Question about Zenith Televison & Video
2005 model Zenith 50inch DLP YV makes a very loud humming noise when it is turned on. lamp in on but no picture
  • rwwdir May 29, 2011
    That was my next guess. Thanks
  • rwwdir May 30, 2011
    is there a replacement wheel available anywhere?
  • 643 Answers
Vacume out where the fan is in the back of the tv. That should release alot of the built up dust. I try to do that to my tv atleast once a month. Hope this helps.
Posted on May 29, 2011
    cooling fans are working OK This is a VERY LOUD whirling sound. It is coming from the light bulb side of the set. The picture is white with a 4 inch horizontal line near the top of the screen.
  • Mando Mojica
    Mando Mojica May 29, 2011
    That sounds like the color wheel. Repairs are usually worth it. Hope this helps.
How do I fix loud humming noise in my DLP HLP4663W 42 IN Samsung TV?
I would start by checking all the cooling fans to see if one is dirty or possibly failing.
Aug 30, 2015 | Samsung HLP4663W 46-Inch Widescreen DLP...
My phillips is making a loud buzzing noise, no picture, then it shuts off
presuming it has one two choices: contact Philips (good luck there) or Google the model number with "color wheel"
Oct 31, 2012 | Philips 50PL9126D/37B 50" DLP TV
I have a 2005 zenith 52 inch model# Z52SZ80 heres the problem i replaced the lamp and when you turn it on as soon as the picture comes up the lamp shuts off and the red lamp light blinks 8 times then...
This is a DLP tv wright?Problems with many DLP tvs after changing the tv projection lamp,tvs still have the same problems or make alots of cliking sound too.The board that call the Ballast baord is also is dead.The Ballast board only job is to ignite the tv projection lamp.
Mar 01, 2011 | Zenith Televison & Video
I changed my lamp a few months ago, but now the tv makes a loud humming noise when you turn it on. The picture is still good, but it continuously makes the noise.
This is most likely caused by the DLP Color Wheel Motor. It is a common problem with all DLP rear projection tv's. This motor is located inside the Light Engine Assembly. It is a exspensive Assembly to replace. I did not see brand name of the set. If it is a Samsung, the motor can be replaced separately. The motor will continue to get noisier as it is used.
I hope this helps,
Skyassoc
Dec 08, 2010 | Televison & Video
Hi I have a samsung hlr4667 and the set will not come on at all.. It makes a buzzing sound kinda like it makes when powering on..And the lamp light flashes but no picture just a loud humming sound...The...
This DLP tv have a colors wheel.The tv colors wheel,it dead.Have loud humming sound,motor noises and pictures flashes black&white within a picture.The colors wheel is dead and is spinning off of it axis and hitting of it sides motor walls.Tv must require a replacement of a colors wheel.Hire a tv tech. to do the job.The tv colors wheel is hard to replace.The tv colors wheel sit behind many manchanical parts,must take out even before u even can replacement the colors wheel itself.
Nov 05, 2010 | Samsung HL-R4667W Rear Projection...
Samsung DLP making noise and is picture out
Lamp probably went out. Refer to your manual regarding lamp replacement.
May 16, 2010 | Samsung DLP HL-P5663W 56" TV
Tv is making a loud buzzing noise and the picture is all funny ie colurs are out and pixelated
Hi,If your tv is a dlp you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.
Apr 05, 2010 | Samsung SP46L6HXX/XEU 46" HDTV-Ready DLP...
I have the same problem with the HLR4667W model.
The noise could be from the try joint on the main Board please try resoldering them all.
Main filters are common to be targeted.
Thks..
Jul 22, 2009 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
273 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
