Question about Universal Kreepy Krauly In-Ground Pool Cleaner
My Kreepy Krauly pulses, has good suction but doesn't move. I noticed the "skirt" at the bottom of the cleaner is pretty shredded. Could that be the problem?
  • 990 Answers
SOURCE: Our kreepy krauly will not stay suctioned to the
Check for air leaks in your hoses, your pump or in the plumbing system. Also check for clogs in your pump impeller if you have any problems with your basket. Good luck.
Posted on Apr 24, 2010
Coastsider
  • 331 Answers
SOURCE: My kreepy Krauly will start up and within 5 stops working.
If it is a year old, replace the flapper valve. Also check your water flow and make sure it is adequate. These units are subject to wear on the foot and flapper and these should be changed each season
Posted on Apr 14, 2010
Testimonial: "Great thank you for this info...I believe that I need to buy another type....too many problems with this type of cleaner."
Geekman
  • 32281 Answers
SOURCE: Kreepy Krauly In-Ground Pool Cleaner: my creepy crawler wont hammer...
This usually happens when there is a small stick jambing in the bottom of the openning in the Kreepy Krauly where it sucks in the water and rubbish. It is the rubber tube that has a ****, usually something is jambed in the **** to prevent it from thumping.
Posted on May 25, 2010
jharwell668
  • 640 Answers
SOURCE: my kreepy krauly seems to have good suction, but
Try these suggestions to get your automatic pool cleaner working properly:
• Check to ensure that the main drain and all suction lines are closed, except for the suction line to which Kreepy Krauly is attached.
• Check for debris in the filter or pump basket.
• Check for debris in Kreepy Krauly’s flapper. Debris may prevent flapper movement or restrict flow.
• Check the hose to ensure there are no leaks.
• Check the vacuum connection. It should be submerged so no air enters the system.
• Check the pump basket lid for looseness, cracks, and worn or missing O-rings.
Posted on Jul 28, 2010
jharwell668
  • 640 Answers
SOURCE: My Kreepy Krauly won't move. I've checked the hose
Yes, it could. Check the filter and pump for debris. This could severely restrict movement in these pool cleaners. Also, check the flaps of the Kreepy Krauly for debris. Also, check to make sure that the main drain and ALL suction lines, except the one the cleaner is attached to, are closed. This might also be why you have a lack of suction. My final suggestions would be to check the return line water flow and make sure that it is strong enough.
Posted on Feb 01, 2011
Kreepy Krauly has very little suction thru head but plenty thru hose
most all pool cleaners generate there motion with a thing called a venturi ! thats inside it usually moves a small propeller from the action of water being sucked hard thru the hose , on most the path to this "propeller" is different than that of pool debris , i suspect this alt path is part ways blocked , a simple way to clear is to connect garden hose to suction port of cleaner and force water Back in other direction other than that sometimes dissasembly is need to lube and clean hidden ports inside
Jan 04, 2014 | Pentair Kreepy Krauly Inground Automatic...
Kreepy krauly regulator valve won't close, it's always open so the cleaner doesn't move. There's plenty of suction,
It has debris stuck in it. Normally it is not too hard to clear it out. If you can't clear it, try to run the Kreepy without the regulator.
Aug 04, 2013 | Pentair Kreepy Krauly Inground Automatic...
BROKEN SUCTION HOSE CONNECTOR DOWN IN SUCTION WELL
Contact them direct. This is not something that can be answered by Fixya, especially as this is an Australian product and we are a North American self help website.
Pool Cleaners ' Automatic Pool Cleaner - Kreepy Krauly Pool Cleaners
https://www.kreepykrauly.com.au/Kreepy Krauly is Australia's most trusted and innovative automatic pool cleaner. Request a free pool cleaning demonstration with one of our pool cleaners today.
Kreepy Krauly Google Search
Aug 25, 2017 | Universal Kreepy Krauly In-Ground Pool...
I have great water pressure in my pool, but the minute I attach my Kreepy Krawly, the pressure drops and there is a large vacuum in the pump reservoir. the Kreepy hardly moves at all thereafter.
It sounds like your you might not have all of your suction lines closed. Check to ensure that the main drain and all suction lines are closed, except for the suction line to which Kreepy Krauly is attached. If this is not the problem, it could be that the pool pump and filter system that you have may be too small It should be capable of providing at least 25 gallons per minute. These are common issues with these pool cleaners.
Feb 02, 2011 | Universal Kreepy Krauly In-Ground Pool...
My Kreepy Krauly won't move. I've checked the hose for holes and also replaced the vinyl suction cup on the bottom but it won't budge. Doesn't appear that there is much suction. Could it be something...
Dec 30, 2010 | Universal Kreepy Krauly In-Ground Pool...
My kreepy krauly seems to have good suction, but moves very slow. I usually hear a tic,tic,tic,tic, But, lately it has been tic....tic......tic Very Slow
Jul 28, 2010 | Pentair Kreepy Krauly Inground Automatic...
It moves too slowly
If these automatic pool cleaners are moving slowly or sluggishly, first check to make sure that filter and strainer baskets are clean and not clogged. Make sure that the main drain and all suction lines are closed, except for the suction line to which your Kreepy Krauly is attached. Make sure there is not debris in the flapper than might be restricting movement. Also, and especially if you are noticing bubbles during slow movements, check for leaks. Make sure there are not leaks in the hose, vacuum connections, pump basket lids, etc.
Jun 18, 2010 | Universal Kreepy Krauly In-Ground Pool...
Our kreepy krauly will not stay suctioned to the bottom of the pool. What can we do?
Apr 24, 2010 | Universal Kreepy Krauly In-Ground Pool...
My kreepy krauly is moving at half speed and sometimes stops moving all together. All tubing is good, filter has just been cleaned, any ideas?
Check your pump pressure on the suction side. If there is any air gap in your pump strainer pot (if you have a see thru see thru strainer cover) then you have a leak on the suction side. Auto matic cleaners need ample pressure for them to move. or you might need to backwask the filter check your pressure gauge. If none of these help its more then likely the gears in the cleaner. also check your cleaners hoses
Aug 16, 2009 | Universal Kreepy Krauly In-Ground Pool...
Universal Kreepy Krauly  In-Ground Pool Cleaner Logo
124 people viewed this question
Top Universal Pool & Spa Experts
Bill Jordan
Are you an Universal Pool and Spa Expert? Answer questions, earn points and help others
