenders Experts
pdavis1000
Level 1 Expert
Kolbrun...
Ross Keen
Are you a Krups Blender Expert? Answer questions, earn points and help others
